Gravel Wheelset: Roval Terra CL vs. ??
Quoted: 1461 Post(s)
Liked 1,486 Times
Agree. I think the removal process for the Zipp freehub is basically to remove the wheel from the frame and watch it fall off. I don't think you even need to remove the cassette.
Likes For msu2001la:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,473 Times
Well, at least the DT 350 freehub looks easier to re-assemble per DT's manual; I am not sure I would know how to reassemble a freehub with pawls.
Liked 1,473 Times
Amazon.com : Terske Titanium Tubeless Presta Valve Stems Light, Strong & Serviceable : Sports & Outdoors
Reviews say these have a wider opening at the base compared to some other tubeless valves.
Quoted: 6973 Post(s)
Liked 10,971 Times
SoSmellyAir , you must have these wheels by now. Any impressions to share? I hope you like them!
Liked 1,473 Times
Weights with Roval rim tape, tubeless valves, and spoke sticker: 644 g (front) + 746 g (rear) = 1,390 g (total).
Liked 1,473 Times
The Roval Terra CL wheelset is still for sale at $1,312.
Roval Terra CL Wheelset | Specialized.com
Competitive Cyclist is having an extra 10% sale on Shimano GRX WH-RX870 gravel wheelset for $1,008 + $40 shipping.
Shimano GRX WH-RX870 Carbon Gravel Wheelset - Tubeless - Components (competitivecyclist.com)
Interestingly, the GRX rim has the same dimensions as the Terra CL rim: 32 mm deep, 30 mm wide (external), 25 mm wide (internal). However, the GRX wheelset weighs 1,484 g, and only has 18 points of engagement.
SHIMANO GRX GRAVEL WHEEL REVIEW - Road Bike Action
Is a $300 savings worth an almost extra 100 g and only half the engagement points? I suppose that is for each rider to decide.
No, I still have not installed tubeless tires onto my wheels. Now that the weather is good, I have been mostly riding my road bike.
Liked 10,971 Times
if you don’t know how to overhaul cup and cone bearings, or you just aren’t comfortable doing it yourself, factor in that additional expense. For the conditions in which I’m riding, I would definitely be overhauling them at least once per year. If you’re paying someone to do that, you’ll blow the $300 price difference in just a few years.
Likes For Koyote:
Liked 1,473 Times
I think the bigger factor is that the Shimano wheels have cup and cone bearings, while the Roval wheels come with cartridge bearings in the DT 350 hubs. It’s just a question of whether you want to do an occasional overhaul on the Shimano hubs. If you do a lot of gravel riding in nasty conditions – – like rain and mud – – then the cartridge bearings will definitely be lower maintenance in the long run.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
And for what it's worth, Shimano is moving to cartridge bearings.
https://bikerumor.com/new-shimano-hu...ar-affordable/
For what it's worth and all, since you already bought wheels, guess this is for others that may read this later.
I'll still not understand the appeal when btlos and light offer more for less, but everyone has different priorities.
Liked 1,473 Times
Modern designed cup and cone bearings take like 5 minutes to overhaul. They spin incredibly well too.
At Light Bicycle, to get close to the same weight with the same hubs, the most comparable is WR35 (flyweight version) with CX Ray spokes and aluminum nipples, which comes out to about $950 + $40 handling + $175 UPS. That is a < $150 difference.
Expired Member
Quoted: 3675 Post(s)
Liked 5,441 Times
Any opinions of the Roval Terra C ? 200g heavier but about half the price. Thanks.
Liked 10,971 Times
I’m also curious about the meaning of “modern design” cup and cone bearing hubs. Is there some new type of cup and cone bearings that I haven’t heard about?
They do spin incredibly well… I’ll give you that. Though I’m not sure that they are any better than good cartridge bearing hubs in that regard.
Sunshine
Liked 7,496 Times
I hope you intend the “5 minutes“ remark as hyperbole, because I doubt that the best mechanic in the world could overhaul such hubs in only five minutes.
As for the 5 minutes, it really wasnt hyperbole. But it was admittedly specific to basic preventative maintentance. Basically, open the hub, shoot in some fresh grease, close it up. That doesnt take long with the modern Shimano hub design.
If there is a lot of work to be done because bearings are ruined, yes it will take longer than 5 minutes to swap out the balls, clean everything, check for damage, yada yada. But if a cartridge bearing is ruined, that also isnt exactly a quick swap and takes probably just as long as replacing and cleaning the guts of a cup and cone hub.
