Daily switching between SRAM ETap and Shimano
Quoted: 16 Post(s)
I have always had bikes with Shimano gearing. Currently looking at a bike with SRAM ETAP AXS. I am sure I would get used to ETAP if it was my only bike. But is it confusing to switch from Shimano to SRAM ETap every few rides? Anyone with experience doing this?
I have a stable that includes STI, bar-end friction, and even a bike with downtube friction shifters. Right now I can hop on any of them without having to acclimate in any major way to the feel of the shifting.
The stable you're contemplating is far less problematic than mine. A lot of people can hop on an unfamiliar integrated-shifting system for the first time, and largely get used to it within a matter of minutes. That's especially true for e-shifting, where your hand technique plays literally zero role in the derailleur actuation. Even if you have a harder time with it, and switching feels a bit strange at first, you can acclimate to acclimation: the more you do it, the less you'll notice the switch. It's very unlikely that you'll have trouble after a few switch cycles.
Quoted: 1743 Post(s)
Liked 1,281 Times
My Guru runs SRAM Red mechanical and my CAAD 12 runs 105. I am constantly switching between bikes. You get used to it. Not a big problem.
As with other responders, I regularly alternate between mechanical SRAM Red and Force, Shimano Ultegra and 105 and SRAM Red etap. After the first 100 meters up the road from my house, muscle memory kicks in and adaptation is automatic. Only very rarely will I miss a shift, having momentarily confused which group set I am operating. No problemo.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Either adapt, or reprogram Di2 to have paddle shifting--which you can do.
Likes For dmanders:
Quoted: 83 Post(s)
Liked 157 Times
After a few years with Campagnolo I got a bike with Shimano. At first Shimano interface was weird but then I got accustomed. Every few weeks I change to the other bike and muscle memory works fine.
Bikes: 2021 Trek Domane SLR 7, 2012 Giant Defy 0, 2012 Trek Domane 6.2 P1, Bianchi Infinito CV disc Di2
Quoted: 212 Post(s)
Liked 1,000 Times
Also contemplating as I run four bikes with Di2 and thinking SRAM Red eTAP, but no experience.
Top buttons for shifting Di2 are, IMO, a joke and harder to access and use than the paddles. Also, newer Di2 locks you out of two gears, so it’s still a 20 speed, LOL! LBS said it can’t be overridden.
Ride hard and ride on......
Liked 406 Times
Likes For Marcus_Ti:
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
I switch between Shimano, Campagnolo and SRAM eTap AXS all the time. It's not confusing at all. I just have to be more aware of which bike I'm riding. I mean "aware" in that Zen Buddhist kind of way.
Quoted: 6970 Post(s)
Liked 10,967 Times
The only problem I have in switching between bikes is when I haven't been on my SS for a while. As I hit the first hill coming out of my neighborhood, I will sometimes start banging on the brake lever, trying to get it into a lower gear.
In switching between Sram 1x, etap, and a Shimano Di2 TT, 2x mech - it takes a few shifts to have that memory recall. Then only afterwards it’s only during big effort moments when your concentration lapses for a split second do I ever misfire. So I’ll say 99% not an issue but when it happens I definitely pay for it, like accidentally switching to the big gear going up a steep hill.
It's going to depend on the individual. Some, maybe most, will adapt to using the two systems without issues. Others will have trouble with going back and forth. I would likely be the latter. If you're like me, and occasionally, when thinking about other stuff, use the wrong lever to shift the rear, you might struggle with using two systems. This is after 5 years of solely using Di2. I did test ride SRAM etap for a second bike and didn't have an issue with it while focusing, but know going back and forth could be a issue. Besides SRAM's double tap wasn't going to work for me.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1253 Post(s)
Liked 1,286 Times
I've currently got 3 bikes at home, with not just 3 different gruppos but 3 different gruppos that each have a different shifting paradigm:
- Campy Record (thumb lever moves chain to smaller ring/sprocket, blade lever moves chain to larger ring/sprocket)
- Shimano 105 (blade lever moves chain to smaller ring/sprocket, brake lever moves chain to larger ring/sprocket)
- SRAM eTap (right blade lever moves chain to smaller sprocket, left blade lever moves chain to larger sprocket, both blade levers simultaneously swaps chainrings)
Yes, you do get used to it ...after a few seconds. There's always that moment when I'm about to make that first shift where my brain goes "Ack! What bike am I on? Oh yeah..."
And I'm not gonna lie: I probably biff a shift once every ride or two specifically because I was expecting the wrong paradigm.
But that's not a good enough reason to stick with only one brand.
Quoted: 83 Post(s)
Liked 157 Times
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
I will jump into this discussion. I use Campy Ergo on my road bikes and Sram on my gravel bike. The ergonomics of the hoods are very close. However, the Sram sweep style shifting vs the Campy brifter and thumb button are completely different and when I am on the gravel bike, I invariably miss shifts and find that I miss the Campy down shift motion and up shift motion of multiple gears at the same time, etc. So yea, you do naturally adapt but it is not the same... Personally I have never liked the Shimano big lever / small lever design. My wife has Ultegra 10 speed on her road bike and when I take it out for a test ride after some work on the bike, I have to wonder why so many people like this setup. Slower to shift, not as clean feeling, and well, dare I say - sloppy design.
Quoted: 551 Post(s)
Liked 277 Times
You'll adapt rather quickly. I know I did.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Back in the day I rode and raced on a SRAM rig, commuted on a Campy rig, and did cross using Shimano.
The transition was always funny but went away within a handful of shifts.
Campy one was always the funniest as I would be coming off of it and going for the invisible thumbs shifter while flying downhill on a cross bike.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
