Brake levers: V-brake and cantilever
Hello
I am restoring a very neglected MTB. The cantilever brakes are in good condition, but the plastic brake levers are brittle.
I can find many levers for V-brakes, but very scarce for cantilevers.
Are they interchangeable?
Thanks
Thanks
Quoted: 4198 Post(s)
Liked 3,851 Times
V/linear pull levers will move more cable to match the amount the higher leverage factor the arms have. Canti/caliper levers pull less cable. In the real world every brand/model can be slightly different in exact length of cable being pulled or needed to be pulled so there can be some overlap between the two camps. But most will say they are not compatible. Not that we don't see it done, just not what a shop should do to their customer. Exceptions do exist. One is to use a device that translates the amount of cable being pulled by the lever to what the brake wants. Problem Solvers made their Travel Agent, a stepped pully design, that's most common these days although out of production IIRC. Other devices used a lever arm with cable attachment points along it to effect different cable movement amounts.
So no to interchangeable is the best and safest word. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1324 Post(s)
Liked 927 Times
Not really and doing so can be hazardous to the rider. Either get cantilever brake levers to go with the cantilever brakes or get V-brake levers and V-brake calipers. I just di that to a mountain bike with drop handlebar. I really liked the bike and wanted better braking than what I could get with the cantilever brakes. It works very well with the Alivio V-brake calipers and the dropbar style Tectro V-brake levers. Braking is so much better now.
Cheers
Cheers
Quoted: 283 Post(s)
Liked 262 Times
I have a MT bike with these. Will work with either canti, v-brake, or mech disk. Good quality.
Tektro Eclipse MT 2.1 levers
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
Cantilevers = short pull: https://www.jensonusa.com/Shimano-R5...d-Brake-Levers -- cheap!
Interestingly, I noticed a DIFFERENT set of flat bar levers that said road brakes (I assume dual pivot calipers), V-brakes, and mech-disc brakes.
Road bike brakes should be short pull. Not sure if that means there's some kind of adjustment built in to make the levers short vs. long pull.
Quoted: 2026 Post(s)
Liked 1,096 Times
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
The adjustment is that knob at under the lever right at the pivot point. That's the idea behind the Avid Speed Dials. It kind of works but a set of short pull cantilever levers do work better. Shimano made some transitional levers long ago that had a block system that could be moved so that the lever could work with both.
Stuart Black
Stuart Black
Quoted: 283 Post(s)
Liked 262 Times
Here's an amazon links to the Tektro's:
Amazon - Tektro Eclipse MT2.1
The funky nut on the cable end of the lever is where you set up the pull.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I use Tektro MT2.1 levers on two of my bikes. They are very easy to adapt to either type of brake.
Quoted: 125 Post(s)
Liked 29 Times
https://bike.shimano.com/en-EU/produ.../BL-R2000.html
Really Old Senior Member
These are an option if you can find them.
You move the plastic "plug" in either/or position depending on brake type.
These are the "4 finger" version.
The 2 finger is V brake only.
Liked 4,213 Times
Additionally, if one were so inclined, many cheap linear brake levers could be converted to short pull levers. They often have a recess where they could be drilled out either short or long pull version. The cable anchor would have to be riveted in place or otherwise attached to the lever blade. This is often more of a hassle than it is worth, however.
Stuart Black
Stuart Black
