Are all square taper fixed cups left hand threads?
Quoted: 539 Post(s)
Liked 466 Times
Watching vids on overhauling a square taper BB. The fixed cup on the drive side is left hand threaded and loosens by turning clockwise. These seem fairly difficult to loosen and I have 3 bikes, 86 Trek 560, 80's Trek 400, and 83 Miyata 610, that I would like to service. I would hate to be trying to turn the fixed cup backwards on any of them. Will the fixed cup on all those bikes loosen clockwise?
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Yes. Get some good fitting tools to pull your particular cups, some penetrating oil, maybe even a heat gun, then take your time. Sometimes a bit of a whack with a hammer on the tool itself will help to break the friction if there is any corrosion in there.
Quoted: 876 Post(s)
Liked 2,293 Times
On your bikes , they would be left hand. Italian BB are different.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Many folks leave them alone while servicing rather than fighting with them and possibly damaging something. It isn’t terribly difficult to reach and evaluate the bearing cups from the opposite side. Lubing is also doable.
Likes For sd5782:
Quoted: 539 Post(s)
Liked 466 Times
I was about to order the tools and may leave off the fixed cup tool as it costs as much as the bb lock ring tool and pin spanner combined.
Likes For RH Clark:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Just use the Sheldon Brown nut, washers, bolt removal system. It is also OK to treat it as the fixed cup it is.
Likes For John E:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Don't fix it if it ain't broke.
If you had an Italian frame, then a RH Italian fixed cup would work, but if you have left-handed helical threads, you are stuck.
Unless this is a museum piece, it might be worth it to upgrade to a modern external BB and 24mm or 30mm spindle crankset.
Quoted: 539 Post(s)
Liked 466 Times
Likes For RH Clark:
Quoted: 2364 Post(s)
Liked 1,751 Times
Fixed doesn't mean you don't remove it. Fixed simply means you don't adjust it, like you do with (duh) the adjustable cup. Removing it assures you that you'll be able to remove it when you might really need to, for example, if the frame needs to be stripped bare for repairs or paint. Or if your BB completely wears out and you want to replace it with a cartridge. The longer you leave it without removing it, the harder it will be to remove the day you REALLY NEED to
Absent the spanner that fits snugly all the way around the cup (and even with such a spanner), I found the best method to be to use one of the trigger squeeze clamps used in furniture making, or for jobs like gluing cutting boards together. I've even used this method to hold a bigeffin' adjustable wrench on the cup flats. With a long enough cheater bar, I haven't encountered one yet that has not yielded.
Likes For madpogue:
Likes For gearbasher:
Quoted: 4512 Post(s)
Liked 6,387 Times
The "fixed" cup ALWAYS comes out for proper service of the cup and BB shell threads, inspect, clean and torque, period.
Any other version is neither complete or correct.
Likes For merziac:
A few tips for removing BB 1 loosen the fixed cup first. 2 Clamp the removal tool to the cup. 3 set the bike on the ground with air in the tires, 4 stand in front of bike holding handelbars, press down on tool with foot, use cheater bar if needed. 5 loosen the adjestable cup. .6 put bike in stand and dissamble.
Likes For trainman999:
Quoted: 800 Post(s)
Liked 754 Times
If the fixed cup is a pain to remove because it's been in there for so long or it was super-duper torqued down, then this is exactly the right moment to remove the fixed cup. I agree with the others. If you're servicing the bottom bracket, then do all of it.
Likes For Piff:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
I usually treat the bb fixed cup like the two head tube press fit parts: make sure it's in there snug and leave it alone.
I usually only remove it if it needs removing. The homemade Sheldon tool has worked for me.
If you started a poll on the subject of fixed cup removal for bb overhaul, I will guess it would be a 50/50 result.
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Ditto for French bottom brackets; right hand threads on the fixed cup (which, as many of us have found out the hard, is far more likely to loosen spontaneously after 10 or so miles; left hand threaded British fixed cups don't do that).
Yes, all of your bikes should have the British threading, i.e. left hand threading on the fixed cup. American and Japanese builders used the British standard for bottom brackets (probably with one or two outliers that do not matter with your three fine steeds).
As for the remove/don't remove the fixed cup debate, I am neutral. Like Switzerland. Which has it's own bottom bracket threading standard (same as the French, except left-handed thread for the fixed cup).
Bottom line: British, Italian, French and Swiss fixed cups are not compatible with each other. Swiss and French adjustable cups are the same - swap to your heart's content, but French/Swiss. British and Italian adjustable cups are not interchangeable. This silly state of affairs dates back to the days when the Alps and the English Channel posed much greater barriers to international trade than they do now.
Likes For bikingshearer:
Quoted: 4806 Post(s)
Liked 3,932 Times
Quoted: 876 Post(s)
Liked 2,293 Times
I’m lucky , I have a friend that has a very nice tool that securely removes the fixed cup . Sometimes it takes both of us but it hasn’t failed us yet. If he is not around , I lay the bike on a rug and use my big Sugino wrench . I have one bike with a Phil BB and , to me , my favorite…..NO MAINTENENCE!
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
Most fixed cups can be removed with a big crescent wrench, but it definitely helps to have a clamp or a version of the Sheldon Brown tool because the exposed flats of the fixed cup are so thin. The Sheldon tool gives you an extension clamped into the cup itself to give you a better purchase with the wrench. You can also use a longer bolt with bigger washers to keep the wrench snug against the bottom bracket cup, like with the clamp. I would say it makes more sense to spend a few bucks on some version of a clamping device than on the specialized wrench to fit the cup.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Until I got the tool I used a big adjustable held in with a big washer and bolt. Even with the tool I bolt it in if it doesn't come out easy.
Quoted: 539 Post(s)
Liked 466 Times
Thanks for the help, guys. I will attempt removal with a large wrench and an all-threaded bolt with washers and nuts to keep it in place. I suppose the danger is slipping and rounding the flats of the nut. If it looks like I might damage the nut I may leave it. I would rather get it out if possible, without damaging anything. Hopefully this one won't require a cartridge now, but I would like to have the option later.
Passista
Quoted: 868 Post(s)
Liked 721 Times
I suppose the final word is the manufacturer's recommendations/instructions. Is your affirmation based on any of them? Just curious.
Likes For Reynolds:
Liked 6,387 Times
A fixed cup wrench encircles the cup for far better purchase when every last bit counts.
I have a Sugino that I have had for over 50 years that is the only one I really use, Campy is next with Park last, I have them all, the Sugino has never failed me.
Then have a good cheater set up, I have a 4 foot thinwall pipe that is flatened at one end and slips over the wrench when needed.
The big crescent wrench can work ok but most have tapered jaws that can be hard to hold flat, square on the cup and often try to "cam" out/off and round off the flats, once this happens, you lose the best footing and success is much less likely without extreme measures.
It can be imperative to get it very right from the jump.
Likes For merziac:
