Am I the dinosaur?
#76
Quoted: 18883 Post(s)
Liked 10,646 Times
That means no running because lighter shoes are less pendulum weight, and no running rules most non motor sports out. Obviously not cycling because EPO isn't free. No Nordic skiing either. Or paddle sports. What's left?
#77
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Likes For Sy Reene:
#78
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#79
Disc in Rear/Caliper in Front Makes Sense For Touring
Okay.....call me old and out of touch. I would probably agree to a point. But when I look at new bikes online the push seems to be either pure road bikes migrating to disc brakes (hydraulic or mechanical) as the almost only option. I still love my caliper brakes due to simple simplicity.
So the dinosaur I seem to be, do you feel the eventual path is to certainly extinct the caliper concept?
#80
Likes For Steeler_fanatic:
#82
I live 400 yards from the Atlantic Ocean in the salt air, which rusts steel parts unless they're Marine Grade. I've found that the tiddly bits surrounding disc brakes rust easily and require constant looking after. Since we have no hills on the east cost of Florida, I prefer rim brakes.
#83
Bikes: Specialized Roubaix Elite, Felt Cafe, Specailized Enduro Comp
Am I the dinosaur
Newby here.
I read the threads on disc vs. rim brakes, Do, I am not going to repeat the common pros and cons already discussed extensively. However, have not come across any mention of this distinct advantage of disc brakes on bicycles:
The disc wheels can tolerate quite a bit of out of round and side-to-side warping of the rim!
I discovered this on the Pacific Coast tour from Canada to Mexico, when the chain jumped the large cog (missing limit screw) into the wheel and broke 3 spikes on the drive side. The rim was weaving almost +/- 1/4” side to side. But, I managed to limp carefully for 25 miles to a bike shop to have the wheel fixed.
So, I am sold for disc brakes. BTW, Regardless of how stupid it looked, I put back the protective plastic disc next to the cassette after this incident.
Likes For tang1223:
#84
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
And yes, I do stock up on components I like or have if it appears they are falling out of popularity. I did it with French freewheels, cloth bar tape, Velox handlkebar plugs, and leather straps, and I am doing it with cantilever parts, especially spare Shimano straddle wire sets. I am not a buy a new bike to get a new brake set type of rider or consumer, if the one I have meets my needs.
#85
Quoted: 215 Post(s)
Liked 204 Times
Not totally but many bikes are only available in disc. Even cheap bikes have disc, mechanical cable.
Remember when front disc brakes were an option on cars? Then only sports cars had 4 wheel disc.Now every car has front disc and most have real also.
BTW.. nothing wrong with rim brakes, but they are not best suited for every situation. My "winter - foul weather" bike has hydro disc for better braking in the wet.
#86
ChristopherL
Bikes: '62 Peugeot PA 10, '73 Peugeot UO8, '74 Peugeot UE8 (converted to UO8 look alike), '75 Peugeot UO8, Peugeot Ventoux PH501, '7? Sekine SHS 271, '89 Centurion Ironman Master, '86 Centurion Elite RS, '87 Centurion Ironman Master
Quoted: 13 Post(s)
Liked 7 Times
short arms? hmmmm.....took me awhile.
#87
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 165 Times
Progress marches on. Depending on the era your bike should have the best available at the time with effective modern pads. I don’t ride hard anymore, but my townie/cargo bike has discs. My vintage stuff all has calipers/rim brakes.
Cheers
Cheers
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
#88
Quoted: 4717 Post(s)
Liked 1,882 Times
Newby here.
#89
Under most circumstances discs work better. That said, i spend a lot of time commuting in snow, slush, and slop. So, in the winter, i actually prefer rim brakes (v brakes) because if they’re simple and reliable. In the slop, discs constantly squeal and need daily attention. Rim brakes just work. A quick swipe of the rims after each ride keeps them happy. For anything else, i discs are far superior—except for changing wheels quickly.
#90
Quoted: 850 Post(s)
Liked 344 Times
Carbon clinchers becoming cheaper and more common makes disc brakes a must-have safety issue. I have a set of carbon clinchers with rim brakes and it absolutely sucks compared to alloy. I don’t think this is a controversial take. Most people will agree that carbon rim brakes are terrible and not a good solution. If you’re talking braking in the rain, carbon rim brakes are not even in the same ballpark as discs. Especially when it comes to ease of modulation. I don’t want to lock up my front wheel because I grabbed a fistful of brake, only for it to suddenly bite after 1 whole second of clearing water.
#91
Advocatus Diaboli
Liked 1,531 Times
#92
padawan
I'm with you buddy. I have three road bikes with rim brakes and have no plans to change. They're simple and easy to adjust and satisfy my braking needs. I also live in SW Florida where it's totally flat.
#93
I’ll stick with the simplicity of rim brakes too, and I live in the mountains with long descents. Never needed more braking and never heated a rim too much. As for the wide tire argument, there are good options for long reach wide clearance calipers.
#94
#95
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I have three different pairs of carbon wheels and two pairs of AL wheels. I'll have rim brakes for as long as I can imagine. They all work well.
#96
Quoted: 167 Post(s)
Liked 291 Times
My Wilier has rim brakes, they have served me well and all I've known on road bikes since the 1980's and I prefer them aesthetically. However, racing MTB I realised I much prefer disc on that bike since the stopping power is tangibly better off-road.
Now, I live in a warm place, a tourist mecca for beaches and Sun. I seldom ride in the wet since I can simply go to Zwift for the few days a year I would experience rain. However, going downhill at 70-100km/h in races, club rides or just training alone, there is a place for a braking system that is better. But...a well-matched rim brake to a good aluminium hoop will do just as well as a disc braked bike in the dry. GCN online demonstrated this only recently in one of their videos. A carbon wheel however, is a slightly different story. My Sram Red brakes and Zipp 303's do stop me but not quite as well as my previous aluminium Mavic wheels did.
My soon-to-arrive aero bike has discs. I've opted for them because I will then have both systems and therefore a choice. Also, from a purely aesthetic stance again, I find them less of an issue for me on aero bikes than that of a climbing bike.
