Suntour bar-con locknuts
rain dog
Quoted: 16 Post(s)
Liked 8 Times
So apparently one of the locknuts on the suntour barcons i installed loosened up and liberated itself from my bike recently. Luckily, I had another spare set I pulled one from.
Does anyone have tips for preventing this in the future? Just check them every week or so for tightness?
Anybody have tips for actually tightening them? With the screw sticking through the middle it gets difficult to tighten them with a regular flathead screwdriver after a certain point, I've had to use a smaller one to only fit half the head and I've already chewed part of one up trying that out.
FBoD Member at Large
Quoted: 30 Post(s)
Liked 7 Times
Like a $0.99 screwdriver at Harbor Freight or Northern Tool...
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
You can buy a cheap, soft screwdriver and notch it with a dremel or hand file but your small screwdriver should do the trick because you apply the torque from the other side with a driver on the slotted bolt.
A dab of blue locktite will keep the nut in place for a few years until the cables need replacing.
edit...Khatful beat me too it...
rain dog
Quoted: 16 Post(s)
Liked 8 Times
Thanks guys, I might try rigging up a tool at some point. I guess I was tightening them wrong, I assumed that the cap was a locknut and you were supposed to tighten the screw to the inner nut and then just tighten up the locknut to keep it from loosening. I'll try clubman's method or try to pick up some blue locktite for next time I need to adjust them.
Bikes: enough bikes to qualify for Hoarders......
you can use a chainring wrench too. I have a notched screwdriver tip for this, and to hold seat binder nuts too.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I use blue loctite, and an adjustable pin wrench. But I too have ridden many miles with the lock nut missing.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
BikeTales
Classic & Vintage
20
05-10-23 01:20 PM
jamminB
Classic & Vintage
7
10-14-14 11:27 AM
