Pairing Di2 to Wahoo
I got a replacement 105 di2 rear derailleur that I'm trying to pair up to my Wahoo Roam. Because it's a replacement, I unpaired/forget the previous di2 so I can pair the new one. However, the Wahoo is not finding the replacement di2. I've made sure the di2 is not sleeping. I also tried to pair it with the di2 in pairing mode (usually reserved for the E-tube app). All nothing. The di2 does connect to the e-tube app so that makes me lean more towards the Wahoo.
Any thoughts/suggestions? Thanks!
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Are you able to see the new RD in the E-Tube app.
Maybe check it's firmware revision at the same time.
Don't forget to "Disconnect" correctly.
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Then as long as the bike is awake (trip the brifters) the wahoo should be able to add the Di2 as a sensor
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Thinking about it….. Bluetooth operates on 2.4GHz, make sure you are not near other 2.4GHz devices.
Anything Wi-Fi, Microwave oven, phone…..
Go outside if you have to
Barry
Barry
Liked 2,979 Times
probably have to pair the phone to the wahoo to have it see the Di2
-Oh Hey!
-Oh Hey!
Wahoo is paired to phone through elemnt app. I tried to pair di2 through elemnt app and also directly through the roam device. both times, it doesn't see it. So strange. I do have multiple devices nearby though.
Liked 2,979 Times
will the wahoo pair with another sensor if you "forget" an already existing one known to recently work with it?
-Oh Hey!
-Oh Hey!
Likes For Troul:
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
howaboutme , I put a lot of configuration into my Bolt before I really understood the pages, etc. My configs were logic spaghetti and doing a factory reset is what allowed me to add a new sensor.
You're probably not as dumb as me, but the factory reset was the enema my Bolt needed. It's been very happy ever since.
Quoted: 482 Post(s)
Liked 1,593 Times
Since you use Element, your ride data is in their cloud too. Only the configurations are lost in the reset.
Likes For BTinNYC:
Quoted: 3242 Post(s)
Liked 2,087 Times
Likes For Steve B.:
Ok all. I unpaired the Wahoo Cadence sensor to see if it will find it and repair. It did. So now I'm thinking it's the di2? Any thoughts? Should I do a factory reset of the Wahoo just so I can fully eliminate that as a cause?
I also confirmed that it can connect to the E-Tube app. I even tried it in pairing mode just in case. Nothing.
Ok, I did a factory reset of the Wahoo. Every sensor was found and paired except the di2. Any thoughts?
I figured it out!! The di2 was only set to bluetooth. It needed to be set to both Ant+ and BT.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Well that’s a new one….
Thanks for reporting back on the fix.
Barry
Barry
Likes For Barry2:
