Just upgraded to friction shifters- I LOVE THEM!!
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
I bought some 2$ friction shifters from the co-op I volunteer at and set all the cables in about 3 minutes- something I could never do with indexed shifters. I got the bike off the stand and rode it around the lot a few times to get a feel for them. I've used them before, but never on my own bike. They work wonderfully and I love not needing to adjust them in the stand before riding. I just set the adjuster on the rear back to zero and clamped the cable down. I love the ease of maintenance part about them already after owning them for only 3 hours now.
Before I had friction shifters, I had indexed front and rear shifters. A bit time consuming to fine tune, but they were working great. I got frictions shifters for ease of maintenance, price, simplicity, and take up less room (no room in fact) on the handlebars- which is good for touring.
Any one else have any success stories going from full indexed to friction?
Josh
Josh
Quoted: 5891 Post(s)
Liked 3,475 Times
I don't know about a "success" story. I like indexed derailleurs but I've been thinking of going with friction on one of my riders. I like having to "feel" the shift rather than relying on the mechanical click. So I may join you (with one bike) in moving backwards in technology.
Bikes: '93 Cadex CFM3, '84 Repco Nishiki Olympic 12,'87 Peugeot Montblanc, '09 Giant Trance X1, '13 De Rosa R838
Quoted: 8 Post(s)
I also love friction shifters, especially suntour. I have suntour symmetric shifters on my commuter. They are self trimming!
Bikes: Unknown model Giant MTB
My bike has friction shifters. A while back I needed to swap out the old 6-speed freewheel for a new one, and the only one I had was a 7-speed. Put it on and rode away without even adjusting anything... it works perfectly. Try that with indexed shifters!
Quoted: 987 Post(s)
Liked 1,652 Times
No but I had one hell of a time trying to use indexed shifters on my brothers bike - I had never appreciated how much direct control I have with my friction shifters...
Bikes: 2011 Raleigh Sojourn, 2012 Marin Four Corners, 2013 Soma Saga, 2014 Scott Spark 940, 2017 Brompton H6E, 2016 Trek FX 7.2
Quoted: 10 Post(s)
All my bikes up until a few years ago had trigger shifters. Then I picked up a bike on CL that had down tube shifters, then I got a touring bike that had bar ends. Now I have the shimano bar end shifters where the rear shifter can be indexed or friction (except that I have them mounted in an unusual fashion, see pic). I really like the front being friction because it's so easy to trim for any gear combo. For a few years I rode with the rear friction as well, but recently switched it to index mode. I am finding I prefer the rear indexed because with more gears it's easier to just push the lever around and it automatically lines up with the nearest gear wherever I stop without me having to trim it for noise etc. . What I like most about this kind of shifter is that unlike trigger or STI shifters, I can push through the entire rear cassette in one smooth motion in a split second, instead of ratcheting.
Ha! Funny you should say you've "upgraded" to friction, when about 30 years ago, that's about all the choice you had! I had this $99 special from Canadian Tire when I was a kid that never really worked all that well - cheap, centre-pull caliper brakes that needed adjusting all the time, heavy steel road style frame, a pretty awful saddle - but even the cheap friction shifters worked.
... and now I have a much more expensive bike - with newer and much better made friction shifters, and I love it! I will concede that an indexed rear shifter could have some advantages in some riding positions, but I really prefer just friction shifting the front gears to make sure I trim it just right.
Carpe Velo
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times
I have 2 bikes with friction bar ends and one with DT (The DT bike is actually index capable, but I see no point in bothering). Never found it difficult at all, just moved the lever until it is in the next gear. No fuss.
I didn't like friction shifters on the old bike, it took forever to shift right, and it was probably tied to the whole fact that the bike was crap anyways.
Brifters at least encourage me to use the bike with many of the gear that's available.
But to each their own It's good that you find something that works for you.
Bikes: Poison Chinin IGH
Another success story here. Have a rear dura ace 9 sp barcon with broken indexing, but it works well in the friction mode. Not precise enough when used with a 9sp hyperglide cassette though, chain would frequently jump up or down. I've installed an 8sp cassette which has a bit wider spacing between cogs and voi la, it works very well now.
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
On modern drive trains w/ 9, 10, 11 speeds..........
It is a nice combo to have friction front and indexed rear on bar end shifters.
