Does a more upright position give more power?
Bikes: motobecane outcast 29er singlespeed and nashbar singlespeed road bike
Quoted: 96 Post(s)
I'm not sure if this is specific to only some people, but I am tall and I have found that I think I can climb and accelerate better on a comfort upright bike because of how I can utilize my core muscles more.
and it also makes me able to get a fast start with taking off.
Yet I do know that aerodynamics will suffer such as once I am up to speed or going down a hill.
I just wanted to know if you really get climbing power by leaning towards the handlebars and bending over in the common position that a mountain bike will put you in, since people associate a aggressive position with maximum performance.
But I think I get a lot more by being upright and so you would be surprised that I can climb some very steep hills on a comfort cruiser that would actually be harder on a different bike.
you would not believe how a cruiser can be a climbing machine.
but am not sure if this is only an advantage because of my height 6.4
Quoted: 4560 Post(s)
Liked 2,804 Times
Probably too many variable to generalize, including in the engine room.
I improved my own efficiency and consistently measurable speed over 10 miles or more by replacing the original riser bars on my comfort hybrid with flat bars from my mountain bike. The original upright bars were only superficially more comfortable, but not for very long or many miles. It wasn't just getting a more aerodynamic position. The slightly lower bars and slight increase in reach got my thighs and hips more involved. Suits the slacker geometry of the heavy comfort hybrid. I'm still cruising only about 12 mph, but can do so for more miles without tiring.
And putting those same riser bars on my rigid mountain bike didn't make it more efficient, just more comfortable -- the original flat bars were a bit too low and the reach a bit too far, causing neck strain (permanently limited mobility due to damaged C2). More comfort means I can ride longer, farther and consistently at a reasonable cruising speed (for me) -- around 14 mph, whether I ride 10 miles or 60 in a day. Maybe that's an improvement in efficiency.
But recently I tried a friend's hybrid after he'd replaced the original flat bars with albatross bars. I could see why I was having trouble keeping up with him now, especially into head winds. The albatross bar grips put my hands closer to my thighs and hips, where isometric tension in my arms balanced out my pedaling. And the swept back bar tucks the arms closer to the torso, which is a little more aerodynamic. With my mountain bike's 24" wide riser bars at saddle height, I'm catching more air -- I can feel it demanding more effort to maintain a 15-16 mph pace.
It's still not going to be anywhere near as efficient as a well fitted bike with drop bars or aero bars. But the albatross or flipped North Roads bars might be a bit more efficient for me than riser or flat bars.
Likes For canklecat:
Quoted: 1074 Post(s)
Liked 295 Times
There's power - as in watts - and there is force - as in how hard you push.
They're not the same.
Your body weight alone will generate the most force when your center of gravity is right above the pedal.
And just like a weight lifter striving to have the bar close to his body, you'll be able to push the hardest when your body is as straight as possible between what you brace against and what you're trying to move.
Power is a different thing, basically composed of how strongly you can make a certain move AND how fast you can repeat it.
With geared bikes, the strongest push isn't always that interesting.
If you can do do the same move at half the strength but at 1/3 the time, that'll make more power than the slow-and-hard.
On a properly sized MTB you bend at the hip/waist, stretch your arms a bit and only lean your upper body forward. This keeps your center of gravity pretty much right above the pedals anyhow.
Leaning your full body forward will unweight the rear wheel and seriously hurt your ability to climb on loose surfaces.
Expired Member
Quoted: 3718 Post(s)
Liked 5,582 Times
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
For reasons discussed in the replies here, I think everyone should try mtb riding. There are a lot of skills learned via mtb riding that would help a roadie, inc how to generate power in an efficient manner. Too much and you spin out and end up walking the bike, too little and you don't make a climb and walk the bike..... while those in your group ride up. Then there is getting over/around obstacles.... and so much more.
For me, power can come from either position but typically while standing on the bike, but that doesn't last for very long and takes a lot out of you.
A long time ago when I was a kid I stood up on the pedals. I wasn't fast. But if I didn't stand up on the pedals I didn't make it up a steep hill at all.
Then at the top I sat down again.
Likes For jay ray:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
I find sitting with north road bars and a high seat night makes for easy climbing because I can pull on the bars as I push on the pedals. I end up using taller gear s with this technique.
Likes For 52telecaster:
Mad bike riding scientist
Quoted: 6243 Post(s)
Liked 4,262 Times
I'm wondering, however, if your "advantage" on the cruiser bike has more to do with gearing than with your rider position.
Stuart Black
Stuart Black
Likes For cyccommute:
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
I think what you are alluding to is getting assistance from gravity when you stand in the pedals. Even pro cyclists do this on particularly steep hills.
Liked 4,262 Times
First, your weight is over the pedal that is providing the most power to the crank. That's why we tend to move forward on the bike when standing to climb. We don't seesaw our body back and forth to keep it constantly over the pedals but we do move our center of gravity forward to be over the pedal during the power stroke of the cycle.
Also, your body weight is all you have to push down on the pedals with. There might be a slight increase in force if you pull with your arms but it's tiny compared to the force your body weight puts on the pedals.
