Silca Impero Problem
Silca Impero Pump Problem
I have a Silca Impero dilemma. It should be easy with the simplicity of this pump but, here goes. And I google searched this to death. Old pump, new oiled softened leather piston. It pumps/pushes air out, but when connected to tire valve, on the reverse stroke, no air pulls in, and suction is created so the handle wants to spring back down. How does air flow into the chamber? Is it supposed to flow around the piston when pulled back? Ideas welcome. D'Ohhh!!!
Quoted: 1608 Post(s)
Liked 2,216 Times
xetaprime I would make sure the leather is oriented correctly. I have had them fold part way around making them useless. Cup should be pointed toward the head. The pressure seals the leather against the cylinder to pump the tire. On the return stroke, the leather should let the air go by it and the cylinder. Oh and it should be lubed with appropriate grease for leather.
Take it apart and show us the assembly of the leather.
Likes For SJX426:
Quoted: 3464 Post(s)
Liked 2,831 Times
too good a seal.
Pushing the head too far onto the value and it's holding the valve open?
UPDATE: Old leather piston works fine.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
The problem lies in the leather seal. Its too tight of a fit.They come in 2 different sizes. Or you put a floor pump seal in it.
On Silca website they have 741 - 30mm inside diameter, and 721 - 28mm. I guess those are floor pumps. My caliper is showing 20mm at the threads... why is it never simple?
Quoted: 4512 Post(s)
Liked 6,386 Times
I always clean the inside of the body, they get pretty nasty. Then relube it separately, sparingly and thoroughly working the lube in before installing the handle and plunger.
I have always used mineral oil which I have seen indicated many times, sparingly on the leather.