The modern Shimano hub design needs a 15mm cone wrench and a 5mm allen in order to open. Unthread one side, keep the dust shield in place while filling the cavity with grease, pull the axle and fill the other cavity with grease, then replace the axle and thread the axle cap back on. The two tools are needed to then set the preload and tighten.
That is what I was referring to when I posted that its a fast process.
Really wasnt trying to be contentious with the prior post- just relaying my experience with modern Shimano looseball hubs, which is that they are long lasting, easy to service, and fast to service.
On my current bikes I have 3 with Shimano cup and cone hubs, and 3 with various brands which use cartridge bearing hubs. On those 6 wheelsets, I have spent longer trying to remove stuck cassettes that have etched their way into 'anti-bite' freehubs that use cartridge bearings, than I have spent servicing the guts of modern Shimano hubs.
I like the cartridge hub wheelsets more though- the ones on my 2 most ridden bikes are lighter than cup and cone bearings and have proven to be basically no maintenance for however many thousands of miles.
Liked 10,971 Times
First, I fully recognize that how a wheel spins on a stand is not indicative of how it spins when in use. Quality cup and cone hubs, even 40 year old versions, seem to be frictionless when spun on a stand, especially compared to all the cartridge hubs I have owned. But I totally understand that there are no applied forces in a stand and wheel dynamics are complex. Just mentioning that since it is something I see frequently(people swear cup and cone are 'better' because they spin forever without load).
I get your other point, too: cup & cone hubs are smooth. I had a very cheap set of such wheels on my SS commuter bike. The whole bike was about $550, so the hubs were some no-name made-in-taiwan junk...The first time I opened them up, the races were already scored -- they probably came that way when new. But still, with some new grade 25 ball bearings and a fresh load of grease, they did indeed spin for days on end in the workstand. BUT: for my gravel bike, which routinely gets ridden in nasty conditions (rain, dirt, dust, mud galore), I prefer cartridge bearings. My five-year old DT 350 hubs have about 14k miles on them, and they still spin as well as when new.
Liked 1,473 Times
Koyote and mstateglfr I thought a cup and cone bearing system has loose ball bearings so if someone inexperienced (like me) opens one up, the ball bearings would just fall out, roll away, and some of them would disappear forever? To me, the advantage of the DT Swiss 350 hub is that there are detailed instructions for both its assembly and disassembly, and if I somehow mess up the cartridge bearings during maintenance (which seems quite a bit harder to do so compared to a cup and cone setup), replacements and/or upgrades are readily available at reasonable costs. Not to mention there is no preload to adjust.
Liked 10,971 Times
It sounds like you probably don’t have experience with that sort of maintenance, which is understandable, since such hubs are becoming rarer nowadays. It’s not difficult to learn, and you’d only need a couple of new tools, most likely. But I do prefer cartridge bearing hubs, because they just don’t need maintenance very often; and when they do, you just chick out the cartridge and stick in a new one.
Liked 1,473 Times
1. Proper gravel rim dimensions, i.e., 25 mm internal width, and still slightly lighter than my 19 mm IW 45 mm deep road wheels.
2. Roval states that the rim is made via Resin Transfer Molding ("RTM"). Interestingly, this is also how Time makes its frames:
Technology RTM – TIME - SHOP (timebicycles.com)
3. 18T freehub should be upgradeable 36T:
DT Swiss 36t Star Ratchet Kit: 2 star ratchets, 2 springs and grease - Modern Bike
4. But I have a weird hang up about J-bend spokes.
Likes For SoSmellyAir:
Sunshine
Liked 7,496 Times
This really is a 'to each their own' sort of scenario because it isnt right to want one type of wheel and isnt wrong to want another type of wheel. Many enjoy the maintenance side of cycling and many dont. Totally cool either way. I remembered you built up a bike from a frame last year, so I just assumed you had interest/confidence in basic hub maintenance. Again though, totally cool either way as there is no right or wrong way to do things.
...Though by Shimano's gradual move to cartridge bearings, the market for aftermarket wheels will be like 96% cartridge and 4% Campy cup and cone loose ball.
Likes For mstateglfr:
Liked 1,473 Times
Roval Terra CL II: Nice Wheels!
DT Swiss 350 freehub is so quiet that I can hear myself think. Thank you to Eric F for convincing me to ditch the stock Maxxis Ramblers; the GravelKing SKs do roll more smoothly on paved roads.
