Cycling shoes
Cycling shoes
Picking up my first pair of cycling shoes and I'm torn about the fit. Tried on the 46.5 and they felt snug but comfortable. The 47 felt a little roomier. My question is is it better to go with a snug fit or a looser one
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 710 Times
Snug is better, but if they squeeze your toes you can get hotfoot. Where are they snug?
Different manufacturers fit differently. My feet are relatively narrow (size 13, B width) and I find Shimano shoes work well for me. YMMV.
Jeff Wills
Jeff Wills
They're snug across the top of the foot. Once I tighten the straps on the 47s there is no movement of my foot.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I like mine slightly loose ... that way I can add extra socks in winter.
My cycling shoes have laces so I can lace them tighter if necessary, or loosen them off if necessary.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
The old advice about getting them small-ish was from the days when they were pretty much all leather uppers, which tended to stretch. Synthetic materials don't do that so much. I go for the same fit I would want in street shoes.
I think 1st you need a better than they supply with the shoes, insole..
then bring your favorite insole with you, when you go trying on shoes.
I would Not buy 1st pair of bike shoes over the web..
Purpose? go fast performance the shoe would be tighter, sacrificing comfort,
for high rpm lack of slop/motion inside shoe.
A plodding Tourist, my best fitting shoes worked with my <C> record steel pedals and toe clips
Stiff soled, they were like pennyloafers off the bike,
but with Birkenstock cork composite insoles and the loose fit,
the feet were fine on 4+ month tours..
Bikes: 1997 Specialized M2Pro
Mine are slightly loose, and I've considered adding an insole, but doesn't that defeat one of the advantages of cycling shoes, namely, less give in the sole??
Starting over
Quoted: 10 Post(s)
The cushiest insole in the world won't do anything to alter the stiffness of the shoe's own sole. And that's the part that needs to be stiff.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Better a tiny bit loose. I need room in the toe area, and I've had shooes that were snug and comfortable when trying them on in the store, but painful at mile 60 on a hot day.
The cushiest insole in the world won't do anything to alter the stiffness of the shoe's own sole. And that's the part that needs to be stiff.]
and arch support stiffeners have made so so shoes, into something decent for commuting ,
without needing special bike Shoes.
Velo Club La Grange
Phillyfan:
I have two pairs of Northwave Aerlite S.B.S.; one is size 42.5, the other is 42. I bought the 42.5 first and while they felt, and still feel ok, I wanted a lil more snug fit. Both are fine, I just like the tighter fit better. I'm sure if you go up half size, you'll be fine.
Quoted: 3352 Post(s)
Liked 1,056 Times
A shoe manuf could probably make a fortune if they made and adv WIDE shoes. For some stupid reason they still seem to follow the italian foot print of shoes that are too narrow. I for instance wear a double E if I am fitted right. For me it is compounded by the fact that I have a very high instep. Shoes that are too narrow give hot foot and pain.
In Real Life
Bikes: Lots
Liked 596 Times
For most of my life I wished that shoe manufacturers would make much narrower shoes. B is the average width for women, and it's too wide ... I'm flopping about in Bs like they're flippers.
Unfortunately, about 10 years ago I developed arthritis in my right foot and now I have to buy Bs ... but they're too wide for my left foot and still too wide in the heel on the right.
That's partly why I like my Lake shoes ... they've got laces and I can do something to adjust the width, like tighten the left one tighter than the right.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: schwinn midmoor and looking
I certainly would not go with the snug fit .... As another poster said your feet will swell a bit, especially when warm out. I know mine do.
It's hard enough finding a good fit in regular shoes, but damn near impossible in cycling shoes. I'm wearing some garbage cheap Specialized mtb shoes that are ok. Everything I try fits like a size 3 ballerina slipper, no volume, straight as a string, loose in the heel. Even worse when you're slow and gotta walk the bike up horrendously steep climbs with stiff soles and a slick cleats. Going up a half size, they flex like clown shoes with the flex point behind the ball of my foot, but whatcha gonna do?
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I like a roomy toe box and I have wide feet. I use Sidi Mega's
