DI2 Users - Curious to know which mode you prefer (full or semi-synchro)
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Hey guys,
I'm curious to know which mode you prefer more between semi-synchro or full-synchro and why?
I've been using the 2 (switching every few rides) ever since I got my new bike & having a hard time figuring out which one I like most. I liked the full-synchro at first, but the automatic front derailleur shifting gets annoying at some point (I know you can customize when to shift and I should probably delay that a little). Plus, I kind of missed using my control lever to shift. On the semi-synchro mode, I get to use both levers and the rear derailleur automatically compensates. I guess it's a kind of a ''how you feel'' type of thing.
Quoted: 43 Post(s)
I use the semi-syncro - but I only have it configured to change when shifting from the small front ring to the big (automatically shifts two in the rear). I don't have it change when going from the big ring to the small.
Senior Citizen
Bikes: Trek Emonda SLR7 Disc, Lemond Poprad, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 69 Post(s)
Liked 576 Times
Full Synchro for me. D-Fly and Garmin warn me when the the FD is going to shift so I never get surprised, otherwise I'd go Semi Synchro.
Likes For Igotdibs:
No synchro. I have the cassette / chainring position readout on my Bolt. I just count cassette switches and have gotten so used to it that looking back at the cassette is awkward now!
Quoted: 3238 Post(s)
Liked 2,086 Times
None. I run a 14-28 cassette with a 34/50 crank. I pretty much live in the big ring unless I am forced to climb a hill. Note I’m on mostly flat Long Island.
Quoted: 741 Post(s)
Liked 412 Times
I run full synchro but shift manually. Full synchro keeps me from riding big/big and shifts me to the big ring when I going to higher gears when in the small ring. It is rare that these two situations occur, but is nice to have.
Quoted: 18883 Post(s)
Liked 10,646 Times
That's exactly what I need to do. Is this new in the latest generation?
Quoted: 43 Post(s)
It came out when they came out with the synchro shifting. If you dig into the settings for semi you’ll see the option to change the number of gears that change with upsides and downshifts. If I remember correctly I think I just changed it to zero. Either that or there was a checkbox to disable it. If you can’t find it I can dig through the settings and find exactly what it is.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Semi. Small to big is configured to go 2 bigger sprockets in the rear, resulting in a slight upshift, but less than the chainring change. The opposite for big to small, except I think I set it to go 3 smaller, so it's closer to parity.
Quoted: 1528 Post(s)
Liked 718 Times
Don't have Di2, but if I did, I'd run full synchro and configure the lever buttons so left and right do the same thing. Kinda the opposite of etap - either hand can shift the whole drivetrain instead of needing both hands.
Quoted: 989 Post(s)
Liked 586 Times
Semi-synchro without the RD shifting when going from the big to the small ring is a good idea. Hadn't thought of that!
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times
I've enabled both full- and semi-syncro modes to play with, but have always gone back to fully manual. Where I ride the terrain is rolling hills and it seems like the automatic gear jumps on average make sense (I have Di2 set for a 2 cassette change for a chainring shift), but in a lot of cases I find that I want either a larger or smaller jump depending on the circumstances, in which case I find myself fighting against what Di2 wants to do. In manual mode, I just pay attention to what's coming up and have the feel for how many shifts I want and the muscle memory to hold the shifter for the correct amount of time to get the gear I need.
Full with the option to shift to the big ring manually for topping hills. Garmin display.
Chases Dogs for Sport
I've tried the various synchro programs (including custom programs) several times, but I keep going back to traditional shifting. I like the added control and knowing exactly where I am in the cassette.
Quoted: 878 Post(s)
Liked 726 Times
Quoted: 800 Post(s)
Liked 512 Times
When I bought my bike it came with no synchro modes enabled and I've left it as for the past two years. I keep thinking I'll play around with semi synchro but never get around to giving it a try.
Likes For NoWhammies:
Liked 10,646 Times
The thing about the synchro modes is the system just does it perfectly.
The downside is when you've been riding mech your entire life, even after you've set it up, you still forget sometimes.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Semi. Have run it for a year like that and don't hate it as much as I did initially. Most of my triathlete customers have gone full synchro. I am not fully satisfied with the 2 cog move in semi. Need to change it to 3 when dropping from big to small maybe. Not really sure yet. I just automatically shift when changing rings out of habit so hard to tell.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I go back and forth...ran full for a year, then switched to semi for the last year...might go back to full...
Full Syncro. Love never having to use the left shifter... Having it connected to the Garmin Edge means no surprise shifts from small to big or big to small front chain ring.
