Road helmet Vs Mountain bike helmet
Old 06-18-10, 09:06 AM
Timbike2
Timbike2
Timbike2's Avatar
Bikes: 2009 Specialized TriCross Sport
Quick question (I think I know the answer, but had to ask).
I bought a Specialized TriCross Sport earlier this year to replace my Mountain bike I had been using for my 14 mile each way commute. I continued to use my Mountain bike helmet on the Cross bike. Everything went well in the transition--love the new bike, except I get pain in my neck from having to raise my head to see forward around the mountain bike helmet brim. Buying a new road bike helmet this weekend. Should I see some relief from the neck pain with the higher brim on the road helmet, allowing me to glance up without raising my head as far?
Sorry--I was longer winded than planned. Thank you!
Timbike2 is offline
Old 06-18-10, 09:25 AM
EKW in DC
EKW in DC's Avatar
Bikes: Trek 830 Mountain Track Drop bar conversion
Could you maybe just remove the visor from the helmet you already have instead of buying a new helmet? My helmet's visor is removable, e.g. It just pops out and can be popped back in. I mean, if you want to buy a new helmet, don't let me stop you, but if you've got a better use for $30+, then that may be an option.
EKW in DC is offline
Old 06-18-10, 10:28 AM
Timbike2
Timbike2
Timbike2's Avatar
No visor on the existing helmet. The helmet I have sits low on my forehead and to see forward I have to bend my neck up to see forward, especially when I'm on the drops. The helmet I have is a cheap Bell that looks like a skateboard helmet. Road helmets sit further up on your forehead allowing a view of the road without lifting your head as drastically.
Timbike2 is offline
Old 06-18-10, 10:33 AM
groovestew
groovestew's Avatar
Quoted: 60 Post(s)
Liked 43 Times in 33 Posts
I'm guessing you won't see much relief, because you'll still have to lift your head higher because you're angled lower. But get a new helmet anyway, because...
...you'll look dorky riding your new bike with that helmet.
groovestew is offline
Old 06-18-10, 12:42 PM
frpax
Steel is real, baby!
frpax's Avatar
Bikes: 1984 Pinarello, 1986 Bianchi Portofino, 1988 Bianchi Trofeo, 1989 Specialized Allez, 1989 Specialized Hard Rock, 2001 Litespeed Tuscany
Liked 7 Times in 7 Posts
Pop the visor off. Problem solved.
If you're still having neck pain, then maybe get a stem with more rise to it, or flip the existing one over, if that's an option.
OR, going from a mountain bike (which is typically a more upright riding position) to a road bike (more bent over) just requires some getting used to. I'd still pop the visor off, though, and see if that helps (which it should).
edit: after reading your 2nd post (which I initially did not do), go buy a proper helmet.
frpax is offline
Old 06-18-10, 12:52 PM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 130 Times in 97 Posts
My better half had an accident a few weeks ago when a motorist decided to play chicken with her in the rain... in avoiding the car she had to ride across a steel plate on the road and went down, hitting her head.
There was no concussion but she did get a little whiplash but what is important is that her helmet (a Bell metro) had a smooth shell and had she been wearing a road or mtb helmet with any pointy aero bits could have suffered worse injuries as these can catch on the ground and wrench your head and neck around.
Instead of a visor you could wear a cycling cap or sunglasses as the visor is another one of those things that can get snagged / hooked.
Sixty Fiver is offline
Old 06-18-10, 03:03 PM
thorsteno
wannabe
If you are willing to read there is plenty of info in here....
https://www.bhsi.org/
+1 on what 65er said which is mentioned in the site above.
thorsteno is offline
Old 06-18-10, 04:20 PM
PaulRivers
Quoted: 539 Post(s)
Liked 44 Times in 38 Posts
Bikeforums.net is composed of multiple personalities, and thus it is not surprising that it suffers from multiple personality disorder. :-D
I'll go into one thread and someone will vehemently insist that helmets don't make you any safer. Go into another, someone says a standard helmet isn't good enough, you need a smooth helmet to be safe.
lol, go figure...
To the OP, keep in mind that different helmet manufacturers shape their helmets slightly differently for the differently shaped heads out there. If you have any trouble with the helmet sliding around, you might try another brand. Just an fyi.
PaulRivers is offline
Old 06-18-10, 04:35 PM
mtnwalker
mtnwalker's Avatar
Bikes: '84 Centurion Accordo RS, '06 Gary Fisher Marlin, '06 Schwinn Fastback 27, '06 Litespeed Teramo
Safest bet:
Its smooth, rounded with no pointy bits and HIGH impact grade with a smooth inner lining for the not so high impact.
mtnwalker is offline
Old 06-20-10, 11:12 AM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Bikes: Some bikes. Hell, they're all the same, ain't they?
