Jamis Renegade owners
#476
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times
No reason to replace the front wheel if only the rear is damaged, unless you're really concerned about the weight (it's probably not a huge difference) or you like your wheels to match.
Another wheelset maybe worth looking at is the Easton EA70AX. I have no experience with those wheels, but the older Easton wheels on my road bike have been reliable. I've seen EA70AX wheelsets on Craigslist locally, lightly used, at reasonable prices (sometimes as a take-off from a new bike, they're the stock wheelset for the Cervelo Aspero and maybe others) and I keep thinking about buying them for my Renegade.
#478
Quoted: 427 Post(s)
Liked 339 Times
The GRX wheelset is exceptional for the price. Wheels tend to be grouped around $400 - $450, $800 - $900, $1200 - $1300 so not many choices around $600. The $400 bracket has great choices though with the Shimanos, Eastons and the FSA gravel set all arond that price. Be sure the front axle diameter matches what you need when you order. Some of the Hunt wheels are in this price range as well, and LOOK the nicest but are not as well made as the other choices I mentioned.
#479
Headset for a 2017 Renegade Elite carbon
Headset for a 2017 Renegade Elite carbon?
Anyone replaced theirs? The bottom bearing on mine is toast - reached out to Jamis who gave me the following info:
The SHIS dimensions for the 2017 Renegade Elite headset are IS42/28.6 upper and IS52/40 lower. That should be all you need to track down replacements.
Ordered a Hellbender 70 from Cane Creek based on those specs (IS42/28.6 | IS52/40-H1), but the bottom bearing doesn't seem to have the same angle and does not fit quite right. Can anyone confirm if I ordered the wrong part? This is my first time replacing a headset. Any suggestions for an alternative to the original Ritchey headset?
#480
Quoted: 87 Post(s)
Liked 107 Times
Note - the following answer is based on general information about headsets, not specific to a Renegade.
Which part doesn't fit right - does the bearing not seat in the headtube correctly, or does the fork not sit against the bearing correctly? If the latter, you probably need to replace the crown race to match the new headset. The crown race is a thin washer, shaped to match the bearing, that sits at the bottom of the steerer tube where it meets the fork crown. I'd get a shop to replace it, especially on a full-carbon fork - shouldn't take them long. A shop will have the right tool to remove the old one and bang the new one into place without damaging the fork.
#481
Quoted: 11 Post(s)
Well, my 2017 Renegade Exile is still going strong 8,500 km's of riding. When I purchased this bike, I made the commitment to ride it to work as often as I could, along with with riding it on the weekends with the family during the summer. I was in my early 40's when I purchased it and wasn't sure if it was the right style bike for me, but I'm glad I went with it. It's comfortable, durable and very versatile. Most of my riding is on the pavement with a few stretches of tightly packed gravel but it's done well.
My only regret is putting on a set of 700x38C Schwalbe G-One Speed TL Easy Evolution tires. The original Clement tires were very easy for me to take off and put back on to repair a flat.
These Schwalbe tires were so hard to get on, my wife and I had to do it together. I wasn't sure what I would do if I got a flat while riding and that ended up happening. I couldn't get the tire back on and had to walk the 7km home. The fellow at the store even commented that they were difficult to get back on.
So, my question to the group here is, what tire are you using that is easy to get on and off the rim without needing two people to do it? Do the Panaracer gravel kings go on easily? I suspect it has to do with the bead in the tire? I run tubes and have no desire to go tubless if that makes a difference.
thanks
james
thanks
james
#482
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
Some find GravelKing tires easy while others curse them. You see it play out of forums- someone comments on how difficult a tire is and someone else comments that the same tire and size was so loose it damn near fell off.
I have GK tires in 43mm SS, 32mm Slick, and 28mm Slick. The 43mm SS and 32mm Slick were both easy to get onto the rims. The 28mm Slicks were a bear. They are on 3 different wheelsets.
Its a relative crapshoot.
#483
Quoted: 87 Post(s)
Liked 107 Times
I have a second set of wheels that one day I'll set up, the plan was to have a set for road and a set for gravel but then I built up/acquired two dedicated road bikes so I lost any urgency on that; I'll be interested to see if the same tires are easier or more difficult on different rims.