Finally, mountain bike body position is a bit more complicated. There's a balance that needs to be struck. As you said, move too far forward and the rear wheel breaks loose. But, on the other hand, keep too much weight on the rear wheel and the front wheel lifts off the ground. You can't just sit on the saddle or just stand up like you might on a road bike. You have to strike a balance between the two or you won't go very far.
You seldom encounter this kind of problem on pavement. The surface is sticky enough that the rear wheel never breaks loose and the grades are seldom step enough to cause the bike's front wheel to lift off the ground.
I read something once that compares standing to climb vs sitting to climb to climbing stairs. You can run up stairs and get up the quickly but you burn too much energy to sustain the effort for long. If you walk up the stairs, it takes more time but your body's energy needs are impacted quite as much.
Stuart Black
Stuart Black
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
Quoted: 396 Post(s)
Liked 8 Times
Depending on the engine and grade, mashing and spinning converge. At some point spinning won't provide enough forward momentum to stay upright, and mashing simply exceeds the available power. Personally I spin out before I mash out
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Assuming the bike could be controlled with no hands, just imagine how much it would limit the amount of power you could apply to the pedals while not being able to pull yourself down with your arms.
Likes For fietsbob:
There are a lot of physiological commonalities but we are all different as well. E.G., some people have more fast twitch muscles, some slow twitch. Some have enormous aerobic capacity, others not. Alberto Contador stands and flings his bike all over the place while Vincenzo Nibali stays seated and hunkered over with his hands on the tops or hoods. Jan Ulrich did a slow mash up mountains while Lance did a fast spin. Who knows who is actually better - naturally.
A Sports Physiologist will tell you that you can generate the most power leaning forward on a drop-bar road bike and pulling back on the handlbars (tops, drops, hoods doesn't matter). Interestingly, next most powerful is sitting bolt upright on a city bike with no weight on the handlbars. And third is leaning partially forward with some weight on the flat handlebars.
Likes For CrankyOne:
Bikes: Specialized Roubaix Expert Road and Specialized Stump Jumper FS Mountain; De Vinci Caribou touring, Intense Tracer T275c, Cramerotti, Specialized Allez, Condor, Marinoni
Quoted: 168 Post(s)
Liked 106 Times
Yeah, that's why all the guys in the Tour de France ride upright cruisers!
Quoted: 1069 Post(s)
Liked 788 Times
I don't think it really matters when climbing. Climbing is about force and leverage while having very little to do with aerodynamics. In fact, being a bit less aerodynamic...i.e. standing up to pedal...has advantages on a climb. Most people I've observed stand at least occasionally on a climb..........
.........I read something once that compares standing to climb vs sitting to climb to climbing stairs. You can run up stairs and get up the quickly but you burn too much energy to sustain the effort for long. If you walk up the stairs, it takes more time but your body's energy needs are impacted quite as much.
Quoted: 1062 Post(s)
Liked 665 Times
I've found when sitting bolt upright that I get virtually no power at all, especially up hills. Even though my bikes have upright bars, and look like they could be configured in the cruiser geometry, I greatly prefer to be hunched over a little bit when riding. Not a lot. I can't tolerate drops. My preferred setup is to have my hands roughly level with the top of the saddle.
Note: I'm using the term "power" colloquially.
Going up hill changes things a bit. Similar to a seat that's too far back, your weight is now back behind the pedals instead of over them. Leaning forward helps to place your weight over the pedals again. Generally though, if you lean too far forward you actually loose a bit of power. However, if you lean extremely far forward (so that your back begins to arch) then you get it back and then some (E.G., you're riding similar to on a drop bar road bike).
Quoted: 79 Post(s)
Upright bar, hmmmm....
I can no longer lean on the handlebar at all, due to a destroyed shoulder. I have a 13"-rise stingray bar on my bike, and climbing is a bit more of a chore. Spinning a lower gear is mandatory for me. I discovered, though, on the flats, the added wind resistance was offset by more room for my legs (big thighs and a hypothyroidism-induced "beach ball" below my ribs), so I was fractionally faster, though not enough to really matter.
Everyone's experiences are unique to them, and similarities are generic.
There are many variables involved in body position and the transmission of power.
If you are climbing a steep hill in a low gear, then an upright position is best, because you are putting the weight of your body directly onto the pedals, and, hopefully doing a little pulling on the opposite foot as it comes back up.
For flats or shallow climbs, you will have more power when you are sitting, because if you are pedaling properly, in the seated position you can use all of the muscles in your legs. Aerodynamics play an important part, and have a huge effect, but for maximum efficiency and power, you must have a good pedal stroke, with no dead spots, and be able to pedal in circles.
Minor changes in the location of your cleats, seat post height and saddle tilt can make a surprisingly large difference in efficiency and power transmission, and it can take years of riding before one finally gets everything right. And more than a few people never do get it right, mainly for lack of knowing any better.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I did a hilly 213 km ride last weekend (9 days ago) with my road bicycle in a somewhat more aero position.
I did a not-so-hilly 100 km ride this past weekend with my Bike Friday which is still quite upright despite some early efforts to make it slightly more aero.
Although the longer ride was tougher because of the length and the climbs, that 100 km ride was a surprisingly difficult effort and I'd have to guess it was because of the less aero bicycle I was using. It was not only less comfortable ... it made riding in any sort of wind much more challenging. And it certainly didn't improve the climbing any.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
