Addiction LXXIX
#3026
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Yep.
They're handy for angles at which you can't use the 6" foam roller, or the quad-******. You can also put one point on the floor and use your leg and arms to drive the other point into your gastroc. Quite painfully and strictly hypothetically. Mentioning for a friend. Ok I just did that.
#3027
VFL For Life
Bikes: Velo Volmobile
Quoted: 28601 Post(s)
Liked 1,855 Times
#3028
Silver Comet Fred
Bikes: 1
Quoted: 8830 Post(s)
Liked 2,954 Times
too bad you didn't stay longer, you may have been positively impacted during your formative years.
#OpportunityLost
#OpportunityLost
#3029
Mostly Harmless
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times
#3030
Bikes: '88 Bianchi, '94ish Trek
Quoted: 1085 Post(s)
Liked 128 Times
"The mystery of life isn't a problem to solve, but a reality to experience."
#3031
Administrator
Quoted: 11965 Post(s)
Liked 6,631 Times
Elaine is zinging ‘em. lol
#3032
VFL For Life
Liked 1,855 Times
#3033
Should Be More Popular
Quoted: 22592 Post(s)
Liked 8,925 Times
#3034
Quoted: 10236 Post(s)
Liked 5,183 Times
squeaking was due to my cage being loose. You guys can rest worry free tonight.
#3035
Quoted: 3359 Post(s)
Liked 3,637 Times
#3036
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
#3037
Fat n slow
Liked 2,085 Times
Went to bed intending to do 40 this AM, woke up and legs are so sore from working out Wednesday I can barely descend the stairs.
Likes For phrantic09:
#3038
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
https://www.nhc.noaa.gov/refresh/gra...toa34#contents
We are in the medium green zone. There are a lot of appliances on the roof, not bolted down or otherwise at risk. AC compressor, Water tank, propane tank, solar water heater, solar panels are bolted down but I don't know about their wind speed limits.Internet receiver tower.
#3039
Quoted: 20810 Post(s)
Liked 9,456 Times
Yeah, the rolling pin's got some uses, but if I had to live without one of the two, I would happily jettison it. The 6" roller? Nope, never gonna give it up.
#3040
VFL For Life
Liked 1,855 Times
#3041
Liked 9,456 Times
#3042
VFL For Life
Liked 1,855 Times
#3043
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
#3044
VFL For Life
Liked 1,855 Times
#3045
Liked 5,183 Times
Oh it started two weeks ago when dunken decided to drop pumpkin slice lattes on us. Where they found pumpkins who were mature enough to go into a latte is the question.
#3046
Liked 9,456 Times
I thought that it was from some mud/grit that I'd stepped in last weekend when I came a cross some construction, but cleaning out the cleats and injecting new grease in to the pedals didn't get rid of it. It's definitely pedal/crank, though - it's only happening on the left pedal down-stroke. It almost sounds like when the end of the shift cable is hitting the crank arm, but it's not that.
#3047
Liked 5,183 Times
Likes For bampilot06:
#3049
Liked 5,183 Times
I've got a click, now.
And the squeak turned into a CLICK that’s how I solved it.
#3050
Liked 5,183 Times
