Thinking of bmx bars on my kilo WT
I threw some BMX bars on a mountain bike that previously had old school super long stem and straight bars. Did it more for goofing around and to have a giant BMX bike, but actually put some miles on it cruising around and it's not bad at all.
Threadless BMX stems are standard 1-1/8" steerer tube clamp, so no problem there. BMX stems and bars are generally 22.2mm, or 7/8ths clamp diameter. Although I think some 25.4mm stuff is floating around now. You will likely need a new 22.2mm stem to match whatever bars you get, if only because you need some serious BMX stem clamping action to keep 10" tall bars from tipping forward or back.
Also they are available is almost any rise from 5" to 11" or so. Dans comp is the gold standard of online BMX shops: https://www.danscomp.com/
Quoted: 92 Post(s)
Liked 12 Times
Just to add to the solid info you've already received, keep in mind that BMX stems are short --- 60mm is about as long as they get, but 48 or 52 is more common -- so factor in the effect this will have on your reach.
As far as handlebar rise goes, you might be surprised at how high even a 6" cruiser bar will place your hands. If you're looking for lowboys, Fairdale's MX bar is 4", and Surly's Sunrise bar is 3.25". Also keep in mind that BMX stems can be top-load or front-load, and your choice will slightly influence the effective bar height.
I know origin8 makes a BMX style stem that fits riser bars so you could get that stem and I would suggest BMX racing bars because they're lighter and shorter. Danscomp.com sells them. Also if you're using it in the winter I would suggest lock-on grips. Odi and lizard skins make great ones.
Set up with a freewheel and road drops with front/rear brakes atm but I was thinking of throwing on some bmx bars and gearing it low with a fixed cog for the winter. Basically turn it into an even lower maintenance comfortable cruiser for the cold ****ty weather. Anyone ever ride a setup like this? Whadya think?
Do I need a bmx specific stem if I’m using bmx bars and will said stem fit my fork steerer without issues? thanks.
Quoted: 92 Post(s)
Liked 12 Times
BMXers and dirt jumpers have been putting bars and stems through every kind of impact you can imagine for years and years. With the proper clamp fit and torque, BMX bars are as stable as any other.
You should be fine, I wreaked havoc on a beach cruiser with riser bars and a 1 bolt clamp off and on for like a year. I never slipped the bars, I would just check them here and there.
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
Speaking of the topic anyone know of any good manufacturers of BMX bars that make them in North 'Merica (you know Canadia or Mexi Co. or the Yooknighted Shash)?
