Endurance Road Bike for RAGBRAI
Bikes: Giant OCR 1; Specialized Crossroads; Cannondale Quick 1; Vintage Schwinn Breeze 2 Speed Kickback
Liked 6 Times
Hi all. I am shopping for a comfortable endurance road bike for RAGBRAI 2023. I like a pretty erect riding position. I have done RAGBRAI twice on my 2004 size small Giant OCR 1. I recently added a riser to the OCR to get more erect, and I have also raised the OCR’s stem as much as possible. I like having multiple positions for my hands. I think the OCR small frame is 51cm.
I am female, 5’2” tall, 108 lbs. and 66 years old. I am not a strong rider, but I am a determined one. I might spring for electronic shifters or I might spring for carbon fiber, but if a $1,000 bike will make me comfortable that’s great!
Any suggestions for a comfortable, small, short-reach endurance bike? Thanks!
Likes For TRY-ATHLETE:
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
Have you thought about swapping out the handlebars and/or stem for something more comfortable?
The best suggestion I have is to visit your local bike shops and test ride different brands and models to find the best fitting bike for you.
First, if you're 5'2", a 51cm bike might be a little big for you. Especially if you prefer a more upright riding position. I'm 5'4" and have 5 bikes: two 49cm frames, two 50cm frames and one 51cm frame (tri bike). I'm a couple inches taller than you and it's hard to tell the difference between the 49 and 50cm bikes, but I can between the 49 and the 51cm. My 51cm tri bike is right at the edge of what I am comfortable riding, and I tend to ride low and aero (as much as I can).
That's really all I can say on the matter. But for those of us who are unfamiliar, what is 'RAGBRAI"?
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Trek Domane size 49 might be a good place to start.
Likes For Polaris OBark:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
Literally the first Google search result for RAGBRAI (in either lower or upper case): Home - RAGBRAI
Likes For SoSmellyAir:
Liked 6 Times
Thanks for your advice. I am starting to visit bike shops. Started by riding some hybrids but I didn't really like them. So now I am thinking endurance road bike. And different handle bars might help.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
If you want upright riding, not sure if a drop bar bike is best.
But if you find one that mostly works, consider pairing with a 35deg rise stem and drop bars that have a 20 or 30mm rise from the stem.
Both will help raise the bars up.
Liked 6 Times
Likes For VegasJen:
Liked 6 Times
Thanks for this technical advice. I'm going to print it and I'll have something to talk with the bike shop people about. Very good.
Liked 6 Times
Thanks; I'll check out the Trek Domane size 49.
Liked 3,445 Times
I think the Al one has a smallest size of 49 and the carbon one has a 47. My daughter is 5'6" and her 52 is a little bit too large for her.
Thanks for your advice. I've always thought that my 51cm Giant OCR was a little big for me, so I am happy to hear your opinion. And RAGBRAI is an acronym for Register's Annual Great Bike Ride Across Iowa which began 50 years ago. Starts at the west edge of Iowa and, in 7 days, you bike to the eastern edge. You dip you back tire in the Missouri River, cycle across the state, and dip your front tire in the Mississippi River. Not a race, but challenging. Different routes each year, some more difficult than others. About 500 miles.
Liked 1,474 Times
I do not believe that it never occurred to you to do a web search. Rather, your answer seems to confirm that it did occur to you, but you did not do so for some reason.
Pizzaiolo Americano
The Salsa Journeyer is a perfect Ragbrai bike in my opinion.
https://www.salsacycles.com/bikes/20...eyer-sora-650b
Likes For Pizzaiolo Americano:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
Cannondale Synapse?
Likes For RB1-luvr:
See where I'm going here?
Likes For VegasJen:
Klaatu..Verata..Necktie?
Quoted: 10442 Post(s)
Liked 11,916 Times
OK, let's play a stupid game. Let's pretend we're having this conversation in real life. Let's say you come up to me and say, "Hey! I just signed up for the super wazoo triptokeptic sprint and I'm super excited!" Now I say, "Hold on, I'm going to google that."
Now, to be fair, that may be exactly what Millennials would do.
Liked 11,916 Times
To the OP: If you're comfortable on the OCR1 with the raised bars, your goal should be to find a new bike that allows you to replicate that position. This can be accomplished by taking a number of measurements of it, and determining what bike allows you to get closest to that without things like an ultra-short and/or very angled stem.
Liked 1,474 Times
Quoted: 5888 Post(s)
Liked 3,471 Times
Likes For bikemig:
Quoted: 1401 Post(s)
Liked 1,886 Times
Liv bikes - designed for the gals (?) ... are they still around and a good option ?
some companies have XS size bikes - Trek ... Specialized ... ?
maybe Cannondale Synapse mentioned above ?
maybe Salsa Journeyer mentioned above ?
Cannondale Topstone is avail in a XS size - gravel bike with relaxed geometry, fairly upright bar position (relatively speaking) and wide gearing ... 700c wheels ... throw some 32 - 35mm smooth tires on it and it could be a fairly good candidate for RAGBRAI (?)
Liked 1,474 Times
It's all a matter of how you use it. I prefer face-to-face conversations with people. I live in a rural area where that's a little more difficult. For me, an online forum is a reasonable analog.
Quoted: 4415 Post(s)
Liked 1,567 Times
The reality is that virtually all bikes for someone 5'2" are going to have fairly tall front ends, limited ability to modulate shock due to your low body weight and you won't be doing any real fast downhills. Any sort of road bike will work well. Older carbon fork bikes, pre-disc brake, generally had more shock absorbing rides. But you can put bigger tires on today's bikes - and then ride them at incredibly low pressures du to being so light.
Long story short, get whatever you like that fits. Beware of many newer bikes with "small" frames that have really steep seat tube angles in an attempt to fool you with their apparent short top tubes.
Personally, RABRAI seems like an ideal place to ride a classic '90s bike. Weight and braking being unimportant.
If I were you I would get your OCR handlebars where you want them to model for a future bike. Then you'll have a good back up "rain bike" as well.
Likes For Kontact:
