Friction grip shifters not made any more?
Quoted: 20 Post(s)
Hello,
Are friction grip shifters made any more?
My front derailleur is impossible to index properly and the existing broken shifter is a non-indexed.
Bike shops don't have, amazon just has crappy stuff (i actually bought one marketed as friction but indexed, have to return it), ebay has some old ones but shipping cost exceeds the value.
thanks
thanks
Quoted: 1438 Post(s)
Liked 1,092 Times
Friction thumb shifter? Cheap and simple. Here's a pair for $10 with free shipping. https://smile.amazon.com/Sunrace-SLM.../dp/B007QMJH86
Quoted: 20 Post(s)
Friction grip shifter for the front derailer.
It's easy to find friction thumb shifters and if I can't find grip for a reasonable price, will go thumb instead.
Prefer grip, nicer to use and matches up with the bike properly.
Index doesn't work properly, the bike was never designed for it.
Quoted: 20 Post(s)
Department store mountain bike, went from old SRAM MRX non-indexed to sram indexed shifter.
Original crank and gears.
Impossible to index properly - fix one thing by changing tension level and another problem shifting or rubbing pops up, gears may be slightly misaligned due to age or not standard.
Returned index shifter, have to use friction which doesn't seem to be made in grip style any more.
Quoted: 1034 Post(s)
Liked 1,290 Times
Hello,
thanks
thanks
I've had Gripshift for a lot of years (since '88) but I've never had the cheaper department store type. But every one of them have been index shifting. That's the only way they come. To be clear the front or rear derailleur do Not make it index, it's the shifter itself. So you must make sure the Gripshift is compatible with your specific deraileur. For example different deraileurs have different pull ratio even if it's from the same brand.
Or am I missing something.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12757 Post(s)
Liked 7,672 Times
There are 3-position left gripshifts and 9 or 10 position left gripshifts, no friction that I know of.
Bikes: everywhere
Liked 7,672 Times
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Every left gripshift I’ve ever across has positions on the shifter from 1 to 3 but they aren’t ‘indexed” like the rear. They “click” rather than index like a paddled shifter (Rapidfire or SRAM). Often they have almost as many “clicks” as the right side. I’m not a fan of gripshifters but they do offer a lot of trimming on the derailer.
Stuart Black
Stuart Black
Likes For cyccommute:
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Jeff Wills
Jeff Wills
Bikes: everywhere
Liked 7,672 Times
Quoted: 20 Post(s)
The original shifter i tried had multiple clicks so it could be trimmed.
All the new ones for 3 speed are 3 position. i bought a second one off amazon after having issues with the sram - was supposed to be non-indexed but it has 3 positions/clicks instead of being friction or having multiple clicks for trimming.
I don't know what crankset it has and the info off on the derailer is faded off. Likely cheap generic junk.
Liked 1,290 Times
Likes For user_1:
Quoted: 2337 Post(s)
Liked 2,818 Times
friction thumb shifter? Cheap and simple. Here's a pair for $10 with free shipping. https://smile.amazon.com/sunrace-slm.../dp/b007qmjh86
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I hate grip shifters and always replace them with thumb shifters. Plenty of cheap thumb shifter options.
Quoted: 20 Post(s)
I will probably end up with a thumb shifter due to lack of availability of what I need - friction ones are few and far between.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
You should be able to find lots of old model 5.0, 7.0, 9.0, or 9.0sl left shifters on ebay. Many are new old stock. All are micro-indexed, which is what i believe you are looking for (10-ish clicks of adjustment)
I really liked the micro-indexing for the front. Always seemed like the best of both worlds to me (friction and indexing).
20 seconds of searching turned up a 7.0 ESP on ebay just now. $25.
Look around longer you can likely get one even cheaper.
Quoted: 980 Post(s)
Liked 582 Times
Maybe something from RIVENDELL?
Likes For sweeks:
Quoted: 20 Post(s)
How do you identify/search for them?
I only see two and they're from distant countries.
I'm in canada and prefer something that won't take 2-3 weeks to ship.