Liked 5 Times in 4 Posts
Originally Posted by mtnwalker
Safest bet:
Why not go for an SA-rated automotive helmet since they're rated for multiple high impacts (such as banging your head against the roll cage of a tumbling car)?
BarracksSi is offline
Old 06-20-10, 01:22 PM
shubonker
danke
shubonker's Avatar
i like my giro transfer. its great if you got a smaller face/head. Plus its cheap.
shubonker is offline
Old 06-20-10, 07:06 PM
idiotekniQues
Bikes: Jamis Coda Elite - custom 1x9 setup
Quoted: 222 Post(s)
Liked 8 Times in 4 Posts
i like the skateboard style helmets
idiotekniQues is offline
Old 06-20-10, 07:22 PM
dahut
Ridin' South Cackalacky
dahut's Avatar
lol, go figure...
I noticed that!
Personally I think anyone out on the road, jousting with cars etc, well... a helmet is a good idea.
Cruising around the campus or beach, okay, not such a big deal, perhaps. They look kinda goofy in those places, anyway.
But your wife is proof that the low danger statistics don't always work, for everyone, all the time.
Biking still remains a low danger activity, and the odds are that nothing severe will happen to you.
But when its you against the rest of the metal encased world, the long odds favor the prepared man... or woman.
Sixty Fiver, Im glad your wife wasnt badly injured. Thank Goodness!
dahut is offline
Old 06-20-10, 07:51 PM
DX-MAN
Yeah, 'Lopes', get the new helmet.
DX-MAN is offline
Old 06-21-10, 06:28 PM
shouldberiding
Bikes: '08 Trek 7.3FX
I've had the same experience with a mountain helmet, sits lower on the forehead. It's really irritating. Buy new!
shouldberiding is offline
Old 06-21-10, 08:21 PM
AndrewP
Bikes: Peugeot Hybrid, Minelli Hybrid
Mount a mirror on your bars so you can see forward without raising your head.
AndrewP is offline
Old 06-22-10, 09:03 AM
PaulRivers
Quoted: 539 Post(s)
See...forward?
Old 06-22-10, 10:01 AM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
I don't understand what people are talking about when they're complaining that a bike helmet sits "too far forward" and blocks their view.
I wear mine down at my eyebrows, which is where it's supposed to go for decent forehead protection. The visor blocks the sky, which is what I want, but the body of the helmet really isn't in my way, especially since it doesn't block anything I can see through my glasses.
How far back do some of you want to wear yours?
Old 06-22-10, 10:07 AM
PaulRivers
Quoted: 539 Post(s)
I'm a little confused as well, though I have a road helmet. Even so - I find it difficult to image there's any reason that a mountain bike helmet would sit farther forward on your head. A mountain bike helmet seems to have a bigger visor, but the helmet itself - you still need to be able to see down the trail. Only reason I know of that a helmet sits farther forward is that it's to big so it slides forward.
Old 06-22-10, 10:12 AM
BassNotBass
master of bottom licks
BassNotBass's Avatar
Quoted: 111 Post(s)
See...forward?
It's only a rear-view mirror if mounted that way.
BassNotBass is offline
Old 06-22-10, 12:21 PM
shouldberiding
I don't understand how you could wear any helmet (especially with a visor) down to your eyebrows and not have it obstruct your view unless you have a very upright position on your bicycle.
Old 06-22-10, 01:43 PM
BassNotBass
Quoted: 111 Post(s)
I didn't think it was possible for a typical road helmet to be worn backwards but I just saw it a few weeks ago. I was surprised to see that there are quite a few pictures on the 'net of this.
File Type: gif
Old 06-22-10, 04:23 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
I don't mean covering my eyebrows, I mean down to the top of them, to the edge of they bony part of my forehead. Basically, you wouldn't be able to see my forehead, unlike a lot of the people I see around here.
Old 06-29-10, 12:40 PM
shouldberiding
That's what I meant. To the top of the eyebrows. I can't see far enough ahead with my helmet down that far.
I usually have my helmet about an inch above the eyebrows. That's where it sits naturally. It would have to be deeper to sit that low without tilting the whole helmet forward at an angle.
ganchan
General Cycling Discussion
13
10-19-15 12:59 PM
bikebreak
Advocacy & Safety
17
06-26-13 01:03 PM
Mithrandir
Advocacy & Safety
20
07-22-12 09:03 PM
clarknick67
Road Cycling
29
12-02-10 04:00 PM
zeppinger
Advocacy & Safety
15
07-28-10 10:06 AM
