How long should rim brake carbon wheel sets last?
For the weekend warrior type, non competitive rider. How long should these wheels be expected to last as long as they are reputable?
www.mp-aviation.com
www.mp-aviation.com
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times
A very long time, particularly if you don’t do a ton of miles. I had 7,000 miles on my Zipp 303 rim brake Firecrests before I donated that bike to a kid on my high school MTB team. The brake track showed no signs of wear. I chose Zipp at that time (2014) because they had much more stopping power than the Rovals I tried. I believe at this point pretty much every big maker makes a reliable and sturdy brake track. Fear not!
I do have to be a little careful not to let my wheels drop into ruts in the road. That can mar the edge of the rim.
Just like with aluminum wheels, brake track longevity is determined by the hardness of the brake pads and how clean you keep the brake track/pads. If you stay on top of this maintenance, the brake track will last a very, very long time. Also, assuming the wheel has been built correctly, the rim integrity should hold up for a lifetime.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For GlennR:
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Agree they should last a long time. That said, I have a lovely Williams 38 front wheel that hit a stray rock and the crabon cracked. So stuff happens, but if you don't hit something like a rock they should last plenty.
Which ones are you getting???
Likes For noodle soup:
Not worlds apart from using aluminum. If you're riding in clean conditions, its typically basically forever. If you're doing a lot of wet riding and your regional roads are covered in a particularly abrasive grime, it may be relatively short.
On Your Left
Liked 2,433 Times
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
They should last forever - If you never ride them.
All rim brake rims are a wear component. Use and conditions can reduce or accelerate wear.
They last long enough otherwise there'd be 10,000 threads on here about how no one would ever buy them as they always wear out.
I have seen them wear out in customer's hands. Some. Those customers were ....well....riding. A lot usually. More than most people and/or in all conditions and with lots of long descents. Most that I have seen wear out were rim brake cyclocross use carbon with sand and mud braking conditions.
Regular casual road riders like 90% of this forum....never wear out.
Just make sure you have the right pads (ask manufacturer), and keep the system clean-ish between uses. In other words if you ride in a ton of slop them wash off the bike and brakes when you're done. Inspect the pads every few months and see if there is debris in them. Don't use the same pads for you aluminum and carbon. Yes you can sometimes but the alloy will get caught in the pad material and eat the shiz out of the rims.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Quoted: 18883 Post(s)
Liked 10,646 Times
Two or three rides.
Likes For Seattle Forrest:
In my experience, if you're using the right brake pads, keeping them dedicated to carbon rims, and not constantly riding through muck and grit, the life of a carbon rim depends on how long you can go until you crash it into a curb or something like that.
Tubular rims suffer bangs and collisions better than clinchers, in my experience.
Liked 8,925 Times
Yessir! Came with them.
www.mp-aviation.com
www.mp-aviation.com
