Freehweel knocking noise?
we be rollin'
I bought a department store bicycle for the winter but it has a knocking noise I believe comes from the Superwin freewheel. I searched for this on the Internet but can't confirm if anyone has actually SOLVED the knocking noise by REPLACING the freewheel. Has anyone ever solved a knocking noise by replacing a freewheel?
Quoted: 7350 Post(s)
Liked 2,475 Times
Yes, I have.
Quoted: 4210 Post(s)
Liked 3,875 Times
As have I. For a little while some SunTour Perfect freewheels had a slight bit too much slop to the bearing "adjustment". The outer body (and attached cogs) would rock back and forth on the inner body. Depending which cog one was using the outer body would rock one way then the other using the engaged pawls as the pivot point. There would be a twice a rotation knock easily heard and felt. Andy
AndrewRStewart
AndrewRStewart
we be rollin'
Cool, thanks for answering both of you. If ever someone is searching for this, they will find the answer.
