Making the switch to 1x
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Recent gravel rides have made it clear to me that I could make use of a little more at the low end of the range, and the top end of my current setup is unused.
Current: 50/34 x 11-36 (11s)
The overlap between rings effectively gives me 15 unique ratios, with the top 2 essentially inconsequential.
New: 38T x 11x42 (11s)
38x42 will be the lower ratio I’m feeling like I need, and the 38x11 will get me above 25mph at a comfortable cadence. The steps in between are spread out a bit more than the 2x setup, but not much, and I think it will be good for my needs. I had initially thought of going with a 36T ring, but I think it will sacrifice too much on the top end to make me happy.
The new setup will be an XT cassette, XT M8000 long cage derailleur, with a Wolf Tooth Tanpan to adapt with my existing Ultegra levers.
As much as anything, this is an experiment to see if the 1x hype for gravel bikes is real (I like it a lot on my MTB). I can easily switch back to 2x, or try a different ring, if I’m not digging the new setup.
I’m intending to do some gravel events (including BWR San Diego), but I’m not racing for placing, so ultimate speed is not a top priority. The lower low-end range will hopefully help me just finish on a route that is way out of my comfort zone.
Likes For Eric F:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times
Why not just use a GRX RD-RX812, which will work with a 11-42 cassette?
SHIMANO GRX Rear Derailleur 11-speed (42T max low sprocket) | SHIMANO BIKE-EU
The GRX RD is $120. Wolf Tooth Tanpan is $45. XT RD-M8000 is $65. $45 + $65 = $110, so cost-wise it is a wash.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 270 Post(s)
Liked 241 Times
I would consider a SLX 11-46 cassette too
Quoted: 1461 Post(s)
Liked 1,486 Times
I'll be interested to hear what you think.
I love 1x, mostly because of the clutched RD and narrow/wide rings which eliminate chain slap and keep everything secure when bouncing around on rough terrain. I'd second the GRX 812 rear derailleur for this application, as it seems better suited for road shifters and should be able to handle the range you're looking at. Being able to switch the clutch on/off is an added bonus (though I mostly just leave it "on" all the time now).
I run 40T (rough gravel/CX) and 44T (road and light gravel) on my 1x bikes. In both cases I run an 11-32 rear cassette so I'm on the opposite side of the range as you - it's flat here and I rarely use the lowest ratios. A 36T would probably be too small for most of the riding I do.
Likes For msu2001la:
Quoted: 1401 Post(s)
Liked 1,886 Times
XTR or Garbaruk cassette might be options if you want to shed a few grams from the XT 11-42
not sure of the tooth counts though - XTR might be 11-40 (?)
XT 11-42 cassette cost is reasonable - but it’s relatively hefty 430 g or so (?)
Liked 1,886 Times
I have one 1x bike with 44 and 10-42 cassette
only have a few short rides on it
will be swapping to 40 t chainring soon - don’t need 44-10 - and this should also reduce use of the 42t cog which is a big step (6t) and is alloy
Likes For t2p:
Quoted: 6972 Post(s)
Liked 10,971 Times
Given that you sometimes ride a SS, I'll predict that the larger gaps (on some range of the cassette) will give you little difficulty. Most SS and fixed riders have learned to spin at different cadences.
For gravel riding/racing, the top end is less important, since you'll likely only hit >25mph on descents...And those are great for recovery (i.e., tuck and coast) and/or are often rough enough that you wouldn't want to go too fast anyway.
Likes For Koyote:
Habitual User
Liked 8,099 Times
The GRX RD is $120. Wolf Tooth Tanpan is $45. XT RD-M8000 is $65. $45 + $65 = $120, so cost-wise it is a wash.
Habitual User
Liked 8,099 Times
I have a Garbaruk cassette on my MTB, and I like it a lot. I considered it for my gravel bike, but the only 11s options are 11-46 and 11-50, which aren't where I was wanting to go with this. I also didn't want to go that expensive.
Liked 1,472 Times
Likes For SoSmellyAir:
Habitual User
Liked 8,099 Times
Good to know. Thanks. Had I bothered to research it before, I might have gone that way.
Quoted: 446 Post(s)
Liked 1,045 Times
Hi Eric,
I would most definitely go with the GRX 812 RD if you plan on running 1x, since it's compatible with your Ultegra 11 speed shifters. Another option is to stay 2x, pick up a GRX crankset, GRX 2x FD/RD and you can use your road cassettes. That would get you lower gearing while gaining higher gearing over a 38t/11-42t setup.
As for me, I'm running the 812+Goatlink with an 11-50t cassette and 40t chainring. I can easily hit 25mph + around the Rose Bowl loop with this setup and even get up to 30mph on short sprints. This also allows me to spin through those spicy climbs through Glendale Sports Complex to Cherry Canyon and get through the climbs near JPL.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
But don't you need a 20:36 low gear for ascending Stelvio with luggage and 53:11 for descending from the Rockies on the interstate?
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Habitual User
Liked 8,099 Times
Hi Eric,
Habitual User
Liked 8,099 Times
Quoted: 3242 Post(s)
Liked 2,089 Times
Habitual User
Liked 8,099 Times
As far as overall range, a 30/46 with my current 11-36 cassette would extend the range even lower than my intended 38x42 low gear, but would still have a couple of gears on the high end that I don't seem to have much use for. Within the range of gears that I actually use, the only advantage I see in a 30/46 2x is a couple more steps in the mid-high range.
Why should a 2x be desired?
Liked 2,089 Times
Swapping the crank also means replacing a power meter, which drives up the cost significantly. As I mentioned, part of this is also about trying a 1x system to see if it is something I want to stick with.
Likes For Steve B.:
Habitual User
Liked 8,099 Times
I'm making the 1x change to my gravel bike precisely because my riding is not flat very much, and have bumped against times when I was looking for something lower than 34x36. Maybe it will turn out that I don't like the 1x. If that's the case, I have lots of options.
Likes For Eric F:
I made a similar swap from a compact 2x to an 11-42 XT cassette-based 1x and never looked back. I have 38, 40, and now 44 chainrings, so it took some experimentation to find the "sweet spot" for me. Also, the tanpan + XT works fine, but the GRX setup is just more straightforward.
Likes For jp911:
Liked 2,089 Times
Lot of good reasons to go 1X, especially if in hills with a lot of constant changes. Not needing to think much about front AND rear gear moves is nice, I have 1x on 2 mt. bikes, would never go back to anything else.
Habitual User
Liked 8,099 Times
I decided to go with the GRX 812 rear derailleur for the simple reason of keeping things simple.
I’ll stick the XT RD and Tanpan in a drawer in case I decide to go 11-46 in the future…or maybe I’ll sell them.
Likes For Eric F:
Quoted: 270 Post(s)
Liked 241 Times
your grx 812 is specced for 11-42 so it is lkely it will work with 11-46 slx like most 11-42 derailleurs.
issues tend to happen for 11-50
Likes For Fentuz:
Liked 1,472 Times
Simple is best.
Liked 1,886 Times
but the 48t big ring on the GRX 810 is different and mounts in a different way - compared to the 46t big ring on the GRX 600 crank
the 810 48t chainring is thicker near the mounting holes and sits in a recess on the crank arm ... the 600
46t ring is thinner near the mounting hole area and (apparently) does not mount in a recessed area
it’s possible the 600 46t chainring could still bolt on to the 810 crank - ? - dunno - but the appearance alone led to an aborted mission
46t ... 44t ... big chainring options would be welcome on the 810 crank
maybe the same person at Shimano responsible for the M900 XTR chainring sizes must have come out of retirement and selected the chainrings for the GRX 810 crank
