Stem, HT angle, Fork Rake = steering speed
Bikes: A few
Quoted: 122 Post(s)
I am hoping someone can help me understand and compare 2 different set-ups. Any pros & cons of each set up? how do the 2 steering set-ups compare for twitchiness? Thanks in advance.
Current Bike: Head Tube Angle 71°, Fork Rake 50mm, Tyre 700x35, Stem 90mm 6°
New custom frame: Head Tube Angle 70°, Fork Rake 50mm, Tyre 700x35, Stem 70mm 6°
The bike is mostly for lightly loaded touring, and occasional gravel biking.
Quoted: 714 Post(s)
Liked 800 Times
I wouldn't call either of those "twitchy" The custom bike will have more tendency for the front wheel to "wander" or, steer based on pedaling input, on very low speed climbs. My current gravel bike has the same HTA and rake with a 50mm stem and that is the only negative thing that I have found with that frame. It's a very minor thing and all bikes do it to some extent. It's worth it to me for the increase in stability when descending.
Randomhead
Liked 3,699 Times
Stem length has very little effect on steering. It changes things just a tiny bit at high steering angles, which almost never happen during forward motion. Stem angle has no effect whatsoever. Draw a free body diagram if you don't believe me.
Likes For unterhausen:
Quoted: 714 Post(s)
Liked 800 Times
I always enjoy the, often quoted, bicycling publications that claim you can approximate the feel of steering with a short stem by gripping the bars close to the stem. Um..no..that only shows that really short handlebars cause twitchy steering.
Quoted: 4210 Post(s)
Liked 3,876 Times
With today's removeable face plate stems it's very easy to try a couple of different stem lengths and see for yourself what the steering changes feels like. Then you can report back here and learn us something. Andy
AndrewRStewart
AndrewRStewart
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Bicycle Trail Calculator | yojimg.net
Your new bike comes out to 74.2 mm trail (and 23.8 mm wheel flop).
Your old bike comes out to 67.6 mm trail (and 20.8 mm wheel flop).
Both are high trail compared to a twitchy racing road bike.
The head tube angle matters a lot. The difference in 1/4° is significant. Are you sure these aren't rounded numbers? If they are, I would use 3 or 4 significant figures, do the calculation, and round (if at all) at the end.
Bikes: A few
Quoted: 122 Post(s)
What about a 70mm stem on the first bike (Current Bike: Head Tube Angle 71°, Fork Rake 50mm, Tyre 700x35) for would that be very twitchy?
Occam's Rotor
Liked 2,331 Times
I'm no expert, but (apart from the change in effective reach) I doubt you would be able to tell the difference, especially with those high trail numbers to begin with. Also, since your shorter stem (in the OP) goes with the higher trail, the difference would have to amount to more than the difference between the two head tube angles (which is a lot -- play with that calculator link I posted a bit).
Quoted: 714 Post(s)
Liked 800 Times
You could probably put a zero (0) mm stem on that bike and it wouldn't be what people refer to as "twitchy". It would definitely feel weird to you, because the bars would be way closer to you and you would have less weight on the front wheel. I think that accounts for most of the handling differences people feel when experimenting with different stem lengths.
Likes For dsaul:
Randomhead
Liked 3,699 Times
The feel from a shorter stem is definitely different, as in shortening the stem on an already built bike to put the handlebars in the wrong place. I am not sure I believe it really changes the rider's cg much. Just reverse engineering the numbers, I assume it's a drop bar bike. The various positions on the handlebar change the rider's cg far more than a small change in stem length.
But since this thread is in framebuilders, I assume the frame isn't built yet. You can't just independently change the stem length, it needs to put your hands in the right place. If you shorten the stem then the top tube should be lengthened to compensate, and thus the cg will not change at all. If we agree on these ground rules, then I'm back to saying that the stem doesn't make any difference to handling. Trail dominates handling, it's much more important than cg and weight balance. You certainly aren't going to compensate for a major change in trail by fiddling with secondary effects like stem length and cg.
Quoted: 4806 Post(s)
Liked 3,932 Times
Stem length has a very real effect if you go to extremes. (Says he who has many thousands of miles or 180 stems and currently rides 175, 150. 140, 135 and 120.) Much of this effect is from moving the "cockpit" weight so far from the steering axis. Likewise the weight of the rider's limbs.
Quoted: 714 Post(s)
Liked 800 Times
Randomhead
Liked 3,699 Times
I don't think any analysis, no matter how approximate, would show that to be true. If you need a 180mm stem, then you aren't going to want to reduce the length to change the handling.
I always suggest people do what they want to do and are convinced will have the effect they want. Then confirmation bias will make it so. Feel free. Cycling is so full of received wisdom it doesn't make sense to fight it sometimes. It also helps sell new bikes when the polar opposite of what used to be cool is the new thing.
