Anyone recognize this threadless steerer extender?
Quoted: 1163 Post(s)
Liked 442 Times
I don’t think it is a Nitto or a Cinelli. Sorry, this is about all I can do is help rule out what brand it isn’t.
Quoted: 569 Post(s)
Liked 581 Times
Not at all sure but sorta looks like a vintage BBB that passed through my shop a few years back.
Quoted: 8 Post(s)
I bought one a couple years ago. Seemed like they were no longer being made as I had to search all over for a 1 1/8 size. I'll post again if I can find anything.
Quoted: 2026 Post(s)
Liked 1,096 Times
https://www.nashbar.com/dimension-1-quill-to-11-8-threadless-steerer-adaptor-spt-22-blk-22.2-50mm/p322409
https://www.nashbar.com/forte-thread...il-118/p920937
two sizes:
https://bbbcycling.com/en_en/bhp-21-extender
https://bbbcycling.com/en_en/bhp-20-extender
Branded BBB. (Bike Parts, For Bikers, By Bikers) Primarily a European based company.
Thanks.
Quoted: 8 Post(s)
I used it to extend the fork in my sons bike. It started to feel like the headset was loose after a year or so and I cant get that to go away. I had to turn it down a little on a lathe to fit the aluminium steer tube but fit solid.
Yes, there is no star nut and top cap bolt to preload the bearings so I can see why it could be a bit loose. If you ever tried to get a threadless headset bearing adjustment right without a the top cap bolt, it can be a challenge. I'll be installing it this weekend at the local coop on a kids bike (Specialized Hot Rock hybrid) and well see how it goes. One technique is to use a loop of rope under the crown and over the stem, then tighten ala tourniquet style to put some pressure on the bearings before tightening the stem.
Quoted: 8 Post(s)
I think that the bolt that tightens the quill wedge is threaded inside the hex key opening so you can preload the headset. The issue I have is that the quill is made one diameter but the inside of head tubes varies considerably.
