Light Bicycle Wheels
#851
Ordered a set of the WR38's the other day for my gravel build. I went with the Novatec hubs because I've heard great things (except for the bearings if you ride in the rain; which I don't). Can't wait to get the bike built and mount them up. Should be a sweet set up for sure.
#852
Quoted: 850 Post(s)
Liked 344 Times
Picture 1 is damage to the rim/brake track. I’m not sure exactly how it happened, but judging by the damage to the tire, I assume it must have been a few rocks that I hit at just the wrong angle? It’s definitely not pinch damage because I’ve been running this tire very hard. Do you guys think it’s cause for a new rim, or at least a professional inspection? If this really happened because of some rocks, then maybe 25mm tires on these rims really isn’t practical.
Picture 2 is a random cosmetic defect that I just noticed. Part of me thinks it might be sealant that seeped into the paint? But I had sealant all over the rim and that’s the only spot where anything happened. It also looks too... uniform.
#853
Quoted: 4717 Post(s)
Liked 1,882 Times
It looks like it was from some rock impacts, because the tire is also scuffed up a bit in the same area.
#854
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
That kinda damage IMO is somewhat related to the 'new' 105% rule
#855
someone took their 25mm tire for a gravel ride, stick to pavement with those tire / wheel combo. Even with 38mm tire on 24mm rim combo, i still get rock strikes to the rim. The places I was going probably required 42mm+
#856
Quoted: 850 Post(s)
Liked 344 Times
Why... would you assume that? I’m smart enough to realize that the rim is far more exposed to rocks. I also actively swerve around pebbles when I have the luxury to do so. Sometimes I don’t. I did have a bit of a run-in with a bridge the other day so I can’t say for 100% sure that this was caused by rocks. I’m going to assume it was the bridge and hope that no further damage occurs. If I keep seeing new chips show up, though, I’ll update the thread.
#857
Wow, just stumbled upon this thread. These look fab.
An i9 Torch/ AR36 Disc build for that price is just what the Dr. ordered for a Teammachine SLR01 Disc build i have in the works over winter. To think i almost went with a Hunt set with a Novatec hub for nearly same price...
Anyone experience any flex in these shallower options?
#859
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I didn't, but that was earlier this year, not sure if it changed after the new rules went into effect in June.
Likes For Rides4Beer:
#860
Liked 1,882 Times
#868
Quoted: 11 Post(s)
cheers
#869
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
i am using 25c after asking light bicycle. They told me that 25c has the best aero with the AR46. Clincher lol after reading some horror article from forum like you need to replace sealant after 6 months. And white fluid spreading everywhere if you have a puncture. What do you think? How about you?
cheers
cheers
Likes For robbyville:
#870
Quoted: 11 Post(s)
really?! how about every 6 months to clean and redo the sealant ? easy to clean the old sealant?
which are the best tubeless tire? i am looking at conti 5000 TL. should i get the 28c or 25c? i know 28c definitely more comfortable.
Likes For iwing88:
#871
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Be warned...the GP5K are known to be very tight fitting tires. Lots of tubeless options out there in all sizes.
#873
Quoted: 20810 Post(s)
Liked 9,456 Times
When it comes to tubeless, there's definitely a trade-off. If you're not getting frequent flats, I'd recommend sticking with tubes. If you are getting frequent flats, and if you can trust yourself to do some minor maintenance, then tubeless starts to make a lot of sense.
#875
Quoted: 429 Post(s)
Liked 248 Times
I remove the core, shake my sealant and put about an ounce or more using the supplied tube (see pics). I put the core back in and pump up the tire. The entire process takes less than a minute or two for both tires.
Ive used a lot of tires and the GP5000 is certainly the longest lasting I’ve had, but as mentioned can be a little tough in mounting technique for the first timer. I’ve had great success with the Schwalbe Pro One’s (TL Easy), super easy to put on but may need a compressor to seat. Lots of great options out there!
