Just Sturmey'd my Bianchi
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times
So, my main commuter is now a 3 speed. Got a downtube shifter for the 3 speed wheel I built up over the winter, and that's the solution to my second derailleur explosion on that bike.
Now THERE's your problem!
To be fair, the derailleur may well be fine, but I don't have another 'claw adaptor', and the whole rig never really worked right with the rear spread to 130 OLD. I also had the Sturmey Archer wheel burning a hole in my 'to be used' parts bin, and now I've got motivation to figure out why the 5sp Sprinter hub isn't working (they're both drum brake versions - I'm seeing an ability to switch here)
I'm really enjoying the hub so far - it's really not any less trouble, as the 1056 drivetrain wasn't any either, but I don't find any lack of gears for my use, and I actually enjoy that I'm using a more varied cadence. I'm considering using the bike as my winter bike - it's got enough clearance for the 35mm studded winters I use, and getting rid of one more bike WOULD be popular with my wife. I just sold my carbon fibre road bike to pay for a BMX race bike (kids just started racing, wanted me to join in), and with this conversion on the Bianchi I think I may look for a slightly better steel frame to build as more of a classic road bike, and keep this as my usual commuter. 2 bikes for road riding, one for BMX should be able to be defended. My other two bikes aren't together right now anyway - might as well sell them, they're not much use as backup bikes if I need a couple hours to put them together.
I routed the shift cable same as I would a DT shifter for a rear derailleur, it just comes across under the chainstay to meet the indicator chain instead of going to the cable stop - lots of clearance everywhere. I had been considering a pully mounted to the seat tube, but it shifts very sharply as it sits.
I'll snap some pictures tomorrow.
Likes For Viich:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I'm looking forward to the photos.
I keep toying with the idea of a 3 speed hub of some sort. My usual test is to figure which gears on my 7 or 8 speed bikes simulate a 3 speed and ride it in those gears for a ride or two. It seems that if gear 3 were set for my usual cruising gear of 70" then I'd only need gears 2 and 3. Gear 1 would be all but useless to me.
It's nothing but flat here and the only hills are overpasses or wind, and I never ride up overpasses.
Basic
3 speed math: chain drive gear ratio is 2nd, 3rd is 4/3rds (1.33) of that , 1st is 3/4 (.75) of that 2nd.
(big '/, little x wheel diameter in inches )
[57.6 2nd ,76.6 3rd, 43.2 1st] (my 16' wheel Brompton 54:15)
[54 2nd, 71.8 3rd , 40.5 1st] (a 2:1 chain drive, 27" wheel)
Hack
Quoted: 347 Post(s)
Liked 190 Times
The yellow thing kind of happened by accident - next tape job is likely yellow as well.
I like the Sturmey lever
Housingless is better. Looks a little funny coming out from behind the chainring
Used the plastic cable guide - works great. Was going to use a Sturmey pulley, but the retaining tab didn't line up and I was afraid of more issues.
Drum brake for future.
I'm the anecdote.
Liked 1,176 Times
Looks like a great mod.
You helped put me over the edge towards a future project I want to undertake. That is take a single speed bike of some sort and put a 2-speed hub in it.
I ordered a SRAM Automatix through Bezo's company. Should have it in a couple weeks if all goes as planned. Although, I haven't come up with the bike yet. In this situation the Automatix is a 36 hole hub, seems like that reduces the wheel options a bit.
Hack
Quoted: 347 Post(s)
Liked 190 Times
I use Sheldon's Gear Calculator
I'm running 44t chainring and 18t cog with a 622x35 tire, giving me:
gear inches of :
18T: 20T
Low: 49.8 44.8
Middle: 66.4 59.8
High: 88.5 79.7
As I had it built before, I had cross cranks on it with a 12-25. The highest gear I used regularly was 48:15, almost the same as 3rd, and 1st maps exactly to 38:21. As far as absolute range, I'm losing 2 gears off each end - I used the low ones slightly more often, but I don't really need them, it was mostly while biking with my kids. Basically, I'm losing the small steps. I actually like that it's making me use more varied cadence. I probably could go up to the 20T as I show above, but I think it would leave me in high most of the time instead of middle - I'd rather be in the direct drive, I think. I still use the high on most rides, so not a waste. I'm also planning on switching to a 30 or 32 tire, which will gear me down (very) slightly.
Old 8sp 48-38 x 12-25
48t 38t
12 108.7 86.0
13 100.3 79.4
15 86.9 68.8
17 76.7 60.7
19 68.6 54.3
21 62.1 49.2
23 56.7 44.9
25 52.2 41.3
I'm the anecdote.
Liked 1,176 Times
Dang. Lost my post in a glitch.
I'm kinda hoping to find a bike with a set of 36H wheels already on it. Something like the SE Bikes Lager has 36s on it, per their specs. Most everything else I come across has 32H hubs.
