What size tires are these?
There's time now
Quoted: 4096 Post(s)
Liked 164 Times
https://www.schwalbetires.com/Schwal...ed-11601054.01
Size: ETRTO 35-622 (28x1.35 Inch)
Is that 28c or something bigger? I am looking at a bicycle that has a maximum size of 28c (time alpe d'huez), and these are my current tires. I am missing something completely obvious and not sure what it is. Thank you for any help
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
The 28x1.35 is a European measurement. The 35x622 ERTO means the tire is 700x35c.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
Quoted: 1110 Post(s)
Liked 1,204 Times
It is not a 28mm wide tire (which is what you mean by 28C?). The 622 is a diameter measurement for the wheel itself, the ERTO nomenclature for a 700C wheel. The 35 denotes a 35mm tire width. So 35-622 = 700CX35, aka 700X35C. In either case the "C" refers to the classification of the wheel size, not the tire width.
1.35, in the 28X1.35, is the width of the tire in inches, equal to 35mm (which of course would actually be 1.38"... so I guess 1.4" would actually be closer since they want to round to the nearest .05")
The 28 denotes an approximate 28" diameter of the wheel and the mounted tire (in inches). It is the same 700C/622 wheel with a medium sized tire (in this case 1.35"/35mm), as opposed to the same 622/700C wheel mounted with a fatter (2-3") MTB tire - that would be called a 29-er! (PHEW!).
Dumb and confusing all around, except the 35X622 which is very precise and non-confusing labeling if you know what the ERTO system is. It should be the only system used, imho.
Why should I know this stuff? It's just dumb that I have had any need to or that you do. And I apologize for any unnecessary pedantry.
Thanks to the late great Sheldon Brown: Tire Sizing Systems (sheldonbrown.com)
Likes For Camilo:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2588 Post(s)
Liked 5,649 Times
Went to Sheldon Brown’s site. OMG, tire sizing is such a needless cluster. A standardized sizing nomenclature shouldn’t be that hard.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
It's totally standardized, if you can find the xx-xxx, or sometimes xxx-xxx if you're into fatbikes. But yeah the inches and the As, Bs, Cs are all over the place
Bikes: everywhere
Liked 7,697 Times
Likes For LesterOfPuppets:
Bikes: everywhere
Liked 7,697 Times
Quoted: 506 Post(s)
Liked 639 Times
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
That's what the ETRTO/ISO size designations do. I tell people to ignore the archaic inch-size and A-B-C designations and only pay attention to the ETRTO/ISO designations, which look like "35-622" where the first number is the nominal width of the tire and the second number is the bead seat diameter. The bead seat diameter is the most important part, as it determines whether the tire will actually mount on your rim. Rims can accommodate a range of tire widths (frame clearance is often a deciding factor when choosing tire width), but the bead seat diameter must match, or the tire won't mount.
Grupetto Bob
Liked 5,649 Times
Likes For rsbob:
Old fart
Liked 3,401 Times
Some do, but by no means all. I think tires are required to be marked with ETRTO size designations, but not rims.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
That's like saying we should all speak Esperanto. I find it kinda fun to be able to "speak" multiple systems.
Likes For Camilo:
Quoted: 4227 Post(s)
Liked 2,488 Times
Wow some people just muddy up the waters and create confusion...The simple answer to OPs question is the tires in question are 700 x 35mm. That's all that matters here.
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 157 Post(s)
Liked 146 Times
35mm vs. 120/220 for years before that.
I've somehow managed to limit it to Imperial vs. Metric the last 1/3 of my close-to-75 years.
If it's really, really important to you you'll work to wrap your head around a nomenclature as it applies to your non-trivial pursuits.
Likes For spclark:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Prompted from above: I didn't find what I was looking for regarding the actual difference between beaded and tubular bead seat diameters. (They are different, btw. (Tubular rims are 632mm. No, Really.)) But I did find this: https://en.m.wikipedia.org/wiki/ISO_5775
Could be interesting from a general discussion standpoint.
Bikes: everywhere
Liked 7,697 Times
How are they measuring BSD on tubulars? Seems like middle of the tire bed would make the most sense to me. Slightly surprised it would be that big there though.
Bikes: everywhere
Liked 7,697 Times
I am potato.
Liked 1,631 Times
Rim edge to rim edge since there is no lip or anything to hook in to and it glued to the outermost surface. The brake tracks are in the same place though. So, typical "700" naming convention seems to be the order of the day when researching. It's probably a smart omission among manufacturers. The various systems are confusing enough.
Car dependency is a tax.
Likes For base2:
Quoted: 157 Post(s)
Liked 146 Times
Helps having another approach laid out when next I try again to wrap my head around tire / rim sizing specs.
Bikes: everywhere
Liked 7,697 Times
Liked 2,568 Times
Hehehe... for awhile I tried Beta vs. VHS but that got decided by others fairly quickly.
Old fart
Liked 3,401 Times
