What's that shifter called?
Quoted: 4722 Post(s)
Liked 3,036 Times
Bottom bracket come from old British bicycle terminology. In engineering terms, a bracket is simply a mechanical device to join to two pieces, typically at an angle. What we call lugs, the British used to call brackets. So, the bracket at the bottom of the frame became the bottom bracket. That definition was misconstrued and applied to bearing movement, so we know differentiate between a bottom bracket and a bottom bracket shell.
Clipless pedals refers to pedals that have a shoe retention system that does nor use toe clips and cleats. They are clipless, in that they do not use toe clips. Toe clipless pedals would be more accurate but people have gotten lazy.
The misnomer that is my personal pet peeve is the clincher tyre. When pneumatic tyres became popular during the 1890s there were four major types; the single tube, the double tube, the clincher and the wired-on. What to-day are called clinchers, used to be called wired-on. The two are similar but incompatible. Both use beads to hold the tyre to the rim but clinchers have a very large, all rubber bead that fits under a very prominent lip in the rim. By contrast, wired-on tyres use a metal or Kevlar hoop encased in rubber to create a very small bead and the rim has very little or no lip. Over the decades, the term clincher has been appropriated and applied to what were historically called wired-on tyres.
Likes For T-Mar:
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Another pet peeve of technically incorrect usage that seems to have been superseded by common practice:
Referring to the tire width as "c". I.e., 32c tires. It's 700c x 32mm. 32c means nothing.
But even the manufacturer's spec sheets fall into this usage. I was just looking at the Trek website and they list the Domane as having clearance for 32c tires.
Irregardless, I guess language changes.
Quoted: 2362 Post(s)
Liked 1,746 Times
Quoted: 964 Post(s)
Liked 1,451 Times
Irregardless
Let's not even get into how people pronounce some of these words. SRAM (shram) and derailleur (derail-yer), for example, really get my goat.
Likes For scarlson:
Liked 3,036 Times
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Bill
Semper Fi, USMC, 1975-1977
