Continental Terra Speed 700Cx40 Tires
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Has anyone been riding the Conti Terra Speed 700Cx40 Tires? The online reviews are very good except for the durability. Wondering if anyone here has real-life use experience you can comment on?
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Hate to be that guy, but did you search here?
Mine probably lasted 600 miles in the rear. Can't say it's noticeably faster, but other than wear it was good. There are a lot of alternatives if you aren't mesmerised by numbers. I've used Ramblers, Original G-one allround, GK-SS. other than wear, they are pretty similar. In dry weather I use 36mm GP5000, and that is a crazy fast tire.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Sunshine
Quoted: 11024 Post(s)
Liked 7,568 Times
I've had the Terra Speed for over 2000 miles. Predominantly on gravel rail trails. I looked at them a couple weeks ago and see no reason not to keep rolling them.
Liked 415 Times
yah, I'm pushing the boundaries, but I put the 32mm version on a 29 internal rim, and it measures a bit over 36mm. Its all I ride now in summer/fall (unless its wet and/or rough). It is a lot faster than all my other gravel tires - yet I can handle our summer gravel with ease. It's the best of both worlds and just amazing. Doing 25-30mph in a pace line on the crap asphalt we have around here at 35-40psi - these tires are a lot faster than the guys running 25mm versions of the same tire. Yet, on my way home I can just blast down any gravel road I want with no worries.
I couldn't be happier.
Liked 415 Times
600 miles on mixed hard surfaces (for me, broken chip seal and hard pack dirt) at 200-1000 watts kills the tread life. At 0 watts, they still look fine on the same surfaces. I suspect that running them on softer gravel surfaces would help a lot too.
Quoted: 1424 Post(s)
Liked 1,940 Times
have 700x35 Terra Speed on one bike (pictured)
they appear to run a bit 'small' - 700x35 might be closer to 700x33 *** (?) - so the 700x40 might be around 700x38 (?)
( *** installed on Maddux DC 3.0 hybrid rim with tubes )
The 700x35 Terra Speed (folding, black wall) weighs around 365 g ; the tread part of the tire is not as thick as I hoped - but so far so good
The tire rolls very well on hard surfaces - better than I anticipated given the low-profile knobs
did some dirt road and light trail riding - tire performed fairly well ... 700x40 would prob be better than the 700x35 for these applications
I loved them, but man they burned through the tread in 600 miles for me. mostly trails, some road.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
As mentioned, great tires, but won't last long, that's the tradeoff for a fast gravel tire. I get about 5-600 miles out of a set, but I'm 185lbs and put down pretty good power.
Just put a set on, I can mount them by hand, and they inflate with a floor pump (don't even have to partially seat the bead, they just pump right up), probably the easiest tubeless tires I've mounted.
Quoted: 7053 Post(s)
Liked 11,106 Times
Quoted: 733 Post(s)
Liked 815 Times
More power and speed = more friction, which makes them wear faster. Just like driving a car like grandma versus driving it hard all the time. I was doing 28-30mph in a group ride last week on them (pavement), that's gonna add some wear compared to just riding around easy.
Liked 11,106 Times
Liked 415 Times
On the terraspeed,
0 watts input over 1000 miles = zero wear.
0-1000 watts input, means tire is worn out after ~600 miles.
Doesn't that tell you everything you need to know?
Want more:
I get 1/2 the tread life out of my tandem (rear), with 2x power output.
I get 1/2 the tread life out of my light powered commuter ebike, with 2x power output.
If I just leave the tire on the front alone, I get dry rot before I get tread wear.
Liked 11,106 Times
You are ignoring the other obvious differences between tandems and singles and between ebikes and acoustic bikes. And you still have given no reason why more power would accelerate tire wear. (Note that a mere assertion is not a theory.)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
I'm not sure your analogy holds up. Driving a car aggressively (burnouts, drifting around corners) will obviously wear out tires faster, but riding a road bike faster involves no such additional tire wear. And while higher-speed driving creates more heat and friction on auto tires, I'm not convinced that cycling speeds are anywhere near high enough to create such an effect.
Likes For ThermionicScott:
Liked 11,106 Times
Rear wheels propel the bike forward by friction between the tire and ground. Just because you don't feel your rear tire slipping on the ground doesn't mean that the rubber isn't being scraped away by drive forces. That's why rear tires tend to square off and wear out faster than fronts, and lots of climbing accelerates the effect. Seems reasonable to intuit that applying more power (especially suddenly rather than smoothly) would lead to quicker wear.
Liked 2,571 Times
The more rapid wear on a rear tire is due to the fact that it supports most of the total system mass. And when climbing, even more weight is shifted to the rear wheel. By the same token, chas58 's claim that the rear tire on his tandem wears twice as fast due to 2x power is likely incorrect; it wears faster because it is carrying much more weight.
RUSA #7498
Liked 11,106 Times
There is actual logic behind my argument, since it is indisputable that the rear tire supports well over 50% of the system weight; your (and chas58 's) argument is pure speculation, since neither of you have offered any evidence that power output causes tire wear. (And logic works against your argument, since cycling -- aside from a few track disciplines and the odd TT launch -- doesn't generally involve rapid starts. Even most road races start rather sedately, in my experience, and power is then applied once the wheels are already rolling at a good pace.)
I reckon that rear tires might wear a bit faster due to deceleration, since the rearward weight bias (and many riders' tendency to overuse the rear brake) might cause more skids and near-skids.
Liked 2,571 Times
Unless you've actually done that, you're just speculating.
A rear tire doesn't need to be slipping/skidding for the rubber to wear off due to abrasion, I'm confident that it happens to some extent whenever you apply additional power to accelerate. A front tire, on the other hand, just rolls on the ground unless you're in the process of crashing...
Liked 415 Times
Liked 415 Times
If tire wear were strictly due to load, it should be in proportion to the load. A road bike is usually, what, 40% in front and 60% in rear? Have you ever worn through the tread of a tire that stayed on the front its whole life?
The weigh argument is less relevant. With my tandem, I still get no wear on the front, in spite of the extra load. My ebike is the basically the same weight as my road bike, just with 2x the power output. And yeah, the weigh balance of my road bike is more like 45/55, so weight isn't the overwhelming factor.
