Paint remover of choice?
Quoted: 3811 Post(s)
Liked 6,717 Times
I’m intending to strip paint off of a C&V frame, but am wondering what’s the most effective chemical in this post-methylene chloride era. What I picked up at my local hardware store has been pretty useless. Recommendations?
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Well, what'd you pick up?? I recently got a big thing of Citristrip gel and will be trying it in a few weeks when it's too cold too much of the time to ride, so I'll report back. In the past when I've stripped a frame it was a spray type, and that was not as effective as I'd hoped it would be; took a fair amount of time afterward to really get things off, so I'm hoping the gel sitting on there will be better.
small ring
Quoted: 438 Post(s)
Liked 925 Times
I'm using Citristrip right now. I rough sanded the frame (60 grit) to get through the clear coat. Then coat, let sit overnight, scrape, 2nd coat, sit overnight, scrape again. Not the most effective but it does work.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
The citrus stuff can be frustrating. If you don't wait long enough, it doesn't penetrate the paint and it wipes right off. Leave it on too long and it dries on.
Some good tools to use for the job are a few wire brushes of different sizes, steel wool, scouring pads, heavy gloves, and one of those drill powered wire brushes. It's a messy job, I have found that if you get a good strong batch of regular aircraft stripper, and optimal conditions, that's the fastest time-wise. That citrus stuff can take days and many repeated applications, just making a nasty job even worse.
Quoted: 4513 Post(s)
Liked 6,391 Times
Rough sanding promotes penetration and speeds up the process a lot too.
I did one this summer, out in the sun, once I got a couple of coats on it and it got hot, the next coat would bubble and wrinkle then the paint came right off with a big wire brush. if I missed that window, it would dry out and need another coat to saturate and soften so it would come off.
In the end lots of little bits that had to come off inch by inch but overall much less work than fighting with all of it.
I got a pack of stainless and brass tube brushes from Harbor Freight that helped very much with the detailing at the end.
It was a lot of work but far less than if the heat hadn't cooked much of it.
Likes For merziac:
Quoted: 1106 Post(s)
Liked 1,328 Times
Drywall sanding screens - though they wear out quickly. Warp around the tubes and pull each end, bare tube in 5 minutes (and probably more than one screen). Use the still-good bits of those screens for detail - a spot under your thumb, rub six times hard and it's bare. Available in various grits, pick your finish.
Dental pick for tricky bits.
Quoted: 1609 Post(s)
Liked 2,216 Times
I stripped a 1984 Trek 610 using multiple strippers. The one that worked the best with multiple applications was Aircraft Stripper. Imron is a tough paint to take off! It was a mess. Almost as bad as the Burley Tandem which I used Aircraft Stripper on as well.
P1000848 on Flickr
P1000850 on Flickr
P1000852 on Flickr
Since it was down to bare metal, I cleaned up using a file. In this case, the parting line on the BB shell was attacked. The crown was cleaned up as well.
P1000882 on Flickr
P1000848 on Flickr
P1000850 on Flickr
P1000852 on Flickr
P1000882 on Flickr
Likes For SJX426:
Quoted: 219 Post(s)
Liked 217 Times
Sounds like pre-sanding the clear coat ahead of application of the gel is recommended. I'll try that.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
My favorite paint stripper is my local powder coater. He'll media blast a frame for $40.
Likes For gugie:
small ring
Quoted: 438 Post(s)
Liked 925 Times
Speaking of blasting, has anybody tried doing it at home? I'm thinking for the nooks and crannies. Is such a thing even possible? Probably requires a lot of airflow.
Liked 6,391 Times
Harbor freight sells a set up you use outside with big plastic sheet to collect the media or just sand the ground.
Liked 6,717 Times
I'm thinking of a setup in a bathroom, taking advantage of the fumes created after a family member drops a deuce.
Quoted: 380 Post(s)
Liked 541 Times
BTW the bead blasted surface is about the best there is for that primer coat - mega bond! ! !
I used some Citristrip last time I used a non Methylene Chloride stripper, it worked OK. It didn't take the filler/primer layer very well, but honestly worked better than I expected.
I have though about going the harbor freight blasting route, are you talking about the little handheld gun or something else?
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Sand blasting is the only way I’ll strip a bike
Bikes: 75 Raleigh Gran Sport, 88 Bridgestone RB3, 72 Raleigh Super Course, 75 Jeunet 620, 95 Fuji Team
Quoted: 80 Post(s)
Liked 21 Times
I just stripped a frame with Rustoleum Aircraft Stripper. It worked, but it took three applications and I had to break out the wire brushes.
The old Methylene Chloride strippers would have done it in one shot.
I'll get them blasted from now on.
Liked 6,717 Times
I had some citrus-based stripper on hand, so that’s what I’m using so far. The good thing is that it doesn’t dry out quickly, so it continues to work for quite a long time. The bad thing is that the job will still require a lot of scraping and sanding.
Likes For nlerner:
Quoted: 112 Post(s)
Liked 213 Times
I had the frame I'm working on now blasted by a local powder coating company after attempts using a stripper were going slowly. I used some marine stripper on the chrome fork.
Liked 2,216 Times
BITD I stripped a frame with sand. BAD idea! it will strip both the paint and the metal. Bead blast is best. Sand blasting is really risky when the target is double butted or triple butted, chew right through it.
Check with the service provider for the type of medium they use for blasting
Likes For SJX426:
No one cares
i stripped an old 14' boat this past summer. I started with Citrstrip and it was ok, but not nearly as good as what i ended with which was this stuff:
https://www.lowes.com/pd/Jasco-1-Qua...E&gclsrc=aw.ds
That's what i'd recommend.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
Liked 5,803 Times
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
Jasco 1-Quart Extra strength Stripper Semi-paste
Dichloromethane {Methylene chloride; R-30;Freon 30} 60.0 -100.0 % PA8050000
Methanol {Methyl alcohol; Carbinol; Woodalcohol} 10.0 -20.0 % PC1400000
Hydrotreated light distillate (petroleum) < 5.0 % OA5504000
