31.8mm (Steerer tube) Stem Riser
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 58 Post(s)
Liked 30 Times
I have a Santana tandem with a 31.8mm threadless fork steerer tube. I'd like to raise the handlebars a couple of inches.
Does anyone have a source for a 31.8mm headset extender? (The forks are carbon (including the steerer tube), so it's a no-go on modifying them like I did on a previous tandem).
Cheers, Mike
Cheers, Mike
Due to carbon steer tube, it's a definite no on an extender that fits inside the carbon tube; It must be clamped outside, and with all normal precautions. Just be aware this will place more moment (torque) on the steer tube than the original setup, in all directions, like forward with weight on handlebars, left and right when climbing out of the saddle, etc. Use caution, get advice, preferrably from carbon fork experts, which is not me.
There are lots of higher stems (including adjustable hinged) that may preclude the need for an extender, but the same cautions apply.
Quoted: 5793 Post(s)
Liked 2,584 Times
It's not that a CF steerer couldn't take the load of an internally expanded stem riser ---- as long as it's not overly tightened.
The problem is much simpler. These stem risers are made for steel steerers with 1/16" wall thickness, so 1" for your bike or 3/4" for B a 1" fork. CF forks often have thicker walls, so the IDs won't be right.
Measure your fork's ID, then shop for the adaptor accordingly. And if you find one go easy on tightening it.
FB
Chain-L site
FB
Chain-L site
Liked 2,584 Times
Yes, I was half asleep when I posted that, but it could be worked around by a decent tinkerer. OTOH there are some external riser adaptors out there that the OP night consider.
FB
Chain-L site
FB
Chain-L site
https://www.crazyguyonabike.com/doc/...size=large&v=1
Quoted: 332 Post(s)
Liked 742 Times
That’s a tough one. I’ve never seen a 31.8 stem riser, and all the risers I’ve seen caution against using with carbon fiber steerers. I’d be considering a different style of handlebar.
Likes For bboy314:
Quoted: 839 Post(s)
Liked 1,062 Times
I couldn't find any 31.8/1 1/4" risers either but this may be useful if you want to try to find a stem with enough angle to raise your bars 2" more. Stem Comparison Tool | yojimg.net Plug in the numbers of your current stem and determine what angle and length stem you need to get the right setup.
Quoted: 58 Post(s)
Liked 30 Times
Duragrouch's comment has me concerned. I want to raise the bars about 2" (they are currently about 2" forward and 1" above the steerer tube. I weigh 235# and my stoker #135. Is that modification going to add an unacceptable level of torque on the steerer tube?
Should I just bite the bullet and have a steel fork made?
Cheers, Mike
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times
I would get a different fork. I wouldn't use a steerer tube adaptor at all especially not on carbon fiber. There are plenty of forks to be had but I would look at something specific for tandem usage.
Quoted: 6196 Post(s)
Liked 4,811 Times
Riser bars will get you 1˝" more height on the current stem and steerer tube length. There might be some that go more. I haven't looked in a long time to see what is out there.
Quoted: 58 Post(s)
Liked 30 Times
I think the new fork is the best idea. Carbon kinda scares me. I had a bad experience with a Trek Madone......
Thanks everyone!
Thanks everyone!
Quoted: 332 Post(s)
Liked 742 Times
If you can find an appropriate tandem rated fork “off the shelf” with a 1 1/8” steerer, you can use headtube reducers made by Problem Solvers to make that work with a 1 1/8” headset, and have many more choices of stems to use. I bought such a fork from Co-Motion bikes in Oregon a few years ago when I needed one.
Quoted: 501 Post(s)
Liked 436 Times
then you don't have to mess with the stem/steerer interface.
Likes For grumpus:
Quoted: 58 Post(s)
Liked 30 Times
Hmmmm, that looks interesting. Any idea where I can get one? I googled the name on the side of it and tried some names and descriptions of it, but didn't find anything
Quoted: 58 Post(s)
Liked 30 Times
Quoted: 332 Post(s)
Liked 742 Times
Does your bike have rim or disc brakes? When I was in need of a fork, I also contacted House of Tandems in Houston, TX. They had some really nice carbon Woundup forks on sale for a great price - because they were rim brake only (canti studs if I recall). Granted this was a few years ago.
Quoted: 501 Post(s)
Liked 436 Times
- "There's no such thing as a free lunch" (Heinlein); Whether you raise the handlebars via a riser, or inclined stem, or hinged stem, or that device (known as a handlebar double clamp or double stem), same position equals same moment for the same force.
- The problem I find with double clamps is a) they mount closely on each side of the stem, which is exactly where my aero clip-on bars mount, and b) if mounted further outboard instead, they require handlebars with a very wide area of stem clamp diameter, hard to find, so the double clamp or aero bars would be clamping in the transition area between the center and the sides, so a tapered diameter, which you can't clamp to.
- Some of those double clamps look awful lightweight in structure, hollowed out in the middle, and both brackets will be subjected to not only bending, but torsion when climbing, and for the latter, ideally, the clamps are a "closed section" to be stiff. The one I've seen made by Tern and comes on some of their bikes, looks more stout (even though technically, still not a closed section), and you can adjust the tilt in seconds:
https://www.mybikeshop.com.sg/shop/b...n-andros-stem/
Quoted: 839 Post(s)
Liked 1,062 Times
Why not contact Santana. They know a thing or two about building quality tandems and fitting all types of riders. They can also recommend on whether their fork steerer can handle various stem heights and lengths and may even offer a riser of some sort. Contact Santana - Santana Tandem
Quoted: 4210 Post(s)
Liked 3,875 Times
Unrelated to the riser designs is that when I see riders wanting so much change in handlebar positioning I think that the basic size/nature of the bike is no longer matching the changing rider's needs well. While bike can and are modded to better fit our aging bodies there can be a point when the changes are no longer keeping up with our needs. I see riders wanting to continue running drop bars (as an example) but need really high and close positioned bars to not be reaching out too far when on the brake lever hoods (and by then likely never use the drops for more than fast straight downhills). Generally I suggest flat bars, with the proper controls to match, as a first consideration. It's too bad that the interchangeability between flat and drop bar levers,brake/shift controls, has become so little with the "demands" of more integration and brand/series specific specs design direction we're going in. This makes keeping older bikes up to date with their rider's changing needs harder to do. Andy
AndrewRStewart
AndrewRStewart
Quoted: 501 Post(s)
Liked 436 Times
Quoted: 58 Post(s)
Liked 30 Times
This! Santana even use to offer a riser adaptor for their customers, I've installed a few when I worked at Allstar in Raleigh. I've also installed one for a second level of handlebar mounted accessories (before Minoura brought out their version for accessories).
I'm going to break open the wallet and buy a new fork.
Thanks for everyone's advice.
Cheers, Mike
Quoted: 1400 Post(s)
Liked 1,885 Times
