Cinelli 1R stem help
Я люблю суп
Ok I love the 1R but it doesn't clamp down the handle bar. I was at a bumpy trail today. Every time I hit a bump, my handle bar rotated forward or backward. What is your trick to clamp the bar down on the 1R stem? Look at the picture below, it was bad. I am about to change it out to a 3ttt stem and bar.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Do you have a Cinelli bar in the stem?....because I thought that pre-1996 Cinelli bars are a little (26.4mm instead of 26??) bit bigger in diameter than other brands, so if you have a different brand bar in the stem, it might be too small for the stem to grip on it adequately. Or you might also have an older 26.4mm Cinelli stem combined with a newer 26mm Cinelli bar.
Chombi
Chombi
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
Also check the binder bolt to make sure there isnt a burr or damaged thread. Could be you tighten the bolt and its not really tightening on the bars. Had this happen once. It was maddening until I removed the bolt and inspected it.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
It looks about my size... Send it my way and I will send you a bike with bars that don't slip.
