Go Back  Bike Forums > Bike Forums > Fatbikes
Low Pressure Tire Gauge
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 06-12-19, 06:26 PM
Stateguy
Quoted: 27 Post(s)
Looking for a good low pressure gauge for a presta and schrader valves
Stateguy is offline
Old 06-12-19, 07:10 PM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 941 Post(s)
Liked 319 Times in 189 Posts
Define "low."
bobwysiwyg is offline
Old 06-13-19, 06:12 AM
Stateguy
Quoted: 27 Post(s)
Something that measures up to 30-50 lbs
Stateguy is offline
Old 06-13-19, 11:27 AM
Leisesturm
Quoted: 2497 Post(s)
Liked 740 Times in 523 Posts
Just saying, automotive tire gauges excel in that range of pressure. Schraeder only I am afraid. But I would be shocked if 'fatty' tubes came in Presta. Of course I know nothing about it. Nothing at all. Anyway, that was hardly helpful. I try to be helpful when possible. Here is what I know. I haven't owned (or needed) a tire gauge since I started using Joe Blow (Topeak) floor pumps which have perfectly serviceable gauges built in. I trust mine to measure pressures as low as 20psi and up to 100+ psi, and if the pump is off a pound or two at 30psi I DOUBT anything bad is going to happen. TL;DR: ANY tire gauge sold that reads Presta and Schraeder can be used for the o.p.'s purposes. Some are even digital, but the sensors are analog so the accuracy of the digital unit isn't any higher. It just seems that way. This is intentional.
Leisesturm is offline
Old 06-13-19, 04:18 PM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 941 Post(s)
Never used it so can't voucher for it, but it seems to cover your range and handles both valve types.
https://www.amazon.com/EyezOff-EZ05-.../dp/B01HBMENXO
Old 06-13-19, 06:09 PM
Stateguy
Quoted: 27 Post(s)
From what I am learning (I am new with the fat bike) you wan a gauge that can measure 8-12lbs low for beach higher for trails
So I was asking about a good one to be accurate with pressure
Stateguy is offline
Likes For Stateguy:
Old 06-13-19, 10:05 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
https://www.amazon.com/Schwalbe-6010...omotive&sr=1-1
This one does the trick for me
MarcusT is offline
Old 06-19-19, 01:52 PM
rangie
Quoted: 28 Post(s)
Liked 10 Times in 6 Posts
That's not low.
Search for the "accugauge" on Amazon. There's a model that goes up to 15psi for fatbikes. Higher than you'll ever need to go.
rangie is offline
Likes For rangie:
Old 06-20-19, 06:42 AM
Stateguy
Quoted: 27 Post(s)
Thanks does that gauge do both type valves
Stateguy is offline
Old 06-20-19, 07:48 AM
prj71
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
https://www.amazon.com/Accu-Gage-Pre...gateway&sr=8-2
prj71 is offline
Likes For prj71:
Old 06-24-19, 08:20 PM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
I got a Planet Bike tire gauge that measures up to 15psi.
Daniel4 is offline
Old 07-24-19, 05:46 AM
Davesnhere
Liked 3 Times in 3 Posts
Originally Posted by rangie
That's not low.
^^^Have same gauge, perfect for fatties!
Davesnhere is offline
Old 10-24-19, 03:06 PM
Rangerbob1
Guage
Schwable airman digital Guage, accurate down below five psi. Replaceable battery as well. Shimano also made one but the battery was not replaceable but it was a little cheaper.
Rangerbob1 is offline
Old 10-28-19, 07:45 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
pro tip, from a long distance rider, for one of your presta valves use a schrader adapter as a the valve cover. It will save you should you find yourself needing air at a station.
qclabrat is offline
Old 10-30-19, 12:24 PM
Hypno Toad
meh
Hypno Toad's Avatar
Quoted: 1111 Post(s)
Liked 1,013 Times in 519 Posts
Are there fatbike with Schrader valves?
0-15 psi AccuGauge is my choice.
Hypno Toad is offline
Old 02-02-20, 09:34 PM
Carl J
Bikes: 2016 Trek Farley 9.6, 2016 Felt V85 (Gravel), 2017 Spherik SRU (Road), 2017 Giant ToughRoad SLR 2 (Retired), 2016 Kona Wo (Retired)
Quoted: 36 Post(s)
Liked 34 Times in 17 Posts
30-50lbs (psi) is low?
If you want low (up to 20psi, but especially for under 5psi), for a fat bike, MEC has a really good one
https://www.mec.ca/en/product/5053-079/Fat-Max-15-Gauge
Carl J is offline
Old 02-03-20, 07:44 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
I've got the same one, didn't know the name till I looked at mine this weekend
Easy to use and what I thought was 15 pounds on the pump gauge was only 10
qclabrat is offline
Old 02-05-20, 01:25 AM
Hondo Gravel
Life Feeds On Life
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 4426 Post(s)
Liked 4,537 Times in 3,034 Posts
Go by feel. It is a fat bike. No sense in arguing or worrying about it. Adjust a accordingly to the terrain. Don’t micro manage a fat bike
Hondo Gravel is offline
Old 02-05-20, 01:03 PM
medic75
medic75's Avatar
Bikes: '19 Trek Stache 5, '17 DB Hannjo Trail, '09 Scott CR1 Pro, Schwinn Central commuter, '16 DB El Oso
Quoted: 108 Post(s)
Liked 57 Times in 29 Posts
Originally Posted by Leisesturm
But I would be shocked if 'fatty' tubes came in Presta. .
Get the jumper cables out. But seriously, with the exception of big box store bikes, most fatty tubes are Presta.
FWIW, on my bike, I use the gauge as a reference and a starting point (5-6 psi) and drop the pressure from there as needed for conditions. With winter riding, pressure can vary greatly with temperature changes - never adjust your pressure until the tires have acclimated to the outdoor temperature. With that, there is no real need for a gauge as you will just be squeezing the tire to guesstimate if you have let enough air out.
medic75 is offline
Old 03-02-20, 08:28 PM
Carl J
Quoted: 36 Post(s)
Fatties have presta valves (although I'm sure some have shrader as well).
And 20psi+ is way too much for most fat bikes. For riding in the snow, a pound or two of pressure can make a big difference
Carl J is offline
sbslider
Bicycle Mechanics
33
08-08-17 01:40 PM
CosmicF
Bicycle Mechanics
11
08-21-16 07:19 PM
kenshireen
Bicycle Mechanics
41
12-08-15 04:05 AM
TrailViewMount
9
02-23-14 07:38 PM
ganchan
Bicycle Mechanics
6
04-20-13 12:28 PM
