Best way to remove deafening screeching sound from vintage rim brakes?
Hi Guys! whats the Best way to remove deafening screeching sound from vintage rim brakes??
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Toe in the shoes. Trailing edge in a millimeter or two. This is accomplished in one of several ways, depending on the type of pad and/or cartridge/holder your pad has. Provide more detail on the rim type, caliper type (brand/model), and the pad or block type. These all factor in.
The old school method with simple bolt-on pads that lack angular adjustment was to bend the aluminum caliper arm ends to accomplish the toe in. Done with a crescent wrench, or alternatively, with a screwdriver prying through the opening in the end of the caliper (pad removed). I wouldn't recommend this for anyone under 55 years old, though.
Alternative factors that can contribute to better braking, but not at all to the chirping: rubber compound selected for the block, rim material (chrome steel versus aluminum, machined braking surface versus smooth), and rim surfaces kept scrupulously clean.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 751 Post(s)
Liked 799 Times
Sigh..so we've reached the point where rim brakes are considered "vintage"..and novel..quaint... while wooden rims are certainly vintage, I hope rim brakes are not..
(..and OP..there's tons of info on the web about adjusting brakes..rim or otherwise..)
I think the OP means they have a vintage bike.
Quoted: 1792 Post(s)
Liked 1,671 Times
Some rim brakes on older bikes are more prone to brake squeal than others. Knowing which ones you have would be helpful if you want useful answers
Quoted: 701 Post(s)
Liked 667 Times
Likes For fietsbob:
Quoted: 3905 Post(s)
Liked 7,181 Times
Likes For tomato coupe:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
Sometimes it's just not going to go away, but try these things:
Toe in your pads, but just slightly
Clean your rims. I use acetone but others use alcohol (which does little IMO)
Resuface your pads by lightly sanding them. Mount the sandpaper on a flat surface.
Change your pads. I like the Kool Stop products.
Rebuild your calipers. Sometimes there is too much play in the center pivot that causes resonance in braking
Check your hubs. Sometimes play in the axle can cause a resonant vibration in your rim when braking (so I've heard).
Not recommended: I heard about a chap who treated his rims with auto body wax. Apparently it reduced the squeal but also reduced his braking performance big time.
Quoted: 325 Post(s)
Liked 109 Times
This sounds backwards. All of the toeing-in advice I ever got was to have the front edge of the pads toed-in a millimeter or two, so that you have more control and it's easier to modulate the braking force. Why would you want the back of the pads to hit first? What would that accomplish?
Klaatu..Verata..Necktie?
Quoted: 10244 Post(s)
Liked 11,597 Times
Zip tie Karen
Liked 1,542 Times
Quoted: 325 Post(s)
Liked 109 Times
OTOH, I could see why having the rear-most edge of the pad contact the rim first might be preferable: it could clear away any debris and effectively clean-off the rim before the rest of the pad makes contact. Has anyone tried this?
Liked 11,597 Times
But the friction with the rim would have the effect of twisting the rest of the pad AWAY from the rim reducing the contact surface, wheres with proper toe-in, the friction twists the pad TOWARD the rim.
Likes For genejockey:
Quoted: 667 Post(s)
Liked 529 Times
Yes, that works wonderfully to make the brakes squeal
Randomhead
Liked 3,664 Times
The squealing on a vintage Mafac brake can be fixed with a few minutes and a small round file. Or you can get these angled washers from Rene Herse
https://www.renehersecycles.com/shop...e-washer-pair/
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times
Exactly...........
Bikes: Cannondale Quick 2
Quoted: 27 Post(s)
Liked 30 Times
Best regards
Cheerfully low end
Quoted: 642 Post(s)
Liked 1,040 Times
Otto
My Mafac brakes still squeal on very humid days. If I lived where total humidity was constant don’t know what could be done. Fortunately around here total humidity is like today when it is so freaking hot not one is riding or it happens a short time early in a.m.
Toeing in, a brake pad, is actually the trailing edge of the brake pad touching first, because the top of the wheel rim is moving forward..
Likes For fietsbob:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
So much time and energy are wasted on these threads featuring no real information from the source like one simple photograph.
Quoted: 6882 Post(s)
Liked 10,873 Times