#484
Quoted: 11 Post(s)
I'm likewise running tubes on my 2018 Renegade Exploit. I haven't checked the specs but I expect I've got different rims than you. I've run the stock Clement 36mm MSO's (but I found them too buzzy, I think because they're the low-TPI OEM version and not as flexible), the 40mm version of those tires, 32mm Continental GP5000s, and 32mm Ritchey Speedmax (one with a wire bead, one with a kevlar bead). Of those I've found the Speedmax the easiest to remove. I've been able to get all of them off on my own, some required more effort than others - the Continentals were pretty stubborn although they're also the only ones other than the stock tires that I bought new, so maybe the others were already broken in a bit.
I might take a flyer on a set of Gravel King SS in a 38mm and see how they do. I can't see them being any worse than the Schwalbe I've got on there right now.
How did the 40mm tires do for clearance on your frame? I don't run fenders and interested if I can go a bit wider than 38mm.
#485
Quoted: 11 Post(s)
Unfortunately, there is no universally easy or difficult tire to mount. It totally depends on the tire and wheel/rim combination.
#486
Quoted: 87 Post(s)
Liked 107 Times
The stock MSO tires are 30 TPI which are an inexpensive, OEM-only version. I have the 40mm in the standard 60 TPI; more threads means the tire is more supple and they've been fine for most riding, I don't notice the buzz even on the road. Of the tires I've tried, the 32mm Speedmax are my favorite, they have a fairly smooth center with knobs on the edges which works well for most of my riding. However, I got a couple of pinch flats on a ride a few weeks back while heading down a rocky fire road at speed, and I never had that problem on the same trail with the 40mm MSOs, so I'll probably switch back go to those until they're worn, and then maybe try the Speedmax in a wider size.
#487
Bikes: 2018 Jamis Renegade Escapade and 2017 Focus Cayo SRAM Red
As rain/mud season is approaching (again), I'm considering fenders for my 2019 Renegade Expat. I am intrigued by the SKS clip-on options, but am not sure if the design would work with the way the front derailleur cable is set up on the bike, with a pulley behind the seat tube. According to the SKS website, the rear fender clips on at the same point--there looks to be a gap, but I'm not sure if it's wide enough not to interfere with shifting. I also have 650b tires (size 48 frame) and am not finding a ton of 650b-friendly fender options!
I have changed from the stock tires to 38mm GravelKing slicks, so it looks like the SKS Velo 47 Trekking fenders should fit these as well as the stock tires if I decide to put those back on.
Here is a photo of the fender attachment:
What do you all think? Does anyone have these fenders on their Renegade?
since my 700c wheels are too large in diameter i use 650b wheels for the winter and i have tons of clearance, but i'm also on a 61 frame
#488
I recently bought a Renegade C2. I tried a handful of other bike, just short test rides mind you, but found the ride noticeably better so I went for it. I was between sizes but went with the 58 over the 56 to get the front end up. I don’t love that I really don’t have any stand over but I’ll have to live with it. I’m deep in my 50’s and don’t need a bunch of drop.
Im really impressed with the ride and hoping my journey back into cycling takes me many miles. Happy to be a Renegade.
#489
Quoted: 87 Post(s)
Liked 107 Times
I've got a stock 2018 Renegade Exploit - 50/34 front crank, Shimano 105 5801 front derailleur. I'd like lower gears for some gravel climbs, so I picked up a GRX-600 46/30 crank from a coworker. I'm seeing reports of mixed results using the GRX crank with road front derailleurs - has anyone done this with their Renegade? I have the matching GRX derailleur if needed, but it's a braze-on mount and my existing derailleur is a band clamp, so if the current derailleur doesn't work I'd need an adapter. It would be great to know in advance from other Renegade owners if this is likely to work, so I don't install the new crank, find it doesn't work, and have the bike out of commission for a few days while waiting for the adapter to arrive. Thanks for sharing your experience!
Also, on a related note, how large a rear cog can the 5800 RD reasonably handle on a Renegade? (I can look up the official answer from Shimano but I know there's often room for a bit more.)
#490
Sunshine
Liked 7,496 Times
I have seen online examples of a 5800 GS RD mated to a Shimano SLX 11-40 11speed cassette with a Roadlink adapter.