In some ways, best of both worlds.
Dirty Schwinn-Lover
Bikes: '11 & '13 Schwinn Racers, Takara (Kent) Kabuto, '11 Gary Fisher (Trek) Marlin SS 29er, Schwinn Sanctuary Cruiser, '11 Schwinn Sid, Firmstrong Chief 3-spd, '10 Schwinn Corvette
I mostly ride single-speed, but for the few geared bikes I have, I'm running friction because I love how lazy it allows me to be in "dialing in"...I set the high and low limit screws so that the chain can't jump into the spokes/stays, and away I go for lonnnnnng periods of time! I've got a Sunrace top-mounted shifter for my 8-speed lazy commuter, and I'll soon be putting a set of Sunrace stem shifters on the dreaded Kent Denali for grocery-getting. I've got a nicer set of Shimano bar-end shifters, but I'd kind of like to put them on a nicer bike, to be honest...eventually I'll come across a nicer frameset and dedicate them to that particular Frankenbike, but when it comes to friction shifting, I'm with the OP...due to its low maintenance and easy on-the-fly adjustment, it's definitely my preferred choice of shifting.
Liked 3,475 Times
In the right lane
Beyond that, one simple fact: friction shifters give you more control. You do have to learn to shift differently if you are moving from STI or indexed thumbies, but it isn't hard to learn.
I got off before the index thing in 88, at 7 speed freewheels , then the 'index' shifting
is just the sequence of gear combinations through the grip shifter,
operating in my Rohloff hub, or the trigger shifter on the 3 speed..
nice "up grade". welcome to 1982.
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
aka Timi
Love the "upgraded" title
I have friction stem shifters on my commuter which has evolved from 6 to 9 speed cassettes over the last 25 years or so
Also had friction on my touring bike until the last build where I put indexed barcons on. They can be run friction but I haven't bothered as they work so well... May just upgrade now by turning the knob!
Quoted: 55 Post(s)
Liked 32 Times
You should spend some time reading the "Learn" section of his website or pick up his book "Just Ride". He's all about functionality and comfort. His views are not for everyone but there seems to be a growing population of folks who find his ideas compelling.
Bikes: 2010 Surly LHT (main rider and do-everything bike), 2011 Bike Friday NWT (back-up bike and multi-modal)
+1 on friction shifting. It really is my favorite by far over indexed
As an adult, I started with an indexed shifting 21-speed 1990's mountain bike from a relative who didn't want it anymore, and then I bought a stem-shifter-equipped 1970's 10-speed from the flea market. After that, I didn't really like indexed shifting much anymore.
When I bought my Surly Long Haul Trucker over 3 years ago, it included Shimano Dura-Ace bar-end shifters that offered indexing or friction mode for the rear derailleur. I switched it to friction mode and never turned it back.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Although I just straightened the derailleur hanger on my Bianchi Eros so that the indexing (7-speed) would work cleanly again, I've got to say that I'm a big fan of friction shifting, especially with good micro-ratcheting shifters that will hold their setting with a minimum of friction. While the responsibility for doing the shift cleanly is now up to the rider, that rider can always fine-tune the setting so that they don't have to ride around with a rattly bike if something goes wrong.
Quoted: 32 Post(s)
I would have to agree with you. I love mine too.
I have brifters, rapid fire index, and bar ends and I love my bar ends. I thought I would hate them but they are so nice. The others do not really allow to trim that much on shifting, even the brifters. They allow you to trim but not that much a all but the friction shifting allows a lot of trim and even though cross chaining is not proper, it does allow for it much more then the others. I thought I would hate them but man, I love them.
The ONLY downfall is sometimes they get knocked around since they are located at the end of the bars.
genec
Quoted: 13659 Post(s)
Liked 4,532 Times
What are these "index shifters" you speak of... GRIN
Bikes: '83 Nishiki Olympic 12, '87 Panasonic DX-5000, Formerly owned: '84 Miyata 710 Campagnolo, '84 Miyata 610, 2010 Soma Smoothie ES
I love my autotrimming symmetric shifters too and I get annoyed when I have to trim on my other bikes. I made the same "upgrade" to friction shifters from STI a couple of years ago. Brifters are great, but there's no satisfaction in nailing a shift perfectly with them.
