Pairing brifters w v brakes/cantis
Bikes: lots!!
Am building up a cyclocross frame with canti mounts on the stays and fork. The Shimano brifters I've mounted on the drop bars don't work well w the v-brakes I installed----too much lever travel for actuation of the brakes! Is there a way/gadget to get around this apparant incompatibility...?
Bikes: Bianchi Road bike, Nashbar Ultegra triple cyclocross, Raleigh full XT hybrid, lugged steel Schwinn, Full rigid Diamondback MTB
Travel agents will let you use your long pull v-brakes with your short pull levers. Most people just use short pull brakes (canti's not v's).
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
https://harriscyclery.net/product-lis...00-m6417-qc49/
Jeff Wills
Jeff Wills
Likes to Ride Far
I've found that V-brakes with travel agents are way better than canti- brakes. The only thing going for the canti's is that they have better mud clearance. However, they can be a pain to set up and need to be done just right to get full power. In contrast, V-brakes are pretty straightforward, even when using travel agents.
