Tubular Re-glueing Advice Needed
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
I cut my morning ride short today after about half way through the rear wheel developed a bump with every revolution. I actually thought I broke a spoke. Turns out that the 15 plus year old glue is letting go. As you can see the tire is loose from the rim when deflated. Is this a simple fix? Just re-glue and ride on? Is the tubular stretched or compromised in some way? Any advice is appreciated!
This was my one and only attempt at tubulars and like I said it was 15 plus years ago. I have forgotten what I didn’t even know at this point. Thanks !
Quoted: 159 Post(s)
Liked 375 Times
15 year old glue.
Blamester
If it came off in one spot likely it can do the same in another. Best is remove inspect and then decide what to do.
And if it was me I would do both tyres if they are both on the same length of time.
Quoted: 831 Post(s)
Liked 2,124 Times
Yikes. Definitely time for a complete re-glue.
Also notice the base tape is curling up quite a bit. I'd also be concerned about that base tape detaching from the tire casing. (I had a harrowing experience coming down a long, twisting descent when a vintage Vittoria squadre prof came unglued from the base tape.)
I would remove both tires, check the base tape and re-glue as needed, and then re-glue the tires to the wheels.
Nice rims. Mavic Or 10?
EDIT: Are those Vittoria Ralley tubs? Looks like a non-removable valve. If so, might just be better off investing in a tire upgrade.
Quoted: 809 Post(s)
Liked 1,022 Times
Thanks for the clear pictures.
I am a little concerned for embankmentlb . While re-gluing the tire to the rim is the right thing to do, I also see that the glue that holds the, what do we call it, covering tape, is also getting old, This also is looking like it is loosing it's grip.
The tire is connected to the rim through this covering tape, so if the adhesive on either side of this tape is no longer holding, the tire is not connected to the rim.
The other thing that has me concerned is that tubulars are usually a tight fit on the rim when inflated. You don't actually need glue to hold them on. If you had a wall hanger bike, glue would not be required for the tubular to stay on the rim. When you are going to ride the bike, the glue and the fit become critical to your safety. The picture looks like the overall diameter of the tire has increased and no longer has the same fit to the rim that it had when it was new or even 8 year old.
While the sidewall and tread look good, I think the tire needs to be replaced. They served you well.
Likes For Velo Mule:
Quoted: 159 Post(s)
Liked 375 Times
Likes For embankmentlb:
Quoted: 159 Post(s)
Liked 375 Times
Thank you for all advice! The glue has just turned to a power. I am concerned about the tire not being snug to the rim.
l will probably re-glue both tires but replace the rear with my spare.
What glue do you recommend?
Quoted: 1639 Post(s)
Liked 829 Times
I like Continental's tubular tire glue much better than Vittoria's Mastik.
It has just the perfect viscosity for me for easier and cleaner applications.
I also always seem to not need as much of the Continental glue than the Vittirua Mastik to get a good, secure install.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 1607 Post(s)
Liked 2,216 Times
Kinda like picking your poison. Unless you have a set method of applying, it can get messy regardless of the choice. I like to use the latex gloves and apply with my finger. Other use a brush, disposable btw.
Check out totally tubular thread nearly at the top of the opening of C&V.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Do not try to use those cheap disposable clear plastic food prep gloves, though. The Mastic will stick to those like glue.
Quoted: 1947 Post(s)
Liked 2,010 Times
You can't glue those tires back on. If there is daylight between rim and tire when the tires are mounted, toss them.
Glue and a baggie if your using tubes of glue.
Quoted: 3464 Post(s)
Liked 2,828 Times
often it is just the edges that let go but test, don’t guess.
the tire does look “loose” - actually that is a concern too, tubulars do stretch- perhaps the riding with dying glue has done mischief too
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
I can't even imagine what makes a tire do that. Are you sure your rim is still good and round?
And yeah, your base tape is bad, that's usually an indication the tire should be tossed.
Quoted: 1856 Post(s)
Liked 664 Times
For rim cementing, you can use Velox tape, Tufo tape, that Cafe Espresso (sounds similar) brand, or ... maybe there's another one? I like Veloflex tape. I used to use Mastic glue.
Time for new tires and new glue. Toast. Burnt toast. Cotton tires? They don't last for years. Tires should be snug fitting with no glue at all.
If I own it, I ride it
Quoted: 591 Post(s)
Liked 662 Times
^^^ This. Particularly the fit should be snug inflated or not.
Quoted: 159 Post(s)
Liked 375 Times
I will do some more inspecting over the weekend to see just how loose the tire actually is. I feel pretty lucky that I decided to cut my ride short.
Liked 2,010 Times
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Let me know if you need help. I have glued exactly 1 set of tubulars and it went well :-)
Quoted: 159 Post(s)
Liked 375 Times
Thanks to everyone for their helpful information.
I re-glued both front and rear tires. The old glue had turned basically to powder.
Their was really nothing holding the tires to the rim other than air pressure.
With some air the tires fit snuggly to the rim. All is good! Check those tires that were glued many years ago. They may need attention!