#491
Quoted: 1401 Post(s)
Liked 1,886 Times
I used Shimano front derailleur band adapter SM-AD91 to mount the GRX FD
5800 and 6800 RD’s are rated for 32t max - but in many cases this can be exceeded (as reported by others including above)
R7000 and R8000 RD’s are rated for 34t max
#492
Quoted: 87 Post(s)
Liked 107 Times
Likes For nathand:
#493
Anyone Convert 1x to 2x? Jamis Renegade S2
Last month bought the S2 as my first gravel bike. I come from a road bike background. I love the bike overall, especially the handling, road feel and all day comfort'of the design
I am riding a blend of 70% tarmac and 30 gravel trail.
Overall the gravel thing js definitely a change of mind set, gear and riding approach, almost all for the better. For example, disc brakes suprised me- NOT a gimmick, they are a big step forward.
BUT the one thing I just don't like and cant get used to is the 1x thing. I miss the close ratios on the road and quick shifts between front chain ring "modes".
So has anyone swapped 1x to 2x?
how hard is it?
I guess its replacing the left brifter, cranks, chain ring and cassette? Has anyone done it themselves? Or have you leave it to the pros at the LBS?
Chain also needs replacing?
Bottom bracket?
how hard is it?
Bottom bracket?
#494
Quoted: 87 Post(s)
Liked 107 Times
I would start by seeing if the 1x will work better for you with a different chainring or cassette - that's much simpler.
Does your S2 frame have the right cable guides for a front derailleur? I can't tell from the photos on the Jamis site. If so, you'll need a crankset, front derailleur, and left shifter. You might also need a new chain if you're adding larger chainrings. You don't need a new bottom bracket.
This unfortunately requires a fair amount of work because you'll have to unwrap the handlebar tape and disconnect, then reconnect, the hydraulic brake lines. Personally I'd have a shop do that, although I don't think it's difficult with the right tools. Installing the derailleur and crankset is simple enough, doesn't require much in the way of specialized tools: hex keys, screwdriver, chain tool, and the tool to remove the plastic preload bolt on the crank.
By the time you've gotten through the cost of the parts and labor for this you might be better off selling it and buying the S3 version.
#495
Good point about the hydraulics... all in all it's big enough job that it should be done by a pro wrench..
I thought about the S3 but the spec of the S2 was better overall (brakes, wheels) and S2 has the better grade of Reynolds tubing. I like bike alot.
You are right about cost...after digging into it seems like least $350-450 in parts depending on spec plus a decent bit of labor... The big ticket cost is the left shifter... nearly $200 for that!
I suppose I can try learn to live with the 1x...
I dont dislike the overall range it provides - it's pretty decent... just a little bit missing on the very top end. Rather I find annoying the large number of shifts up and down the cassette needed on rolling terrain, and overall the lack of finesse. For road-biased riding I find it to be inferior.
But everthing thing else "gravel" I am loving. Especially the Jamis frame and geo...
I even switched to 2 sided SPD pedals from Look 3 bolt "road"... wow, is it great. And I can walk around in the shoes!
Likes For JSchmoyer:
#496
Liked 1,886 Times
and at the time i preferred the S2 over the S3 for reasons you stated - but was not enamored with the 1x drivetrain
fast forward to 2023 - I have a 2x bike with a GRX 810 48-31 crank - and also have a 1x bike (40t with 10-42)
the GRX 48-31 shift is a fairly big jump - don’t like it … don’t believe it will fit the your description of “quick shifts between front chain ring "modes" “
#497
Great point! Your post inspired me to dig a little with a gear inch calculator spreadsheet.
I suppose it is not so simple due to the 11-42 cassette with it's split personality ("roadish" part from 11-21 in increments of 2 cogs then a "mountain" part with bigger and bigger jumps for the climbs). What matters here is the overall range of course, but also which ratios are accessed when in the "roadish" part of the cassette where the jumps between cogs are small.
For 2x there is then, for one's most common riding conditions, the factor of how big the jump is between big and small up front (vs perhaps tradeoffs in duplicate gears). And I do see your point - the jumps when switching between the two front rings in that area are bigger than a classic "road" set ip: 25 to 30 or more gear inches for the GRX 2X setup.
I am now looking into sticking with the 1X but having a few front crank sizes for different ride types.
For example the stock 40 tooth (or even 38) for true gravel and loaded tours, and maybe a 44 for days when riding roads light and fast.
Now to figure out a way to make that swap easy!
hexron
6
05-03-19 09:55 AM
motorthings
14
05-23-18 08:20 AM
Barrettscv
5
10-09-15 10:57 AM
