Campy triple?
Bikes: GT,Trek,Fuji,and a couple of Schwinns
Quoted: 17 Post(s)
Liked 12 Times
Campy triple?
I'm thinking about adding a ring to my Campy equipped Trek 2200. !994 8 speed Veloce with a double chain ring and an extra click in the front shifter. Makes me think it could be a 2 or 3 ring shifter? The question is what triple will fit this bike? I see there is a Veloce 9 speed triple or maybe one of the Racing T crank sets with an even lower small ring. Do either of these fit without changing the bottom bracket? As I get older even the hills in Iowa seem to be getting taller. Is this something that could be a direct swap out, or am I looking at a whole new drive train?
Tripleizer chain ring And a longer BB or a 'Race Triple Crank, .... both Square Taper.. Campag /ISO BB
The 'Race triple' right arm is forged to use the same BB (111 for standard 115 for oversize seat tubes)
this is older parts , so good luck searching for them .. eBay, etc..
I'm Old I got some when they were new..
extra <C> 30's to sell , I put 24t on my 50-40, and a 26 on my 52-42 ..
Quoted: 4201 Post(s)
Liked 3,857 Times
You have a good bike for this upgrade (unlike most who follow trends I consider more and lower gearing an improvement). The Campy Ergo will handle a triple range easily. You should assume that whatever crank you end up with will need a different BB. If the same crank was used as a triple, compared to it's double config, the usual added driveside BB axle length is about 3 to 5mm. Aprox because as you look at ring/stay clearance the closer to the BB shell you get the more the stay angles in to the frame's centerline, so a complete added ring dimension isn't often completely needed (for the BB axle).
Don't forget about the ders too. Depending on how small a granny ring you pick and how good you are in avoiding some cog/ring combos the OEM double front der might do well. But if the inner is real small or you like to cross chain I would suggest a ft der for a triple. So to with the rear der but now the issue id chain wrap and having a chain long enough to still handle the big/big with minimal droop in the small/small.
BTW I have a NIB Campy Mirage 170 armed triple set (52-42-32) that I have never used. PM me if you're interested. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2026 Post(s)
Liked 1,096 Times
I had a 10-speed Campy Chorus triple on my 2006 Litespeed for many thousands of miles and it worked very well. It had 135/74 bolt circles and came with 53/42/30 chainrings. I substituted a 26T granny chainring and it still shifted fine. Campy sold a specific square taper Chorus cartridge bottom bracket for this crank and it used a 111 mm eccentric spindle IIRC. Obviously these are now available only NOS or used.
Quoted: 17 Post(s)
Liked 12 Times
Thank you all! I will be keeping my eyes open for something to get me down around 28 or 30 on the small end. right now I'm at 39/53, so a 30/40/50 maybe. I wish I had found this forum a long time ago. A wealth of knowledge and courteous people in the same place! Hard to believe now days.
