Go Back  Bike Forums > Bike Forums > Fitting Your Bike
What "size" is my full-suspension bike?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 09-14-20, 11:52 AM
hobkirk
Retired dabbler
hobkirk's Avatar
Location: Acton, MA (20 miles west of Boston) - GORGEOUS cycling territory!
Bikes: 2007 Specialized Roubaix Elite Triple - 1st ride = century 9/19/2010 , Ultegra
Quoted: 46 Post(s)
I've read there is a rule of thumb for finding if a bike fits -
  1. sit on bike and inseam should be 2" off ground (or, you are just able to stand on your tippy toes!)
I bought a full suspension bike at a garage sale years ago. I've ridden it twice. I had the saddle fairly high (I am 6' 1" tall). But, as far as I can tell, the bike is too big for me - the seat in its lowest position is 36" (I have a 30" inseam). So, I need help so I can figure out how to sell this to someone it will fit.
This is the full bike:
Here is the seat in it's lowest position (highest = 43"):
And the imprints on the bottom bracket, in case they are useful:
hobkirk is offline
Old 09-14-20, 12:18 PM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,779 Times in 3,297 Posts
Few bikes I ever saw listed on craigslist and elsewhere listed a size. Maybe just measure the seat tube, the max saddle height, effective top tube length and stack. Pic's of each with tape measure might help.
Few buyers will probably know what to do with that though. So don't sweat it.
Iride01 is offline
Old 09-14-20, 08:16 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
"size" is seat tube length up from center axis of the BB..
fietsbob is offline
Old 09-16-20, 07:09 AM
AnthonyG
AnthonyG's Avatar
Quoted: 3450 Post(s)
Liked 420 Times in 289 Posts
Take a horizontal line from the top of the head tube/headset to where it intersects with the seatpost. Then measure from this point down to the centre of the bottom bracket. This will be the nominal size of this frame in inches/centimetres.
For the record, I don't believe that this bike is too big for you, based on how much seatpost you have exposed, but if you want to sell it then sell it.
AnthonyG is offline
Likes For AnthonyG:
Old 09-16-20, 01:00 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
6ft 1inch.... 30 inch inseam....Huh?
trailangel is offline
Old 09-18-20, 09:44 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
You should not be able to reach the ground while seated. I an 5'8" and my bike saddles are around 38" high if measured from the ground. You should be able to get full leg extension while pedaling seated. You slide off the saddle to reach the ground when stopping. Looking at the headtube and guessing that that bike should be pretty close for you.
c_m_shooter is offline
Old 09-18-20, 01:18 PM
mack_turtle
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times in 273 Posts
utter nonsense. that has nothing to do with a bike's size or how it fits you.
if you're going to talk about inseam, you need cycling inseam or actual inseam, not your pants size. look that up. how high is the bottom of your pelvis from the ground when standing in your bare feet. that's a start. I am 5'9" with average proportions and my actual inseam is about 34". my legs might be just a tad on the long size for my heigh. if you're 6' tall with a 30" actual inseam, you might have an undiagnosed medical disorder.
most bicycles have a sticker on the seat tube of the frame that states the frame size. at 6' tall, you should be on a 19-21" frame.
unrelated—that chain needs more than oil. it needs to be replaced. it's way beyond maintenance now.
mack_turtle is offline
