New Build - RestoMod Schwinn
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Some sort of late 80s/early 90s LeTour sporting 3x7 Accushift. This is for a friend of my daughter's, for that girl's fiancee for Christmas.
It'll be upgraded to MicroShift STI, with new consumables throughout.
QUESTION: Will a Deore LX FD-M550 (front triple) shift with a road STI shifter? I'm thinking yes. Tell me if I'm wrong. Thanks.
Likes For Phil_gretz:
Zip tie Karen
Liked 1,542 Times
I will keep the Blaze calipers on it.
Zip tie Karen
Liked 1,542 Times
The Accushift stuff will go into the parts bin. It apoears to be indexing correctly, though.
Quoted: 405 Post(s)
Liked 430 Times
Unless Microshift makes a road shifter for MTB front derailleurs, you'll need a road triple front. Shimano index-compatible road and MTB front derailleurs have different actuation ratios.
--Shannon
--Shannon
Likes For ShannonM:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 707 Times
Jeff Wills
Jeff Wills
Zip tie Karen
Liked 1,542 Times
Thanks for the feedback, guys. I did vaguely recall something like this. I've gone with a MicroShift branded front road triple that will work with the shifters. Phil
I have a "newer" (late 90s) Schwinn LeTour and it's one of my favorite bike to ride! Mine is 2 x 7 with the Blaze / Accushift group. Mine seems to work fine and I have no intention of upgrading any components. I usually have it switched to the "friction" mode but the indexing does work!
Your daughter's friend's fiancé will be getting a nice bike!
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I would have used 7s Command shifters on this one I think, but not everyone likes the old aero brake levers and the Command shifters are few and far between these days.
Believe it or not, I have used road triple STI levers with old Deore triple front derailers (resto-modding a couple of 1980's Trek aluminum bikes), but it required that the cable be anchored differently at the pinch bolt. I don't recommend it though, because on one of the bikes there was a pronounced tendency for the downshift from the big ring to drop straight to the granny ring as the internal ratchet apparently couldn't move fast enough to catch the middle-ring position with the added tension caused by the re-wired cable attachment. Perhaps the one bike had too smooth of a cable/housing to moderate the aggressive return force of the re-wired Deore mech, or perhaps the faulty one somehow incurred more return-spring force(?).
Levers were RSX STI 7s in all cases, one setup worked well enough and the other one didn't. I lubed the heck out of the afflicted bike's shifter, even replaced it eventually, but to no avail.
