Armadillo Tires Are A Joke
I have a Specialized road bike and thought I'd put an Armadillo on the back to reduce the number of flats. (I have used them before over the years). The bike has a standard Black Belt tire on the front.
I should add that I only ride on city streets.
One recent week the back tire had 3 flats, and I have had two since then. Always in the back, of course. The back wheel is enough of a pain to deal with, but these tires have tougher beads and are hard to get on and off.
These supposed "tough" tires are anything but.
Today I check the tire after a ride and, sure enough, it was flat. I thought it was a puncture, but about 7" of the tire was off the rim and the tube was blown out. Nice.
A total waste of money.
The last time you patched the tube you got part of it under the bead, that's not the tires fault. Partially fill the tube just enough to remove the wrinkles next time when you mount.
Likes For popeye:
Also, the tube was last replaced roughly 200 miles ago. I could be wrong but I think if it were pinched it would have blown out long ago.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Switch to Michelin Power Protection+. Install them correctly.
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Don't blame the tire. It is obvious it wasn't mounted correctly. Make sure ALL of it is under the bead ! I have done the same thing.
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times
Have a look at the Pirelli Cinturato. Great tyre for commuting. Roll fast and damn near puncture proof
Likes For illdrag0n:
Quoted: 4838 Post(s)
Liked 3,967 Times
OP, have you spun the wheel with the tire partially inflated to make sure the little line on the tire just above the rim doesn't hop or fall in under the rim? (The line; you can see it in your photo ~1/4" above the edge of the tire.) Won't help with the thorns, but it is a very simple tool to avoid a lot of problems.
Ben
Ben
Likes For 79pmooney:
I have gotten enough flats to know how to do that. I always partially fill the tube first. Regardless of this incident, I have had more flats from thorns with the Armadillo tire than with regular tires.
Likes For DeadGrandpa:
