Colder weather - glasses fog up issue.
How do you guys deal with this?
Its ok when moving, but when stopped things get foggy real fast. I can wear contacts to solve this issue, but then I like to have protection from the wind, dirt, dust etc.
Quoted: 626 Post(s)
Liked 701 Times
Least expensive solution:
1. Put a drop of dish soap on each lense.
2. Smear it around real good with your fingers.
3. Wipe clear. (use a dry rag)
Depending on how long your commute is, you might have to do this before every ride, or every few days.
There are other antifog solutions that last longer, made specifically for glasses, that cost more:
https://www.amazon.com/Eyeglass-Clea.../dp/B0143RD3OK
https://www.ebay.com/i/112963700666?...iABEgJiFvD_BwE
The one I use on my motorcycles (for both my glasses and my visor) that works well for both fog, and helps rain bead off the outside:
https://www.nikwax.com/en-gb/product...-1&fabricid=-1
Likes For Notso_fastLane:
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Put a glasses "leash" (like Croakies sp?). on your glasses. Set the thing,that allows you to tighten them up just loose enough so you can pull your glasses down a little to vent them. When you stop pull them down a little and put them back up when you get moving.
Quoted: 4788 Post(s)
Liked 3,912 Times
These are old memories. I haven't winter commuted in snow country for 40 years but when I did, it was Ann Arbor and Boston and I didn't own or drive a car.
Ben
Likes For 79pmooney:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,198 Times
I've never found anything that is 100% effective. I've never even found something that is 10% effective. Look at the construction of the glasses. You don't want them too close to your face. I use Rudy Project Kerosenes and they clear pretty quickly after I start moving again. I have the nose pieces moved so that the air flows over them better and they have vents at the top of the lenses to get air to flow in behind the lens. I also pull them away from my nose when I come to a stop to avoid as much fogging as I can. You might also try blowing your breath out of your mouth and down away from your face.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: 2 many
Liked 323 Times
I used wire rim glasses (not goggle-like sport glasses) in my winter riding days. I'd pull them a little down my nose at lights. Also practiced breathing away from my glasses, directing my breath down (usually - wind could be a factor). With the glasses pulled down, I could see (sorta) when the light turned green even if they did fog.
Ben
Ben
Seems like I will have to pull the mask down when stopped and put up once moving is the only good solution.
Since the fog goes away almost instantly when I start moving again, I don't find this an issue. I don't wear anything over my mouth though, perhaps the fogging up is way worse that way.
Swimmers spit in their goggles to keep them from fogging up. I wonder if this would work on bicycle goggles that are not underwater.
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
When it's cold I'll put on a cheap pair of ski goggles. This pretty much works 100% of the time. As far as glasses goes, I haven't found a solution that is effective yet. Besides, goggles give the ski area around your eyes protection as well. Even with a balaclava covering my nose it's not a problem.
Likes For mcours2006:
Bikes: 2010 Giant Rapid - Trek 820 - 1968 Schwinn Continental
Quoted: 13 Post(s)
Liked 11 Times
It does not have to be cold for glasses to fog up when stopped. I live in Florida and it happens here too. If my glasses are not fogging up, then they are subject to dripping perspiration, which does not clear up without wiping the glasses dry. At least fogging clears up as soon as I start moving again. I wear a sweat band to capture the perspiration just above the brow and I bring a sweat rag to wipe my forehead when I stop, which works okay. Unfortunately, I have not found a great solution for either issue.
Likes For bpcyclist:
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 345 Post(s)
Liked 186 Times
I go a little slower so I'm not breathing hard. It's actually not an issue on my non-snow season route, I only have to stop 3-4 times. In snow/ice season, I'm usually going slow enough, and/or pull my balaclava down.
Quoted: 800 Post(s)
Liked 218 Times
I perenially post my approach to the problem, most recently on the Winter Cycling Forum.
Follow the link for further information, and
Considering how frequently this question arises I have also frequently posted:
including a dispute with the dishsoap / spit solution.
I favor:
And I look forward to trying this newly-posted solution:
Originally Posted by Jim from Boston
(from a now-closed thread)…In the past I have offered IMO several useful suggestions about cycling, particularly for winter and urban cycling, to multiple repetitive threads.
They are usually lost in the morass of often scores of replies, both in agreement and dispute with mine.
I favor:
I use an old Iditarod trick I saw back in 09 of Jay Petervary,a veteran rider of the 1000 mi trip to Nome. In addition to wearing a balaclava, I cover my nose and cheeks with a fleece headband. This gives my breath an opening to escape without going up my goggles when covered with the balaclava.
This is my 11th winter of daily commuting. I always had fogging problems below 10'f. I used it at 0'f and it worked great.
I’ve used “Scott Lens Cleaner & Anti-Fog” for years with good results with my motorcycle riding. You want to put three to four coatings on.
https://www.cyclegear.com/accessorie...eaner-anti-fog
Quoted: 1813 Post(s)
Liked 1,692 Times
As a long time(39+ year) cross country skiier, I can tell you that your glasses will always fog up when you stop moving, so just don't stop. There is no magic solution for this, just keep moving, air will circulate and your lenses will stay clear. If you stop, remove your glasses. Replace them when you start moving again
Likes For alcjphil:
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
Quoted: 1324 Post(s)
Liked 927 Times
If there's a military surplus store near you or you find on online, then you might be able to buy some anti-dimming compound used on the lenses of gars mask to prevent fogging.
Cheers
Cheers
