Specialized Globe Centrum-Rebuild/Modify
Theflatbarguy!
Bikes: Custom Giant Anyroad Flatbar, Custom Raw Steel Raleigh XXIX SS
Quoted: 40 Post(s)
So here is my latest build. It started out life innocently enough as a 2008 Specialized Globe Centrum single speed. These are cool bikes as they came from the factory but with entry level components like cable actuated disc brakes, square taper bottom bracket/heavy crank, heavy wheels, heavy handlebar, and heavy stem they are just begging to be upgraded. Lol.
When I purchased the bike it had seen some use. There were lots of areas with cable rub (through the paint) and the components had seen better days. Fortunately, I purchased the bike specifically for the purpose of upgrading/rebuilding it.
Here is the (almost) end result. All I have left to do is purchase/install a matching FSA carbon seatpost and shorten the brake lines. It's running a 1x9 drivetrain.
Let me know what you think.
Here are the details:
Completely stripped and repainted the frame with Dupont "Hot Rod Black" Semi-matte paint w/black "ghost" decals
Avid HSX heat shedding rotors 160mm/140mm
XT Hydraulic disc brakes
XT shifter
XT rear derailleur
XT cassette
XT chain
Specialized Toupe Sport saddle
Specialized BG Contour XC grips
FSA K-Force UD carbon handlebar
FSA K-Force UD Carbon stem (80mm)
FSA SL-K Light UD Carbon crank w/ceramic BB
DT Swiss Axis 2.0 Disc wheelset
Specialized Borough XC 32c tires
Jagwire shifter cable
Sorry for the quick and dirty photos.
XT shifter
XT rear derailleur
XT cassette
XT chain
Theflatbarguy!
Quoted: 40 Post(s)
This is really impressive thanks for posting. I'm sure I'm asking something I shouldn't, but would it be possible to fit 2 chain rings on the crank? I've got a long comute and there is a Globe going for $250....
Theflatbarguy!
Quoted: 40 Post(s)
This is the Centrum model and it came as a single speed. I added the dropouts to convert it to multi in the rear and I'm sure if you added a cable guide on the bottom of the BB housing you could install a front derailleur and a double crank.
aka Phil Jungels
You did a very nice job; but, it's a little swoopy for me.......
Theflatbarguy!
Quoted: 40 Post(s)
If you have the same bike you can use part numbers 9898-4240 and 9898-4245. Here is a link to the Specialized Hanger fit guide.
https://service.specialized.com/colla..._hangerfit.pdf
Theflatbarguy!
Quoted: 40 Post(s)
Are you planning on running a double in the front? If so, you'll also need a cable guide on the bottom of the bottom bracket housing. You'll need one with a built in cable stop because there are no cable stops on that frame. So you'll need to run a shifter cable all the way from the rear shifter to the rear derailleur. You can either just wire tie the cable to the frame (which looks like crap) or you can order some cable clamps like these:
10 Pcs 1 8 1 4 3 8 1 2 3 4 1 in Black Nylon Cable Hose Tubing Pipe Wire Clamps | eBay
I've found your Centrum via Google. Really nice!
I have one myself and would like to upgrade to a single speed 29" or 700c disc brake wheel set. Right now it is 26" 3-speed.
The bike is originally designed for 26" but has a lot of tire clearance.
How is the clearance holding up?
Did you had to make any adjustments?
How is the geometry/handling of the bike with the 700c wheels?
Theflatbarguy!
Quoted: 40 Post(s)
I've build a few of these over the past few years and I haven't had any issues with tire clearance. Obviously there is a limit to what size tires you can mount because it was designed as a 26" wheeled bike but I've experienced no issues and it actually handles better than with the 26" wheels.
Theflatbarguy!
Quoted: 40 Post(s)
The 38t is perfect. I have an 11-34 on the rear now so it gives me plenty of range.
Although it really doesn't much matter because I haven't rode it much (at all) since building my Carbon Sirrus.
Here's a link in case you missed it.
https://www.bikeforums.net/hybrid-bic...ds-v2-0-a.html
Theflatbarguy!
Quoted: 40 Post(s)
Hey Guys,
Here is the bike in it's current state. I removed a few of the components to use on another bike and used some of the components from my new Sirrus Expert disc carbon to put it back together. I'm not sure if this is allowed here or not but I wanted to mention that is is now for sale. Everything is brand new on the bike save for the frame, fork, and seatpost. I'm selling it because now that I have my Sirrus I really don't need two hybrids. This is an awesome bike and has some very nice components on it. Let me know if you are interested.
Please note that the shifter cable for the rear derailleur isn't installed in these photos but the bike does come complete.
Wow, nice build. I've also modified mine quite a bit. I had it as a 700c/29er, but the bike was too tall to put my foot down at stoplights, so I added a Specialized CommandPost dropper seatpost. After riding it that way for a while, I swapped the wheels out for a 650b set with 35c Michelin tires which ride great and feel much more stable than the 23c ones I had on the 700c wheelset.
But what I am most interested in is where you ordered your dropouts from. I suspected this was a possible mod, but could never find the correct dropouts for this frame. Thank you for the part numbers!
Is there a dealer stateside that has them? TIA.
Edit: BTW, since the Centrum already has the non-driveside dropout, I only need to order the right side dropout, correct? TIA
Update: I managed to find the part on eBay through a seller in Australia. The seller agreed to ship it by postal service which reduced the total part cost to about $20 USD. My local Specialized dealer couldn't find the part number at all in their database, and told me the dropout typically costs about $35(!). Anyway, I got the part in a few weeks and it's a perfect fit.
Bikes: Giant Anyroad 2
Looks like giant liked that frame design. The Anyroad from Giant looks a great deal like that Spesh
I agree, they do share similar designs. Now I'm intrigued to see what the Centrum would be like with drops. I'll compare the geometry with the Anyroad and if I do a conversion I'll pop back on this thread...
https://www.specialized.nl/OA_MEDIA/p...cs_rev2013.pdf
28" wheels
Hey TS, sexy built on that Globe, planning to do smth similar to mine.
Tell me, would 100x15 front hub and 142x12 rear hub wheels fit on the Globe San Francisco I got?
Have a nice one!
Have a nice one!
Your Centrum looks lovely :-)
Am going to turn mine into a 7 speed and would love to be able to see your photos.
Are they available anywhere else as it looks like your photobucket account has expired?
Many thanks
Many thanks
Hi there..I have a Globe Centrum comp 2008.And i'm trying to convert my 26" to 650b.Is it ok?It still has a plenty of room for the 650b.But what is the cons if i do the change..Thank you guys..
I had upgrade some parts
Shimano Alfine 45T
Halflink chains
Shimano Alfine front dynamo hub
Shimano XTR rotor
Shimano Alfine Brakes
Spanninga Kendo dynamo lamp
picture in my IG account @arie_widiawan
Shimano Alfine 45T
Halflink chains
Shimano XTR rotor
ive just found this thread while searching for the Globe recall... I rode mine for a few years and then its just sat in a 1/2 deconstructed state for a while.
seeing this build has given me some ideas to get it to where I originally thought it would be when I rode it home. immediately I wanted to add a shorter stem and some mountain downhill styler riser bars to it, and now seeing the 29er bits I'd love to add that and some more gears to my rear wheel. I bought the San Francisco model initially, so it has the internal geared hub, which I meant to regar but never got around to.
wondering if I could pick your bran about what direction to take this.
thanks.
thanks.
