Parts no one misses on New Bikes...
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
i'll start the list with... Cottered Cranksets and their tapered cotter Bolts.
i have spent countless hours trying to remove the bolts... only to find that the crank arm is far more stuck in place than the bolt ever was....
if someone brings an old raleigh three speed by with a bad bottom bracket,, i tell them, up front, that it's not worth fixing, and that the Crank is stuck to the spindle, so it may need to be CUT with a grinder to be removed.... some insist and persist, due to sentimental wants, then gripe about the repair bill.
Likes For maddog34:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Steel rims.
Steel seat posts, with a separate clamp that has a bolt running horizontally/laterally and two-piece steel clamp for each seat rail, you know the type.
Freewheel clusters. They worked okay, but cassettes are so much nicer.
Likes For Broctoon:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 622 Post(s)
Liked 575 Times
"Dork Disk" -- The infamous accessory of dubious utility so popular in the 1970s and 1980s.
"Rat Trap" pedals -- Many a shin bone still contains bumps galore, from an ill-fated "oops" moment with those things.
Rim-type Bottle generators -- Don't see many of these around, anymore. Good to see that there are several decent alternatives for front hub dynamo generators.
"Banana" seats -- Like disco, it died a few decades ago.
Quoted: 3560 Post(s)
Liked 2,976 Times
Crappy center pull brakes.
Likes For smd4:
Likes For msu2001la:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 415 Post(s)
Liked 950 Times
I already miss square-taper BBs/cranksets, quill stems, and quick release hubs, so any appearance on this list of those items will be incorrect.
Likes For Fredo76:
Quoted: 1833 Post(s)
Liked 1,709 Times
I was always a person who appreciated the latest state of the art back in the 1970's. There was so much innovative stuff coming out back then. There are lots of things from back then that I miss. Things that are no longer around had their day, but there are tons of things that I very much miss E.G the flickstand
Likes For alcjphil:
Parts not missed
Downtube shifters.
Likes For BillRS22:
Quoted: 576 Post(s)
Liked 1,004 Times
Grip Shift
Likes For DorkDisk:
Quoted: 1423 Post(s)
Liked 1,938 Times
quick release skewers
Likes For t2p:
Liked 1,938 Times
Likes For t2p:
Likes For wheelreason:
Clark W. Griswold
Quoted: 4422 Post(s)
Liked 4,064 Times
Freewheels and "dork discs" still very much exist along with a bunch of other stuff on the list. However I wouldn't mind seeing some of that stuff gone.
Quoted: 4481 Post(s)
Liked 4,952 Times
Brake and shift cables
Inner tubes
toe clips
QR skewers
Front mechs on mtbs
Inner tubes
toe clips
QR skewers
Front mechs on mtbs
Veteran, Pacifist
Quoted: 3907 Post(s)
Liked 4,859 Times
If a 'lightweight' road bike (that's really all I've ridden much as an adult) from the '70s, '80s, '90s, 00's, 10's, or 20's is in good condition with nice tires - I would be happy to ride it. Maybe happy to own it.
I do not miss 35pound, single speed bicycles - like the one I used on a 1960's paper route.
Across 60 years of road biking, the changes have been more evolutionary than revolutionary, imho.
Give me disc brakes, thru axles, electronic shifting, stiffer forks, steerers, and stems for hills and mountain rides. For flatter rides where speed is not the #1 priority = I miss none of the modern improvements.
edit: I miss shiny bits on bicycles.
Likes For Wildwood:
Quoted: 7666 Post(s)
Liked 3,529 Times
I totally don't understand everyone's issues with QR skewers. What I dislike is "lawyer lips." I also don't miss having to carry a wrench to take my wheels off ......
Likes For Maelochs:
Bikes: old ones
Quoted: 26456 Post(s)
Liked 10,416 Times
...the Buddha said that attachment is the root of suffering. I try not to get too attached, so as not to miss anything.
Likes For 3alarmer:
Likes For ofajen:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2611 Post(s)
Liked 5,730 Times
I don’t miss the stem mounted shifters on my old Schwinn 10 speeds.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: old ones
Liked 10,416 Times
...I just realized that I don't miss bicycle wheel rims without bead hooks, and the low pressure tires that went with them. This Buddhism thing is working for me.
Quoted: 18462 Post(s)
Liked 15,725 Times
Sissy Bars.
Stems with deep bolts and plastic caps.
Mario Cipollini.
Mario Cipollini.
Liked 3,014 Times
8 speed cassettes
-Oh Hey!
-Oh Hey!
Pennylane Splitter
Bikes: Yes
Quoted: 1822 Post(s)
Liked 1,466 Times
A great cost-effective option for that MTB/roadie you want to convert to a utility/commuter bicycle. No need to put a costly set of shifters/brifters on one of those bicycles.
The old screw-on freewheel gear clusters were a PITA to remove, cassettes work much better!
I like QR wheel attachment systems, just easier to get on/off to fix a flat. Square Taper bottom brackets, rim brakes, cabled brake & shifting systems all work fine and are easy to maintain with a basic set of tools.
Liked 3,529 Times
Thumb shifters were no more expensive than twistgrips, and were a lot more useful, IMO. With twistgrips one must use the same portion of the grip which is most necessary for control, for shifting as well---thus combining motions which are unrelated, compromising either control or shifting.
With thumb- or trigger shifters, one can grip the bar with the fingers (or thumb and fingers) and still shift. And twist shifted Grip Shifts were in now way cheaper originally, and certainly nowhere near as simple. A thumb shifter is just a lever on a pivot, essentially .... basically a downtube shifter on the bars. Stone-age simple .....
As you mentions .... "... work fine and are easy to maintain with a basic set of tools."
But ... i will let that slide because you have solid views on the rest of the stuff ... (read: "you agree with me." )
Likes For Maelochs:
