Bianchi Serial Number Identification
FixedGearQueer
Bikes: 2005 IRO, 198x Bianchi Stelvio
Is there a site that has the Bianchi serial numbers cross refferences with date of manufacture? I tried e-mail Bianchiusa and they told me there "is no serial number database" that they can look at to tell me more about my bike. I find that odd, but that's what they told me.
Any other suggestions?
Vincent
Vincent
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
If you can figure out Bianchi serial numbers, Vincent, you are a far better man than I!
If anyone else is interested, we can start our own a Bianchi serial number database. I'll start with my two entries. To participate, just copy the body of the message and paste in your own entry. Let's try to keep it organized by year, then by model.
date
purchased model S/N
Dec. 1962 Corsa 2F51703
ca. 1981 Campione d'Italia 1M9914
date
purchased model S/N
FixedGearQueer
date
purchased model S/N
Unknown Selvio S4504D5
feros ferio
Liked 1,331 Times
Originally Posted by nolageek
It appears that the first digit of yours are the last digit in the year of production.
date
purchased model S/N
date
purchased model S/N
Yes, I had considered that possibility, including a reversal of the old Schwinn Month-Year system, such that 2F = 1962 June and 1M = 1981 December, assuming H = August and J = September, ala Schwinn. Unfortunately, other people's Bianchis did not seem to fit this pattern.
Is your Selvio a Japanese Bianchi (BB shell measures 68mm instead of 70mm across, excluding lockring and fixed cup flange)? They would presumably use a different numbering system.
FixedGearQueer
I will measure and get back to you. It has the Made In Italy sticker, but I guess that could juist be where it was assembled?
feros ferio
Liked 1,331 Times
If it says "Made in Italy," it probably was brazed or welded there and presumably has a 70mm bottom bracket.
Bikes: Felt F60
Hi,
I have recently acquired a Bianchi frame. It is baby blue with a shimano dreailer and sakae crank arm. The serial number in DS484284. I can only assume the bike is from the mid to late 80's but was wondering the same thing as many others, which is if there is a web site, catalog, book that would tell the tale of the frame or bike as a whole. This question has already been asked but here it is again for those who may be in the know on such a matter.
Quoted: 4722 Post(s)
Liked 3,039 Times
Finney71, your Bianchi was made in Japan in 1984, but could be a 1985 model.
Building a better Strida
Bikes: bianchi brava 1988. fuji track 2007, 2006 Bianchi Pista, 1987 Miele and a strida knock off
speaking of this, when exactly did bianchi start manufacturing in Japan?
I ask, because I have read of bravas made in japan as early as 1986, but there are others made in italy as late as 1988...
was there a cutoff? or did they just have both manufacturing feeding different parts of the world?
Bikes: Felt F60
Thanks
Thank you to T-Mar for weighing in and getting me closer to finding material that will give me the specs of my bike. I am without wheels and hubs but I have worked to do before I put anymore parts on the bike. I would be interested in the source of information that led T-mar to know the bike is from the mid eighties.
Bikes: yes
Quoted: 59 Post(s)
Liked 81 Times
Hi Finney71,
Go to https://bulgier.net/pics/bike/Catalogs/ to view Bianchi catalogues (among many others) for the '84 - '85 time period. And welcome to BF!
stan
stan
Liked 3,039 Times
Then, circa 1985, there was a massive re-evalution of the yen that made most manufacturers offload to cheaper Taiwanese production. In Bianchi's case, it appears that the entry level models went to Taiwan while the lower mid-range models, such as the Brava and Limited, were brought back to Italy.
Thank you to T-Mar for weighing in and getting me closer to finding material that will give me the specs of my bike. I am without wheels and hubs but I have worked to do before I put anymore parts on the bike. I would be interested in the source of information that led T-mar to know the bike is from the mid eighties. ?
If there are no matches on the Bulgier site, you can post pics, list components, and state the seat post diameter. This will allow us to at least determine the relative level of your bicycle, if not identify the exact model.
Wrench Savant
T-Mar or others-
I recently came upon a Japanese made '87 Bianchi Sport SX, Ser#AS718273 (on the seat tube), Suntour alpha-5000 components. I am interested in knowing more about the frame geometry (beacuse I really like this one) and more about the "Bianchi Superset" Tange double-butted tubing.
Thanks.
Thanks.
Liked 3,039 Times
T-Mar or others-
Thanks.
Thanks.
The Sport was an upper entry level model with sports/touring geometry. Geometry will vary depending on the size, but suffice to say that the seat and headtube angle will be a slacker than a racing model of the same size. Also, there's more rake and a slightly longer wheelbase and chainstays. All this is meant to make it more comfortable and less twitchy than a racing bicycle. However, it is more sporty that the boom era sports/touring models. It's well suited to long, fast, day rides and the occassional triathlon.
Wrench Savant
Thanks, T-mar. The clearances between the rims and the brake bridge are rather tight (about 45mm from center of braking surface to the center of brake bolt). I also noticed that the fork rake looks rather generous. I am considering doing a 650B conversion, so I was interested in re-calculating the trail based upon the new wheel size. It is a 58 cm frame (c-c I think).
Liked 3,039 Times
Use a 73 head angle and 45mm rake for your calculations. Of course the results will all depend on the actual tire diameters but I'm guessing that you're looking at less than 5mm difference
Likes For T-Mar:
Wrench Savant
Thanks, again T-Mar. I thought the rake would be more in the 50mm range (near impossible to measure accurately with the tools I have available). The fork bend is very similar to an '86 Trek 310 I have.
Liked 3,039 Times
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Soooo, Are we going to start a Bianchi Serial Number database?
Roccobike BF Official Thread Terminator
Bikes: GT ZR5000, GT Timberline, Chariot Chauffeur
I just purchased a Japanese Bianchi from usedottawa.com. The serial number that I found on the bottom bracket is: LS206786
I am not sure what model it is. My plan is to make this my daily commuter bike.
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
serial number data?
Hello
I agree with the other post I don't think Bianchi USA ever kept track of serial numbers. if you are interested in knowing when the bike was made I am sure there are enough Bianchi geeketes and geeks here to help if you post more info and perhaps a pic. what color is it? 27" or 700c wheels?
I'll put some pictures up once I get it back from the bike shop. It is in for a tune up at the moment.
Bikes: Dean Animas CTi, Miyata 610, Lemond Zurich, Univega Viva Sport (sheldon's)
I have a Sport SX with SN BS801036 under the crank. A sticker on the seat tube says Made in Japan, and above the shifters says Campione del Mondo 86-87. Does anyone know the year of manufacture by reading the SN? Thanks for any help.
