Less torque question
Likes For grumpus:
The effects of creep deformation generally become noticeable at approximately 35% of the melting point (in Kelvin) for metals and at 45% of melting point for ceramics.[3]
Likes For Duragrouch:
Quoted: 4412 Post(s)
Liked 1,566 Times
The coil spring and mechanism in a click-stop torque wrench is steel. If not overstressed and not at (very) elevated temperature, steel does not "creep" or "take a set" at room temperature. Plastics/polymers/elastomers/etc are different, and can take a set. Lead, solder, ice, can also creep at temps below melting point. From wiki:
Steel, at room temperature, no.
Quoted: 1109 Post(s)
Liked 1,200 Times
But all I'm doing is that if the OP feels accurate torque is necessary, his first step other than guessing should be to look locally. I have no idea what's available where they live, but I just suggest they look around.
May be just "old practice", or it may have to do with whatever is the sliding "cam" surface where it overrides the spring force, perhaps that is not steel.
Liked 1,566 Times
Quoted: 2496 Post(s)
Liked 739 Times
Sorry people but I completely lost it after only about eight posts and came right here to say: I've never owned a torque wrench. I've built bikes and maintained bikes for 50 years and there isn't anything I can't do to or for a bike, and apart from cross-threading a replacement bottom bracket 8 years ago, that had to be re-tapped by my LBS, I've never broken anything, or had anything fail on me on the road. O.p. scenario is making my sides hurt I am laughing so hard. And the ferocity with which follow on posters are suggesting things like overnight delivery of a new wrench ... oy ... enough ... stop. Please. O.p. torque that nut to 8hm and give it a smidge more, or don't. If 8nm isn't enough, you will know because your crankset will explode, mid-race and you will DNF. Lesson learned. Develop 'the touch' that all good mechanics must have to get to the next level.
Quoted: 682 Post(s)
Liked 453 Times
Getting torque wrenches delivered overnight here is a case of going on to amazon and 3 clicks. It’s not like having a viable donor kidney delivered.
Likes For choddo:
$10, brand frickin' new, 10 years ago. They were always on sale at HF, reg $30, on sale for $10, any size:
Quoted: 5793 Post(s)
Liked 2,585 Times
For example dive computers automatically reset oxygen to 100% at midnight. This is a safety measure done to force divers to set the correct mix before diving, rather than assuming anything.
Likewise, best practice would be to set a torque wrench to zero so one cannot get into trouble by taking the setting for granted.
Not saying that's the logic behind torque wrench shop practice, but offering it as a possibility.
There are countless examples of things done a certain way, but the reasoning behind it being forgotten. Like why "normally open" valves are always left 1/8th turn off from full open.
Likes For FBinNY:
Liked 2,585 Times
Various reasons depending on the application. Where temperature may be a factor it prevents jamming with shrinkage.
But the usual reason is insurance against panic. In an emergency it might be necessary to quickly close the valve, ie. to prevent flooding.
Under stress an operator trying to close the valve might turn it the wrong way. Assuming it's stuck he'll continue, losing precious time before recognizing his mistake.
OTOH if the valve is free to turn in either direction, and he starts out wrong, he'll know it's not stuck, and correct himself after that 1/8th turn.
It can also be an aid for inspection. On many valves you can't see whether they're open or closed. By leaving the valve cracked off, it's easy to verify that it's open with a quick tweak.
Quoted: 366 Post(s)
Liked 274 Times
Just speaking from ordinary life experience, coiled steel springs don't last forever when constantly loaded. I'm thinking of the springs pulling against a garage door, or the suspension springs in a car.
Regardless of the actual physical reason, if accuracy is important it makes sense to store a spring in its most comfortable state.
Quoted: 2488 Post(s)
Liked 2,957 Times
So, at least theoretically, changing a spring from a state of tension or compression to its most relaxed state as a matter of course (and then, of course, loading it again later, when it's back in service) would result in the spring wearing out faster than if you were to leave it as is.
Likes For Trakhak:
Liked 2,585 Times
Springs don't change their constant (get weaker)unless distorted significantly. Otherwise they have 2 failure modes.
If stretched or compressed beyond their yield limit they won't return to their original length. A typical example is a bathroom scale that no longer zeros out after an extremely heavy person uses it. However, the constant is unchanged, so you can reset zero and continue using it. Old cars and trucks with a history of being overloaded sag for this reason.
The other mode is fatigue, whereby repetitive flexing beyond the fatigue threshold causes stress cracking and ultimately, collapse.
Liked 2,957 Times
If cycled within its working limits a spring will last nearly forever. Storing it loaded or unloaded doesn't make a difference. If that werent true, your car would slowly lower sitting in your driveway.
Unfortunately, the first time I hit a good-sized pothole, the coil spring let the engine sag enough for the fan blades to slice into the radiator. Over the next couple of years, I went through three radiators. Finally sold it to a friend for a dollar.
I've wondered ever since whether there might have been a workaround for the punctured-radiator problem.
Maybe something using bike inner tubes.
Further off topic:
Earliest bike inner tube hack was towing a friend on his motorcycle to a repair shop in 1974.
Latest: 2 hours ago, 24 x 2.00 tube stretched over the end of the bathroom sink drainpipe, secured with a Fernco coupler, and fed down the pipe that connects to the main waste pipe, bypassing a leaking section that would require tearing out a lot of Sheetrock to access.
Should last forever. As the French say (more elegantly, no doubt): nothing endures like the provisional.
Likes For Trakhak:
Liked 2,585 Times
Don't know your particulars, but a SOP fix for sagging or weak coil springs was (still is?) to fit a study rubber balloon into the spring, and inflate it firm enough to add some lift. The coils braced the sides, and you ended up with a poor man's tunable, air ride suspension.
Likes For FBinNY:
This reminds me of a long-gone car of mine, a 1960 Plymouth Golden Fury, bought in 1977 from the original owner, in Brooklyn. The engine mount arrangement was apparently a one-off design: big hinges in front, big horizontal coil spring in back.
Further off topic:
Further off topic:
I dunno about that year Fury, but in the years just prior, according to wiki:
The 1957 models were restyled; longer, wider, with very large vertical tailfins and a new torsion bar front suspension replacing the previous coil springs. While the new styling boosted sales, quality control suffered for all Chrysler products as they were brought quickly to market before their design and construction weaknesses could be fully addressed by engineering. The front suspension introduced Chrysler's Torsion-Aire Torsion bar suspension shared with all Chrysler products starting in 1957.
Quoted: 502 Post(s)
Liked 436 Times
Likes For grumpus:
Liked 1,200 Times
Liked 2,585 Times
We might also note that there are two types of published torque specs. Some may be critical with limited margin for error, while most are simply a way of offering guidance, since things like "hand tight" don't make the grade anymore.
There's also a cultural difference. For decades, mechanics learned hands on from more experienced mechanics, with knowledge passing from generation to generation this way.
Some time back, along with the creation of the internet, how we learn changed, and folks needed to communicate info like how tight is right in different ways, not dependent on the old one to one method.
So, I suspect we have s cultural divide based on when and how each of us learned. I, for one, am not invested in how anyone does any job, as long as they do it well.
FB
Chain-L site
FB
Chain-L site