However, I'll probably end up getting a 36H rim like you did to match the hub. That should open up my bike options.
By the way, I don't think I see many 3-speed drop bar bikes out there, which makes that Bianchi a unique ride. Too cool.
Hack
Quoted: 347 Post(s)
Liked 190 Times
There isn't really much point in taking apart a single speed wheel to put the 2 speed hub on - the spoke length is going to be different, so you need different spokes, and it's really better to just start with a clean rim. If you want something cheap check out the local bike coop. Which I should have done instead of getting the cheapo single-wall.
I've got an SE Draft Lite frame I'm likely getting rid of - I had my 5 speed sprinter hub on it a few years ago, but when it wasn't shifting correctly I just put a single speed freewheel on it and kept riding it for the winter. I'll work on getting the 5 speed working again so I have an easy-swap backup for the 3 speed (or vice versa)
Last edited by Viich; 07-07-19 at 07:33 PM. Reason: Correcting my run-on sentence. At least one of them.
Likes For Viich:
Quoted: 7348 Post(s)
Liked 2,465 Times
@Phamilton, take note.
Hack
Quoted: 347 Post(s)
Liked 190 Times
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Awesome job - is the shifter a bar end shifter mounted on the DT? If so, would "standard" DT shifters work in this application?
Hack
Quoted: 347 Post(s)
Liked 190 Times
Sort of - I'm pretty sure it's the same shifter Sturmey-Archer sells as a thumb shifter, bar end shifter, or the under-seat shifter, but without a clamp or pod.
Having the Sturmey-Archer detents is terrific, the shifting is very positive. Plenty of people have said they've done it, and as long as you get into the right range (I think it's pretty forgiving), the hub should work fine. Issue is that running it in between gears is bad. 3 speed you can likely get away with it.
Virgo
Quoted: 1062 Post(s)
Liked 665 Times
Nice build! A three-speed on a nice slick bike is a joy to ride.
I have but one minor quibble, based on a similar build. The shift cable running directly from the bottom bracket to the hub, leaves a lot of cable exposed to get hung up on things. My cable got caught on the heel of my shoe, and got torn out while I was on a ride. I had to hobble home in 3rd gear. So I now add a little guide -- here you can see that it's just a piece of cable housing, innertube rubber, and zip tie. This has lasted for a few years so far. Also, make sure the shift cable can't get hung up on the cable guide that's down there for the original derailleur cable.
Hack
Quoted: 347 Post(s)
Liked 190 Times
I see you aren't using a cable stop on that end of the housing - do you have any issues with having to adjust the shifting?
Virgo
3 speed blog
I used to read this blog, before I joined BF. It’s no longer updated, and I don’t know the etiquette of publicly sharing the link but it’s still open.
Its what inspired me to ever want a drop bar 3 speed. My first bike as an adult was my Schwinn Collegiate. Not suitable for drop bar. And I don’t care for the Shimano hub.
3-Speed Blog and Occasional Keyboard Shortcut Trading Post
Liked 665 Times
May just be how I position my feet, shorter crankarms or longer chainstays, or some combination thereof, but I'm no-where close to the shift cable (or the chainstay) at any point in my pedal stroke.
On another 3-speed in my fleet, the shift cable is housed all the way from the shifter down, and runs along the seat stay. In that case, a cable stop is definitely necessary. I suppose a rule of thumb is that there are always an even number of cable stops in the system, where the shifter is one of the cable stops.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Neato bikes, have fun riding without hearing grinding. ha But shift cables on the chain stay is really lame, IMO. Cable getting bonked or muddy beside your heel? Pffft
I'll ride in tall rubber boots now and then.
All my IGH attempts have had the shifter on the TT, including my Rohloff. I just sawed up some tubes and got them welded at Midas. Didn't get around to doing something prettier than hose clamps. My housings go all the way.
Bikes: Windsor TimeLine; Linus Gaston 3; Sears Free Spirit
Quoted: 43 Post(s)
Liked 99 Times
My kind of bike
I have a Windsor TimeLine setup with an SRF 3. On mine, I have the traditional trigger shift on the drop below the right brake lever.
The shop routed the cable along the chain stay. A cable cover, the wedge shape, came with the hub.
From today’s ride to Canarsie Pier in Brooklyn.
Hack
Quoted: 347 Post(s)
Liked 190 Times
I have a Windsor TimeLine setup with an SRF 3. On mine, I have the traditional trigger shift on the drop below the right brake lever.The shop routed the cable along the chain stay. A cable cover, the wedge shape, came with the hub.
Quoted: 43 Post(s)
Liked 99 Times
My other bike, a Linus Gaston 3, has the same hub but with the downtube shifter.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,431 Times
Likes For Gresp15C:
