Cone pitting
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Yep, I meant to say cups. I like your explanation too on the lesser distance of the bearing track. Interestingly, I’ve seldom had a bad cup, so I should be thankful for that at least.
Quoted: 967 Post(s)
Liked 1,631 Times
Another question is how deep are the pits? Or are they even pits? Often I have seen super shallow changes in old Peugeot/Simplex Cones that were simply a change in color and not pits at all. A simple cleaning with 440 sand paper and they polished out just fine.
I have always been impressed at how well Cones and Cups hold out. After all, they are at the apex/cone of the entire bicycle including the fat yahoo on top of it and everything else... HA
OH... And another thing... I always replace the bearings on a old bike rebuild, but do I really have to? Probably not...
Really Old Senior Member
When you have saved enough old ones, do a mass cleaning and you have slingshot ammo.
Likes For Bill Kapaun:
Quoted: 980 Post(s)
Liked 582 Times
This is the one you'll more often see in bike shops, I think.
Likes For sweeks:
Quoted: 501 Post(s)
Liked 435 Times
I've got one of those too, but it just clamps the axle. The Stein tool allows the axle to be compressed (shortened) by the quick release *while* the bearings are being adjusted. There's no quesswork about how much the bearing pre-load changes when the wheel is subsequently installed on the bike.
Quoted: 980 Post(s)
Liked 582 Times
Good point... you'd be able to rotate the axle and feel for interferences better if the wheel wasn't clamped in a vise. I guess the Stein tool could be released from the vise as well.
Good point. IMO, it's absolutely critical to be able to rotate the axle in fingers for proper preload adjustment, rotating the wheel has too much leverage, you won't feel things.
Likes For Duragrouch:
