Fit question- reach
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Fit question- reach
My current bike has flat bars, a 525mm (c/c) top tube (non sloping) and a 70mm stem.
I am interested in a frame but the smallest size which makes sense is one with a 590mm (c/c) top tube. I can get a 35mm stem so the overall difference in reach will be +30mm.
I know it’s not fair to throw in multiple variables but I’ll also be running Jones H bars with a 45 degree sweep.
Being that the new frame comes with a fork with an uncut steerer, I can raise it up a bit higher than my current setup.
So between the backswept bars and the ability to customize the bar height, is 30mm extra reach a big deal or not?
Quoted: 4201 Post(s)
Liked 3,857 Times
So the prior numbers are with using what kind of bar? Andy
AndrewRStewart
AndrewRStewart
Quoted: 1104 Post(s)
Liked 1,825 Times
Measure your current set up using the 80mm wide point of the saddle to the center of the grips where your hands go. Then install the new bars (or lay them over the current bars) and measure again. When it comes to fit, only a tape measure will tell the truth; the rest is just something somebody said on the inter-net.
Likes For nomadmax:
Liked 3,857 Times
Thanks for the added details. Generally I follow nomadmax's advice. Careful measuring, careful "lay over" placement of the new, then the judgements and follow up fine tuning. One aspect not easy to anticipate is the wrist angle between the two bars and how that effects the feel of the fit. I have a few customers/friends who have installed similar bars and they have mentioned this wrist angle as being a big part of the improvement in comfort as the miles add up. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Likes For davei1980:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
If it is a new frame you are looking at, see if the manufacturer has a similar model designed for use with drop bars - it will almost certainly have a top tube a few cms shorter.
Likes For Wilfred Laurier:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Thanks all, very helpful!
As mentioned above, my Ridley XBow is a CX bike with short everything, made for drop bars. I like it in its current config. with ghetto aerobars.
I want to build a 27.5+ rigid bike and the Crust Scapegoat is appealing to me but has 65mm longer top tube.
I have also ridden the Jones Plus LWB with these bars in the SM and MED sizes with 584 and 609mm top tubes, respectively (I just found out these lengths, Jeff Jones is somewhat secretive about the details of geometry). The SM fit just fine and the MED was even better with 50mm stems so I am now a little LESS apprehensive that the MED size Scapegoat with the 590mm top tube will work.
See below for picks of my current ride, the Crust Scapegoat and the Jones Plus LWB:
Quoted: 836 Post(s)
Liked 1,061 Times
I think you would have better luck by mounting the new bars on your current bike, find a comfortable setup and then do your measuring. As mentioned having such a different wrist angle is going to change your riding position enough that just measuring hand position distances between the two different bars is not going to transfer into rider feel.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Good advice by the way and thank you
Liked 1,825 Times
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Call it a compromise, I don't care, but I am happy with my platform/SPD combo pedals I am using now. Not the lightest things ever but they work well on my commute and just tooling around with my kids in street shoes....
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
How tall are you?? Looks like 6'+ in your pic. The Ridley is obviously too small for any other bar.
If anything the 590 TT will be a bit small too. You will not need a shorter stem for sure. The Jones bar is very wide, but likely OK for you.
I am 5'8" and made my custom tourer with old style 70d swept upright bars with 6" grip area, so back farther than the Jones B. My TT is 610 and stem is now 76mm with 13d rise. I still get knee overlap with sharp turns.
Actually my other 1973 CCM 3 spd has a slack 23" ST and 23 1/2" TT with a level 70mm stem. Fits perfect, with the same SB bar. I have had 3 different width bars, 47.5 to 51 cm CC. I liked the one half way the best.
Liked 1,825 Times
You mean the Crust Scapegoat? I have seen them advertised, it's like a strap which goes diagonally across your foot.
Likes For nomadmax:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
My Ridley is compact in every way - it's a CX race bike 1st, I just have it set up for commuting and I have tubeless gravel tires on it.
I am not thinking of putting a Jones H bar on my Ridley because I think it's just too compact, not without at least switching to my 100mm stem (70 mm stem w/ 45 rise pictured.)
Thanks for your input on the 590mm frame (Crust Scapegoat) I am pondering - let me leave you with this and you can let me know what you think:
I test-rode a Jones Plus LWB with the Jones H Bar in two sizes: SM and MED. The small has a 563mm top tube and the MED has a 588mm top tube. Both had a 50mm stem or close to it. The small fit me well in the legs but the cockpit was a little cramped. The Med fit better but standover at 31.5" was too tall. If I were to buy one I would get the small and put a 75mm stem on it.
The Crust frame I am posting about here has about a 29" standover (perfect) and 590mm top tube so I am thinking I can marry the benefits of the lower standover and the roomier cockpit. I can always add up to about 60mm or subtract about 15mm of reach with the stem.
It's worth noting both the Jones bikes I test rode had a set back seatpost.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
"Reach" and "top tube length" are not the same thing. The former (the horizontal distance from the BB to top of the head tube) is a more useful means of comparing how two frames will fit.
You have to be careful using just top tube lengths for comparing how frames will fit. The problem you can run into is that they are not directly comparable if the seat tube angles are different.
Likes For Kapusta:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I did a little more research -
The Jones Plus LWB has a ETT length of 24.0" (the bike I have ridden and feel comfy on, except a bit too tall) - fitted with 50mm stem on my ride
The Crust Scapegoat has a 24.4" ETT length. I can put a 40mm stem on it to shorten the reach by about 0.4"
I plan on using the same bars as I test rode the Plus LWB with. Both bikes have a 69 degree eff. seat tube angle and a 73 degree head tube angle.
They should fit very similarly in the reach, then, correct?
I like the Crust Scapegoat a little better for a few reasons, just making sure the Medium size will fit ok because the small size is built around 26" wheels, not 27.5+
