Swap out suspension fork for fixed?
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
I've been out of the game for a while. I have a ten-year old Hardrock that I want to swap the front fork for a fixed fork. How do I go about finding a fork that would be geometrically correct? Thank you.
'10 Specialized Hardrock
Measure the axle to crown length. See you can find the specs for rake, trail or offset.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Likes For dedhed:
If you want handling to remain the same, measure the axle to crown distance (from the center of the dropout to the bottom of the lower headset cup) and shorten that value by about 20% (to account for sag) to find the correct A2C for your new fork. You can also look up the amount of rake on the fork, although there's not a ton of variety on replacement forks. Take note that you may like a slightly shorter A2C if you're using the bike to ride around town, as it'll make the steering quicker/less stable which is more road-bike-y.
Wrong. To account for sag, you need to subtract ~20% of suspension fork travel from the A2C figure, not 20% of A2C. Or you could measure the sag directly (if the fork still works).
