Help ID this frame
Help ID this frame
This frame came in to our coop, fork probably not original.
Notes:
1. Campagnolo dropouts
2. "C" cast in to lug that connects head tube and down tube
3. Some type of badge on head tube
4. Only one cable guide on bottom bracket
5 68 mm, BSC BB
6. Looks like two cable guides on each of seat stays near drop ouits
Notes:
5 68 mm, BSC BB
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Not ringing a bell for me, but I'll just say, that's a nice looking frame. The detail on the lugs is nice. Ron Cooper?
Quoted: 1088 Post(s)
Liked 1,205 Times
Is that first picture the emblem on the head tube? It looks like a bird with open wingspan, and it looks like the letters J and C on either wing. Not ringing a bell for me either, but my internal database doesn't run too deep.
Quoted: 3811 Post(s)
Liked 3,338 Times
lug pattern Prugnat 62/d
NERVEX, BOCAMA & others offered crowns of this shape, would need better image(s) for ID
chainstays certainly suggest Britain
the canti bosses on the seat stays appear to have been mounted asymmetrically
very nice job preparing the shell
thinking about 1975
Edit:
after posting recalled that the forum has had one or more bicycles with this head emblem in the past
alas, can no longer recall the maker
it is sure to twig the memory of other readers...
thinking about 1975
Edit:
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
subscribing! no ID for me, never saw that "JC" eagle before but like the effect with flat stock and a few handtools,This seems like it was a CX or touring frame, but the canti bosses are 2 different makes (?)...weird.
Liked 3,338 Times
also the drive side canti boss appears to have been mooshed...
Quoted: 5888 Post(s)
Liked 3,471 Times
VIntage steel cross bikes are not easy to find.
Liked 1,062 Times
One thing rings a faint bell with this, but very faint: there was a make of frame that we usually saw coming from Benelux and some were CX frames but marked with a single "D" engraved in the lugs and maybe also forkcrown. And IIRC the font was very similar to this "C" but I don't think there was ever any brazed-on head ornament. IIRC (again) there finally was an ID made for this mystery make and IIRC (3rd time) it was some connection to Martens/Martelly. Maybe there's some "Benelux trail" to follow with this one...just a thought.
Liked 3,338 Times
interesting suggestion
although chainstays tend to say "Britain" rather than "payes bas"...
framebuilder
That looks like a Henry James bottom bracket shell. That means it has to be an American made frame. Unless it is a Italian Roto shell. They are obvious because on the underside they had indented panels. Maybe the OP could take a look at the bottom of the shell and tell us if is plain like a HJ or indented (but not cut out all the way through) like a Roto? While Hank probably exported some of his investment cast frame parts overseas, I haven't ever seen them on anything but American frames. The retail cost of a European frame at that time was not enough to justify the expense of an costly American BB shell. Hank came out with shells before his lugs and fork crowns. I would estimate the age of this frame more towards the end of the 70's (unless that is a Roto shell).
I'm also betting that the C in the down tube lug was cut with a jeweler's saw and files. When I taught my framebuilding classes in the 70's I showed my students how to do that. In the 80's when Henry James lugs were a more popular choice then carving an initial wasn't as common because there wasn't as much real estate on the lugs for it to look right. I often cut the initial of the customer out of the lug so the "C" is not necessarily the builder's.
I'll also add that touring frames in the middle 70's were popular because of Bikecentennial.
Likes For Doug Fattic:
Liked 3,338 Times
Thanks so much for this always excellent information!
Am sure you will be able to contribute more as well when we get additional pictures...
Liked 1,062 Times
Yep, as always very pertinent points provided by Doug F.! But I'd say if this frame was for touring and not CX there would typically be at least a single (if not double) eyelet on the DOs, plus it's TBC but that blurry braze-on on the lower DS seatstay would make sense if the RD cable was routed from above, like along the TT, more typically for CX routing than for a touring frame. But all this could be clarified with MORE photos, please jrstewart3 !
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I was just thinking that he used those lugs for decades and did cut a "C" that size into some but the unfamiliar typeface, and lack of cleanliness male me question it...
I seem to have lost what little mind I had left before this all started.
PM me your cotters
Liked 590 Times
I still suspect it's a small-volume builder, OR maybe it's not, someone had this frame, stripped it to add cantis on and maybe do another repair (?), file the lugs while they're in there, and they could've very well the C lug addition in the process, along with the braze-on J/C eagle on the head tube. Those bits, the C, the J/C-eagle could simply be the second person who came along to add extra bits.
But I'm probably wrong
framebuilder
I would love to see the underside of the bottom bracket shell or if taking a photo is inconvenient than just tell us what it looks like under there. A plain shell indicates an investment cast Henry James BB shell and if there are indents than it is probably an Italian Roto shell. This will help us know if it was built in the States or Europe.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
But I don't think it's Belgian. My first thought when seeing the pics were "American" and "CX". For what that's worth.
Likes For non-fixie:
Quoted: 4511 Post(s)
Liked 6,381 Times
That cutout will ring some bells I bet.
Liked 1,062 Times
Not my bells, I'm afraid, but looks like it's NOT a Roto BB shell and the cutout in the socket is a bit too blurry to make it out but is it another sort of "winged creature", not a match to the "eagle" head badge but out of that aviary? I'm clueless as before but coming around to agree with this being "custom American" and still a mystery.
Liked 6,381 Times
PM me your cotters
Liked 590 Times
I mean, "C" + "Eagle" immediately makes me think Coventry Eagle, which lends credence to juvela 's comments but then what's up with the J/C in the eagle on the head tube?
Liked 3,338 Times
Doug's suggestion of a Yank origin due to the presence of the Hank shell would also explain the chainstays.
Gladly deferrin' to them whot knowz mo'.
Liked 1,062 Times
Now I'm REALLY confused, the sharper pic of that same braze-on but on the NDS chainstay, as well as the DS, does not compute as a cable guide: why would you need a cable there? Although it DOES appear to be close to the single "guide" on the DS of the BB shell...I'm just not getting a clear picture of what this bike was intended for!
What does the top tube look like?
Are there shifter bosses?
How about water bottle cage bosses, one set, two, or nuthin'?
