Carbon steerer question
Old 03-13-24, 12:33 PM
zactaylor
Quoted: 11 Post(s)
Liked 7 Times in 5 Posts
Hello all,
Looking for some advice.
I noticed at the beginning of last summer that there was a tiny 'line' on my carbon steerer tube just above the lower stem bolt. I actually just thought it was cosmetic marking, so have been riding on it ever since. Over the winter, the bike has been 'parked' while I have been on the winter machine, so I decided to drop the fork out just to be sure.
When I removed the stem, it was immediately apparent that it was not what I thought. There was a crack running down about 1cm from the mark I could see (covered by the spacers). It looks as though the lower stem clamp bolt has, at some point, been overtightened and 'compressed' the steerer tube.
To assess just how bad the damage was, I removed the expander bung and checked the inside. I could indeed feel a 'bump' where the line was on the inside of the tube.
Although I think I (sadly) already know the answer, could somebody answer for me: is the fork 'toast'? The mark was originally noted in June/July 2023 and I was riding it until October, and it never got any worse (from what I could see). However, now I have seen it 'properly' I am uneasy about riding it. The bung is actually very long (by modern standards) and comes right down all the way past the stem inside the tube.
Is it time for a new fork?
I wanted to attach images, but as I have only just joined the forum I can't. Bit of a silly rule?
Thanks in advance!
zactaylor is offline
Old 03-13-24, 12:51 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 839 Post(s)
Liked 1,258 Times in 663 Posts
I sure would not ride a carbon steerer if there was an obvious crack. It will fail at the worst possible time, with disastrous results.
I have seen some ways to sleeve them using a carefully sized plastic insert and epoxy but not as a repair technique
If you do get a new fork, spend the 20 bucks extra and get the expansion nut that supports the thin wall carbon steerer better than a star nut
/markp
mpetry912 is offline
Old 03-13-24, 12:59 PM
grumpus
grumpus's Avatar
Quoted: 502 Post(s)
Liked 436 Times in 335 Posts
Never ever ever use a star fangled nut in a carbon steerer.
grumpus is offline
Old 03-13-24, 01:03 PM
grumpus
grumpus's Avatar
Quoted: 502 Post(s)
If it's a particularly good fork you could probably have it repaired, but if you can easily buy a suitable replacement that's probably the way to go.
grumpus is offline
Old 03-13-24, 01:31 PM
travbikeman
travbikeman's Avatar
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times in 123 Posts
Hello all,
Thanks in advance!
Curious if your fork has a steerer tube with something similar to the following:
Or is it a star nut/clamp like this:
If it's like this last image, and if you are on a new bike still under warranty, you might want to speak further with your LBS on this. An incorrect clamp may have been used.
travbikeman is offline
Old 03-13-24, 01:36 PM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times in 694 Posts
I can’t see any reputable carbon shop repairing a steerer/fork !
What brand/model/year is the bike?
Barry
Barry2 is online now
Likes For Barry2:
Old 03-13-24, 01:46 PM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
Barry
No. Our local one only do frames and wheels.
choddo is offline
Old 03-13-24, 03:17 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
Nobody uses a star nut with a CF steer tube and neither did the OP. He referred to the expander bung that was in it.
Camilo is offline
Likes For Camilo:
Old 03-13-24, 03:29 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
Likely. Take it to a bike shop, where it can be assessed in person.
I wanted to attach images, but as I have only just joined the forum I can't. Bit of a silly rule?!
Spam mitigation rule. You can upload pictures to an "Album" associated with your user account, and other people can link to them from there.
JohnDThompson is offline
Old 03-13-24, 04:03 PM
Crankycrank
Quoted: 839 Post(s)
Liked 1,064 Times in 747 Posts
When you can post a photo that will be the most helpful. Without one no-one can say anything with any accuracy. Sometimes there are layup seams that get confused with cracks or damage so there is that possibility but I would suggest taking it to at least 3 different shops to get an in-the-flesh check which should be the most accurate way to do it.
Crankycrank is offline
Old 03-14-24, 04:29 AM
grumpus
grumpus's Avatar
Quoted: 502 Post(s)
He wrote "I removed the expander bung" and "The bung is actually very long (by modern standards)" - I think that's pretty conclusive evidence that he doesn't have a star nut, and knows what he's doing.
grumpus is offline
Likes For grumpus:
Old 03-17-24, 05:36 AM
zactaylor
Quoted: 11 Post(s)
Hello everybody
Thank you for all your replies.
I sent the photos to Carbon Bike Repair UK who are a highly-regarded repair shop in Leatherhead. They confirmed it was a clamp fracture.
I am going to contact the manufacturer for a new fork.
I will upload the photos (as I can now) so if anybody would like to add anything feel free!
Likes For zactaylor:
