What did you just buy for your gravel bike?
#76
AX150D - Cyclocross Clincher Disc Brake Wheels - PSIMET Custom Wheels
Just ordered these. Will see what they are like when I get them. Sounds pretty much bombproof for what I need them for...
#77
Bikes: Salsa Casseroll, Salsa Pistola, Surly 1x1, All-City Nature Boy
New set of WTB Wheels
WTB frequency team wheels on Deore XT hubs. Walked out 3 miles the other day after the freehub on my reynolds blew up. Actually i lowered the saddle and adult balance biked it for awhile.
#78
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Sportcrafters High Inertia Drum for my existing rollers
#79
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
#81
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Wooohooooo. Finally found someone with stock of the new Vittoria 700x40 Tirreno Dry tires.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Luckily...even though they aren't listed as Prime they're coming in 2 days....catch being my front Panaracer GK has a ton of life left in it
#82
Quoted: 1975 Post(s)
Liked 232 Times
#83
Liked 406 Times
Things I don't like about the GKs:
-The files clog with mud when it is wet...at which point you're on a slick anyway in effect.
-If you spend much of your time on pavement the file tread feels slow.
-In pea gravel, the file tread doesn't do much good anyway, you're limited by the size of the tire.
-GKs tick off people trying to paceline ...they kick up a ton of gravel in your wake.
Wanting to try something a bit more slick-ish for a bit. The GKs are nice tires (and I can get them cheap from my LBS), but they tend to either be overkill (hardpack limestone-chip rails/trails) or underkill (pea gravel roads) here for me much of the time.
#84
Liked 232 Times
Hehe, they don't get here until Wednesday. Not sure when I'll put them on, probably have another couple weeks on my rear GK and another few months on my front.
#85
After struggling for the last year, I decided that as most of the gravel around here are fireroads up hills, I needed to lower my gearing, so I just ordered a Shimano Deore M615 38/24 crankset to replace the Shimano FC-CX50 46/36 that's on there right now. Should make my life easier, and perhaps, slower, but going fast is what I own a road bike for!
Also I'm throwing out my cheapo Tektro mini-V brakes, and replacing them with Paul Minimotos.
#86
Liked 406 Times
Tirrene tires - Album on Imgur
So Depending on which label you read these tires are either "700x38C" or "ETRTO 40-622". WTF. Maybe they were just covering their buts.When mounted they're 40.5mm on my SL25 rims. For reference, the "40mm" Panaracer GKs measured 44.5mm IRL on these rims. They snapped right into place with my compressor (and the tubeless valve core removed), and stayed snapped while putting the valve in and pumping up better than the GKs. The tread pattern is a bit more raised than it looks online....also for whatever reason Vittoria says the tread is directional. Got me as to why.
Will see how they ride tonight after dinner.
#87
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#89
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
#90
Liked 692 Times
They're here! Album located here:
2019 Salsa Warbird
2019 Salsa Warbird
#91
purity of essence
Bikes: 2018 Giant Trance 2, 2019 Trek Farley 7, 2017 Jamis Renegade Exploit
Quoted: 37 Post(s)
Liked 26 Times
I just bought a Brooks B17 off eBay for a good price. I figured what the hell. Been hearing about them for years, I figured I might as well try one and give it a fair shake.
#92
Bikes: Trek Domane SL Di2, Giant TCR 2004, Salsa Beargrease 2015, Dahon Mariner
Industry 9 AR25 alloy wheelset. Lighter, wider and better CLD implementation (uses small lock rings) than my Boyd/White Altamont Lites. My 30mm G-1 tires expand to 33.5mm on the 21.5mm id of the AR 25's. Easiest tubeless setup I've ever had & a fantastic ride.
#93
Liked 232 Times
The sizing label is normal. The new GKs are that way, the Maxxis Ramblers are too I think. I forget why they do that, it has some to do with the cross section or something. Anyway, it's a 38mm tire that looks to ballon out to 40 on wide rims. I'm anxious to hear how they do on loose climbs with that tread.
#94
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
New frame (after accident), Diverge 2016 frameset, new saddle - phenom expert and new helmet Specialized airnet.
#95
Bikes: 2018 Fuji Cross // 2014 Scott Addict 10
Quoted: 25 Post(s)
Just snagged my first pair of MTN bike shoes for my 2-week old Cross bike, as well as the Crank Bros Double Shot pedals. Excited to use these for gravel rides & commuting!
#96
Bikes: Cutthroat, Scalpel, Roubaix, Sequoia, SuperX, Diverge
Quoted: 51 Post(s)
getting a power meter for my new Diverge, along with some 42c tires to replace the 38c trigger pros that come with the bike
#97
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
Bought a pair of WTB Byway tires. Was going to get the Panaracer Gravelking SK 27.5x1.9 but I think the slick center tread will last longer for me since I primarily ride road with some off road.
#98
I just bought a whole gravel bike..
Semper fi
Semper fi
#100
